MOAB: Mesh Oriented datABase
(version 5.4.0)
\(\frac{1}{n}\sum_{i=1}^n\mu(s_i)^p\) More...
#include <PMeanPTemplate.hpp>
Public Member Functions | |
MESQUITE_EXPORT | PMeanPTemplate (double power, QualityMetric *qm=0) |
MESQUITE_EXPORT | PMeanPTemplate (const PMeanPTemplate ©) |
copy constructor | |
virtual MESQUITE_EXPORT | ~PMeanPTemplate () |
MESQUITE_EXPORT double | get_power () const |
MESQUITE_EXPORT void | set_power (double p) |
virtual MESQUITE_EXPORT bool | evaluate (EvalType type, PatchData &pd, double &value_out, bool free, MsqError &err) |
Evaluate objective function for specified patch. | |
virtual MESQUITE_EXPORT bool | evaluate_with_gradient (EvalType type, PatchData &pd, double &value_out, std::vector< Vector3D > &grad_out, MsqError &err) |
Evaluate objective function and gradient for specified patch. | |
virtual MESQUITE_EXPORT bool | evaluate_with_Hessian_diagonal (EvalType type, PatchData &pd, double &value_out, std::vector< Vector3D > &grad_out, std::vector< SymMatrix3D > &hess_diag_out, MsqError &err) |
Evaluate objective function and diagonal blocks of Hessian for specified patch. | |
virtual MESQUITE_EXPORT bool | evaluate_with_Hessian (EvalType type, PatchData &pd, double &value_out, std::vector< Vector3D > &grad_out, MsqHessian &Hessian_out, MsqError &err) |
Evaluate objective function and Hessian for specified patch. | |
virtual MESQUITE_EXPORT ObjectiveFunction * | clone () const |
Create copy with same state. | |
virtual MESQUITE_EXPORT void | clear () |
Protected Member Functions | |
double | get_value (double power_sum, size_t count, EvalType type, size_t &global_count) |
Handle EvalType for all eval functions, return OF value. | |
Protected Attributes | |
Exponent | mPower |
Exponent | mPowerMinus1 |
Exponent | mPowerMinus2 |
std::vector< size_t > | qmHandles |
std::vector< size_t > | mIndices |
std::vector< Vector3D > | mGradient |
std::vector< SymMatrix3D > | mDiag |
std::vector< Matrix3D > | mHessian |
Private Attributes | |
size_t | mCount |
double | mPowSum |
size_t | saveCount |
double | savePowSum |
This class implements an objective function that is the power-mean of the quality metric evalutations raised to the power-mean power. That is, the sum of each quality metric value raised to a power, divided by the totoal number of quality metric values.
Definition at line 51 of file PMeanPTemplate.hpp.
MESQUITE_EXPORT MBMesquite::PMeanPTemplate::PMeanPTemplate | ( | double | power, |
QualityMetric * | qm = 0 |
) | [inline] |
power | The exponent to use for the power-mean |
qm | The quality metric. |
Definition at line 59 of file PMeanPTemplate.hpp.
References clear(), and set_power().
Referenced by clone().
: ObjectiveFunctionTemplate( qm ) { clear(); set_power( power ); }
MESQUITE_EXPORT MBMesquite::PMeanPTemplate::PMeanPTemplate | ( | const PMeanPTemplate & | copy | ) | [inline] |
copy constructor
Define a copy constructor because the compiler-provided default one would also copy the temporary arrays, which would be a waste of time.
Definition at line 72 of file PMeanPTemplate.hpp.
: ObjectiveFunctionTemplate( copy ), mPower( copy.mPower ), mPowerMinus1( copy.mPowerMinus1 ), mPowerMinus2( copy.mPowerMinus2 ), mCount( copy.mCount ), mPowSum( copy.mPowSum ), saveCount( copy.saveCount ), savePowSum( copy.savePowSum ) { }
virtual MESQUITE_EXPORT MBMesquite::PMeanPTemplate::~PMeanPTemplate | ( | ) | [inline, virtual] |
Definition at line 80 of file PMeanPTemplate.hpp.
void MBMesquite::PMeanPTemplate::clear | ( | ) | [virtual] |
Clear any values accumulated for BCD-related eval calls
Implements MBMesquite::ObjectiveFunction.
Definition at line 47 of file PMeanPTemplate.cpp.
References mCount, mPowSum, saveCount, and savePowSum.
Referenced by MBMesquite::PatchPowerMeanP::initialize_block_coordinate_descent(), and PMeanPTemplate().
