MOAB: Mesh Oriented datABase
(version 5.2.1)
#include "Mesquite.hpp"
#include "MsqError.hpp"
#include "ArrayMesh.hpp"
#include "DomainClassifier.hpp"
#include "PlanarDomain.hpp"
#include "MeshDomain1D.hpp"
#include "IdealShapeTarget.hpp"
#include "TInverseMeanRatio.hpp"
#include "TShapeSizeOrientNB1.hpp"
#include "TShapeSizeNB3.hpp"
#include "TQualityMetric.hpp"
#include "PMeanPTemplate.hpp"
#include "LPtoPTemplate.hpp"
#include "SteepestDescent.hpp"
#include "FeasibleNewton.hpp"
#include "InstructionQueue.hpp"
#include "TerminationCriterion.hpp"
#include "HexLagrangeShape.hpp"
#include "UnitUtil.hpp"
#include <iostream>
Classes | |
class | HigherOrderTest |
Defines | |
#define | HAVE_HO_HEX |
#define | TEST_HO_QUAD |
Functions | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (HigherOrderTest,"HigherOrderTest") | |
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (HigherOrderTest,"Regression") | |
static double | dist (double x1, double y1, double x2, double y2) |
int | tri_mid_edge_nodes_edge_center (double x2, double y2, double x3, double y3, double x4, double y4, double x5, double y5, double epsilon) |
int | quad_all_in_xy_plane (const Vector3D &p2, const Vector3D &p3, const Vector3D &p4, const Vector3D &p5, const Vector3D &p6, const Vector3D &p7, double epsilon) |
int | quad_mid_edge_nodes_edge_center (const Vector3D &p2, const Vector3D &p3, const Vector3D &p4, const Vector3D &p5, const Vector3D &p6, const Vector3D &p7, double epsilon) |
static void | get_ideal_quad (Vector3D &p2, Vector3D &p3, Vector3D &p4, Vector3D &p5, Vector3D &p6, Vector3D &p7) |
int | tet_mid_edge_nodes_edge_center (const Vector3D &p3, const Vector3D &p4, const Vector3D &p5, const Vector3D &p6, const Vector3D &p7, const Vector3D &p8, const Vector3D &p9, double epsilon) |
static void | get_ideal_tet (Vector3D &p3, Vector3D &p4, Vector3D &p5, Vector3D &p6, Vector3D &p7, Vector3D &p8, Vector3D &p9) |
Variables | |
const int | MAX_ITERATIONS = 1000 |
const double | QEL = 1.0 |
const double | IDEAL_TRI_SIDE = sqrt( 2.0 / sqrt( 3.0 ) ) |
const double | IDEAL_TRI_HEIGHT = 1 / IDEAL_TRI_SIDE |
const double | IDEAL_TET_SIDE = 2.0 / pow( 33, 1.0 / 6.0 ) |
const double | IDEAL_TET_BASE = sqrt( 3.0 ) * 0.5 * IDEAL_TET_SIDE |
const double | IDEAL_TET_HEIGHT = sqrt( 2.0 / 3.0 ) * IDEAL_TET_SIDE |
Definition in file HigherOrderTest.cpp.
#define HAVE_HO_HEX |
Definition at line 32 of file HigherOrderTest.cpp.
#define TEST_HO_QUAD |
Definition at line 33 of file HigherOrderTest.cpp.
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION | ( | HigherOrderTest | , |
"HigherOrderTest" | |||
"Regression" | |||
static double dist | ( | double | x1, |
double | y1, | ||
double | x2, | ||
double | y2 | ||
) | [inline, static] |
Definition at line 189 of file HigherOrderTest.cpp.
return sqrt( ( x1 - x2 ) * ( x1 - x2 ) + ( y1 - y2 ) * ( y1 - y2 ) );
static void get_ideal_quad | ( | Vector3D & | p2, |
Vector3D & | p3, | ||
Vector3D & | p4, | ||
Vector3D & | p5, | ||
Vector3D & | p6, | ||
Vector3D & | p7 | ||
) | [static] |
Definition at line 405 of file HigherOrderTest.cpp.
References QEL, and MBMesquite::Vector3D::set().
Referenced by HigherOrderTest::test_quad_basic_ideal(), HigherOrderTest::test_quad_basic_left_down(), HigherOrderTest::test_quad_basic_left_over(), HigherOrderTest::test_quad_basic_mid_convex(), HigherOrderTest::test_quad_basic_right_up(), and HigherOrderTest::test_quad_basic_top_down().
static void get_ideal_tet | ( | Vector3D & | p3, |
Vector3D & | p7, | ||
Vector3D & | p8, | ||
Vector3D & | p9 | ||
Definition at line 613 of file HigherOrderTest.cpp.
References IDEAL_TET_BASE, IDEAL_TET_HEIGHT, IDEAL_TET_SIDE, and MBMesquite::Vector3D::set().
Referenced by HigherOrderTest::test_tet_basic_apex_down(), HigherOrderTest::test_tet_basic_apex_over(), HigherOrderTest::test_tet_basic_apex_up(), HigherOrderTest::test_tet_basic_ideal(), and HigherOrderTest::test_tet_basic_mid_convex().
{ const Vector3D p0( 0.0, 0.0, 0.0 ); const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); p3.set( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT ); p4.set( 0.5 * ( p0 + p1 ) ); p5.set( 0.5 * ( p1 + p2 ) ); p6.set( 0.5 * ( p2 + p0 ) ); p7.set( 0.5 * ( p0 + p3 ) ); p8.set( 0.5 * ( p1 + p3 ) ); p9.set( 0.5 * ( p2 + p3 ) ); }
int quad_all_in_xy_plane | ( | const Vector3D & | p2, |
const Vector3D & | p3, | ||
const Vector3D & | p4, | ||
const Vector3D & | p5, | ||
const Vector3D & | p6, | ||
const Vector3D & | p7, | ||
double | epsilon | ||
Definition at line 375 of file HigherOrderTest.cpp.
Referenced by HigherOrderTest::test_quad_basic_ideal(), HigherOrderTest::test_quad_basic_left_down(), HigherOrderTest::test_quad_basic_left_over(), HigherOrderTest::test_quad_basic_mid_convex(), HigherOrderTest::test_quad_basic_mid_spin(), HigherOrderTest::test_quad_basic_right_up(), and HigherOrderTest::test_quad_basic_top_down().
int quad_mid_edge_nodes_edge_center | ( | const Vector3D & | p2, |
Definition at line 386 of file HigherOrderTest.cpp.
{ const Vector3D p0( 0.0, 0.0, 0.0 ); const Vector3D p1( QEL, 0.0, 0.0 ); const Vector3D e0 = 0.5 * ( p0 + p1 ); const Vector3D e1 = 0.5 * ( p1 + p2 ); const Vector3D e2 = 0.5 * ( p2 + p3 ); const Vector3D e3 = 0.5 * ( p3 + p