{ mCount = 0; mPowSum = 0; saveCount = 0; savePowSum = 0; }
ObjectiveFunction * MBMesquite::PMeanPTemplate::clone | ( | ) | const [virtual] |
Create a new instance of the objective function that is a copy of the callee with the same accumulated values, parameters, etc.
Reimplemented in MBMesquite::PatchPowerMeanP.
Definition at line 42 of file PMeanPTemplate.cpp.
References PMeanPTemplate().
{ return new PMeanPTemplate( *this ); }
bool MBMesquite::PMeanPTemplate::evaluate | ( | EvalType | type, |
PatchData & | pd, | ||
double & | value_out, | ||
bool | free, | ||
MsqError & | err | ||
) | [virtual] |
Either evaluate the objective function over the passed patch or update the accumulated, global objective function value for changes in the passed patch, depending on the value of the EvalType.
type | Evaluation type. |
pd | The patch. |
value_out | The passed-back value of the objective fuction. |
free | If true, incorporate the quality metric values only for those metric evaluations that depend on at least one free vertex |
Definition at line 99 of file PMeanPTemplate.cpp.
References MBMesquite::ObjectiveFunction::ACCUMULATE, MBMesquite::QualityMetric::evaluate(), MBMesquite::QualityMetric::get_evaluations(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::ObjectiveFunctionTemplate::get_quality_metric(), MBMesquite::QualityMetric::get_single_pass(), get_value(), mPower, MSQ_CHKERR, MSQ_ERRFALSE, qmHandles, MBMesquite::Exponent::raise(), and value().
Referenced by PMeanPTemplateTest::test_evaluate().
{ QualityMetric* qm = get_quality_metric(); if( type == ObjectiveFunction::ACCUMULATE ) qm->get_single_pass( pd, qmHandles, free, err ); else qm->get_evaluations( pd, qmHandles, free, err ); MSQ_ERRFALSE( err ); // calculate OF value for just the patch std::vector< size_t >::const_iterator i; double value, working_sum = 0.0; for( i = qmHandles.begin(); i != qmHandles.end(); ++i ) { bool result = qm->evaluate( pd, *i, value, err ); if( MSQ_CHKERR( err ) || !result ) return false; working_sum += mPower.raise( value ); } // get overall OF value, update member data, etc. size_t global_count = 0; value_out = qm->get_negate_flag() * get_value( working_sum, qmHandles.size(), type, global_count ); return true; }
bool MBMesquite::PMeanPTemplate::evaluate_with_gradient | ( | EvalType | eval_type, |
double & | OF_val, | ||
std::vector< Vector3D > & | grad, | ||
) | [virtual] |
The default implementation of this function will use the value-only variation of the evaluate method and numerical approximation to calculate gradients. Whenever possible, objective function implementations should provide more efficient analyical gradient calculations.
pd | The patch. |
grad_out | The gradient of the OF wrt the coordinates of each *free* vertex in the patch. |
Numerically Calculates the gradient of the ObjectiveFunction for the free vertices in the patch. Returns 'false' if the patch is outside of a required feasible region, returns 'ture' otherwise. The behavior of the function depends on the value of the boolean useLocalGradient. If useLocalGradient is set to 'true', compute_numerical_gradient creates a sub-patch around a free vertex, and then perturbs that vertex in one of the coordinate directions. Only the ObjectiveFunction value on the local sub-patch is used in the computation of the gradient. Therefore, useLocalGradient should only be set to 'true' for ObjectiveFunctions which can use this method. Unless the concrete ObjectiveFunction sets useLocalGradient to 'true' in its constructor, the value will be 'false'. In this case, the objective function value for the entire patch is used in the calculation of the gradient. This is computationally expensive, but it is numerically correct for all (C_1) functions.
pd | PatchData on which the gradient is taken. |
grad | Array of Vector3D of length the number of vertices used to store gradient. |
OF_val | will be set to the objective function value. |
Reimplemented from MBMesquite::ObjectiveFunction.
Definition at line 125 of file PMeanPTemplate.cpp.
References MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::get_evaluations(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::ObjectiveFunctionTemplate::get_quality_metric(), get_value(), mGradient, mIndices, mPower, mPowerMinus1, MSQ_CHKERR, MSQ_ERRFALSE, MBMesquite::PatchData::num_free_vertices(), MBMesquite::OF_FREE_EVALS_ONLY, qmHandles, MBMesquite::Exponent::raise(), MBMesquite::Exponent::value(), and value().
Referenced by PMeanPTemplateTest::test_gradient().
{ QualityMetric* qm = get_quality_metric(); qm->get_evaluations( pd, qmHandles, OF_FREE_EVALS_ONLY, err ); MSQ_ERRFALSE( err ); // zero gradient grad_out.clear(); grad_out.resize( pd.num_free_vertices(), Vector3D( 0.0, 0.0, 0.0 ) ); // calculate OF value and gradient for just the patch std::vector< size_t >::const_iterator i; double value, working_sum = 0.0; const double f = qm->get_negate_flag() * mPower.value(); for( i = qmHandles.begin(); i != qmHandles.end(); ++i ) { bool result = qm->evaluate_with_gradient( pd, *i, value, mIndices, mGradient, err ); if( MSQ_CHKERR( err ) || !result ) return false; if( fabs( value ) < DBL_EPSILON ) continue; const double r1 = mPowerMinus1.raise( value ); const double qmp = r1 * value; working_sum += qmp; value = f * r1; for( size_t j = 0; j < mIndices.size(); ++j ) { mGradient[j] *= value; grad_out[mIndices[j]] += mGradient[j]; } } // get overall OF value, update member data, etc. size_t global_count = 0; value_out = qm->get_negate_flag() * get_value( working_sum, qmHandles.size(), type, global_count ); if( global_count ) { const double inv_n = 1.0 / global_count; std::vector< Vector3D >::iterator g; for( g = grad_out.begin(); g != grad_out.end(); ++g ) *g *= inv_n; } return true; }
bool MBMesquite::PMeanPTemplate::evaluate_with_Hessian | ( | EvalType | type, |
std::vector< Vector3D > & | grad_out, | ||
MsqHessian & | Hessian_out, | ||
) | [virtual] |
The default implementation of this function will fail.
pd | The patch. |
Hessian_out | The Hessian of the OF wrt the coordinates of each *free* vertex in the patch. |
Definition at line 251 of file PMeanPTemplate.cpp.
References MBMesquite::MsqHessian::add(), MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::get_evaluations(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::ObjectiveFunctionTemplate::get_quality_metric(), get_value(), mGradient, mHessian, mIndices, mPower, mPowerMinus2, MSQ_CHKERR, MSQ_ERRFALSE, n, MBMesquite::PatchData::num_free_vertices(), MBMesquite::OF_FREE_EVALS_ONLY, qmHandles, MBMesquite::Exponent::raise(), MBMesquite::MsqHessian::scale(), MBMesquite::Exponent::value(), value(), and MBMesquite::MsqHessian::zero_out().
Referenced by PMeanPTemplateTest::test_Hessian().
{ QualityMetric* qm = get_quality_metric(); qm->get_evaluations( pd, qmHandles, OF_FREE_EVALS_ONLY, err ); MSQ_ERRFALSE( err ); // zero gradient and hessian grad_out.clear(); grad_out.resize( pd.num_free_vertices(), 0.0 ); Hessian_out.zero_out(); // calculate OF value and gradient for just the patch std::vector< size_t >::const_iterator i; size_t j, k, n; double value, working_sum = 0.0; const double f1 = qm->get_negate_flag() * mPower.value(); const double f2 = f1 * ( mPower.value() - 1 ); Matrix3D m; for( i = qmHandles.begin(); i != qmHandles.end(); ++i ) { bool result = qm->evaluate_with_Hessian( pd, *i, value, mIndices, mGradient, mHessian, err ); if( MSQ_CHKERR( err ) || !result ) return false; if( fabs( value ) < DBL_EPSILON ) continue; const size_t nfree = mIndices.size(); n = 0; if( mPower.value() == 1.0 ) { working_sum += mPower.raise( value ); for( j = 0; j < nfree; ++j ) { mGradient[j] *= f1; grad_out[mIndices[j]] += mGradient[j]; for( k = j; k < nfree; ++k ) { mHessian[n] *= f1; Hessian_out.add( mIndices[j], mIndices[k], mHessian[n], err ); MSQ_ERRFALSE( err ); ++n; } } } else { const double r2 = mPowerMinus2.raise( value ); const double r1 = r2 * value; working_sum += r1 * value; const double hf = f2 * r2; const double gf = f1 * r1; for( j = 0; j < nfree; ++j ) { for( k = j; k < nfree; ++k ) { m.outer_product( mGradient[j], mGradient[k] ); m *= hf; mHessian[n] *= gf; m += mHessian[n]; Hessian_out.add( mIndices[j], mIndices[k], m, err ); MSQ_ERRFALSE( err ); ++n; } } for( j = 0; j < nfree; ++j ) { mGradient[j] *= gf; grad_out[mIndices[j]] += mGradient[j]; } } } // get overall OF value, update member data, etc. size_t global_count = 0; value_out = qm->get_negate_flag() * get_value( working_sum, qmHandles.size(), type, global_count ); if( global_count ) { const double inv_n = 1.0 / global_count; std::vector< Vector3D >::iterator g; for( g = grad_out.begin(); g != grad_out.end(); ++g ) *g *= inv_n; Hessian_out.scale( inv_n ); } return true; }
bool MBMesquite::PMeanPTemplate::evaluate_with_Hessian_diagonal | ( | EvalType | type, |
std::vector< SymMatrix3D > & | hess_diag_out, | ||
) | [virtual] |
The default implementation of this function evaluate the entire Hessian and discard non-diagonal portions. Concrete objective functions should provide a more efficient implementation that evaluates and accumulates only the required terms.
pd | The patch. |
hess_diag_out | The diagonal blocks of a Hessian. I.e. Decompose the Hessian into 3x3 submatrices and return only the submatrices (blocks) along the diagonal. |
Definition at line 174 of file PMeanPTemplate.cpp.
References MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::QualityMetric::get_evaluations(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::ObjectiveFunctionTemplate::get_quality_metric(), get_value(), mDiag, mGradient, mIndices, mPower, mPowerMinus2, MSQ_CHKERR, MSQ_ERRFALSE, MBMesquite::PatchData::num_free_vertices(), MBMesquite::OF_FREE_EVALS_ONLY, MBMesquite::outer(), qmHandles, MBMesquite::Exponent::raise(), MBMesquite::Exponent::value(), and value().
Referenced by PMeanPTemplateTest::test_diagonal().
{ QualityMetric* qm = get_quality_metric(); qm->get_evaluations( pd, qmHandles, OF_FREE_EVALS_ONLY, err ); MSQ_ERRFALSE( err ); // zero gradient and hessian const size_t s = pd.num_free_vertices(); grad_out.clear(); grad_out.resize( s, 0.0 ); hess_diag_out.clear(); hess_diag_out.resize( s, 0.0 ); // calculate OF value and gradient for just the patch std::vector< size_t >::const_iterator i; size_t j; double value, working_sum = 0.0; const double f1 = qm->get_negate_flag() * mPower.value(); const double f2 = f1 * ( mPower.value() - 1 ); for( i = qmHandles.begin(); i != qmHandles.end(); ++i ) { bool result = qm->evaluate_with_Hessian_diagonal( pd, *i, value, mIndices, mGradient, mDiag, err ); if( MSQ_CHKERR( err ) || !result ) return false; if( fabs( value ) < DBL_EPSILON ) continue; const size_t nfree = mIndices.size(); if( mPower.value() == 1.0 ) { working_sum += mPower.raise( value ); for( j = 0; j < nfree; ++j ) { const size_t idx = mIndices[j]; hess_diag_out[idx] += f1 * mDiag[j]; mGradient[j] *= f1; grad_out[idx] += mGradient[j]; } } else { const double r2 = mPowerMinus2.raise( value ); const double r1 = r2 * value; working_sum += r1 * value; const double hf = f2 * r2; const double gf = f1 * r1; for( j = 0; j < nfree; ++j ) { const size_t idx = mIndices[j]; hess_diag_out[idx] += hf * outer( mGradient[j] ); hess_diag_out[idx] += gf * mDiag[j]; mGradient[j] *= gf; grad_out[idx] += mGradient[j]; } } } // get overall OF value, update member data, etc. size_t global_count = 0; value_out = qm->get_negate_flag() * get_value( working_sum, qmHandles.size(), type, global_count ); if( global_count ) { const double inv_n = 1.0 / global_count; for( j = 0; j < s; ++j ) { grad_out[j] *= inv_n; hess_diag_out[j] *= inv_n; } } return true; }
MESQUITE_EXPORT double MBMesquite::PMeanPTemplate::get_power | ( | ) | const [inline] |
Definition at line 83 of file PMeanPTemplate.hpp.
References mPower, and MBMesquite::Exponent::value().
double MBMesquite::PMeanPTemplate::get_value | ( | double | power_sum, |
size_t | count, | ||
EvalType | type, | ||
size_t & | global_count | ||
) | [protected] |
This function implements the common handling of the EvalType argument for all forms of the 'evaluate' method.
NOTE: This function modifies accumulated values depenending on the value of EvalType.
power_sum | The sum over the current patch |
count | The number of qm evaluations for the current patch |
type | The evaluation type passed to 'evaluate' |
global_count | The total, accumulated number of QM evaluations |
Definition at line 55 of file PMeanPTemplate.cpp.
References MBMesquite::ObjectiveFunction::ACCUMULATE, MBMesquite::ObjectiveFunction::CALCULATE, mCount, mPowSum, MBMesquite::ObjectiveFunction::SAVE, saveCount, savePowSum, MBMesquite::ObjectiveFunction::TEMPORARY, and MBMesquite::ObjectiveFunction::UPDATE.
Referenced by MBMesquite::PatchPowerMeanP::evaluate(), evaluate(), MBMesquite::PatchPowerMeanP::evaluate_with_gradient(), evaluate_with_gradient(), MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), evaluate_with_Hessian(), and evaluate_with_Hessian_diagonal().
{ double result = 0; switch( type ) { case CALCULATE: result = power_sum; global_count = count; break; case ACCUMULATE: mPowSum += power_sum; mCount += count; result = mPowSum; global_count = mCount; break; case SAVE: savePowSum = power_sum; saveCount = count; result = mPowSum; global_count = mCount; break; case UPDATE: mPowSum -= savePowSum; mCount -= saveCount; savePowSum = power_sum; saveCount = count; mPowSum += savePowSum; mCount += saveCount; result = mPowSum; global_count = mCount; break; case TEMPORARY: result = mPowSum - savePowSum + power_sum; global_count = mCount + count - saveCount; break; } return global_count ? result / global_count : 0.0; }
MESQUITE_EXPORT void MBMesquite::PMeanPTemplate::set_power | ( | double | p | ) | [inline] |
Definition at line 89 of file PMeanPTemplate.hpp.
References mPower, mPowerMinus1, and mPowerMinus2.
Referenced by PMeanPTemplate().
{ mPower = p; mPowerMinus1 = p - 1; mPowerMinus2 = p - 2; }
size_t MBMesquite::PMeanPTemplate::mCount [private] |
The number of accumulated entires
Definition at line 149 of file PMeanPTemplate.hpp.
Referenced by clear(), and get_value().
std::vector< SymMatrix3D > MBMesquite::PMeanPTemplate::mDiag [mutable, protected] |
Temporary storage for qm hessian diagonal
Definition at line 162 of file PMeanPTemplate.hpp.
Referenced by evaluate_with_Hessian_diagonal().
std::vector< Vector3D > MBMesquite::PMeanPTemplate::mGradient [mutable, protected] |
Temporary storage for qm gradient
Definition at line 160 of file PMeanPTemplate.hpp.
Referenced by MBMesquite::PatchPowerMeanP::evaluate_with_gradient(), evaluate_with_gradient(), MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), evaluate_with_Hessian(), and evaluate_with_Hessian_diagonal().
std::vector< Matrix3D > MBMesquite::PMeanPTemplate::mHessian [mutable, protected] |
Temporary storage for qm Hessian
Definition at line 164 of file PMeanPTemplate.hpp.
Referenced by MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), and evaluate_with_Hessian().
std::vector< size_t > MBMesquite::PMeanPTemplate::mIndices [mutable, protected] |
Temporary storage for qm vertex indices
Definition at line 158 of file PMeanPTemplate.hpp.
Exponent MBMesquite::PMeanPTemplate::mPower [protected] |
The power to use
Definition at line 144 of file PMeanPTemplate.hpp.
Referenced by MBMesquite::PatchPowerMeanP::evaluate(), evaluate(), MBMesquite::PatchPowerMeanP::evaluate_with_gradient(), evaluate_with_gradient(), MBMesquite::PatchPowerMeanP::evaluate_with_Hessian(), evaluate_with_Hessian(), evaluate_with_Hessian_diagonal(), get_power(), and set_power().
Exponent MBMesquite::PMeanPTemplate::mPowerMinus1 [protected] |
mPower - 1.0
Definition at line 145 of file PMeanPTemplate.hpp.
Referenced by evaluate_with_gradient(), and set_power().
Exponent MBMesquite::PMeanPTemplate::mPowerMinus2 [protected] |
mPower - 2.0
Definition at line 146 of file PMeanPTemplate.hpp.
Referenced by evaluate_with_Hessian(), evaluate_with_Hessian_diagonal(), and set_power().
double MBMesquite::PMeanPTemplate::mPowSum [private] |
The accumulated sum of values to the mPower
Definition at line 150 of file PMeanPTemplate.hpp.
std::vector< size_t > MBMesquite::PMeanPTemplate::qmHandles [mutable, protected] |
Temporary storage for qm sample handles
Definition at line 156 of file PMeanPTemplate.hpp.
size_t MBMesquite::PMeanPTemplate::saveCount [private] |
Saved count from previous patch
Definition at line 151 of file PMeanPTemplate.hpp.
double MBMesquite::PMeanPTemplate::savePowSum [private] |
Saved sum from previous patch
Definition at line 152 of file PMeanPTemplate.hpp.
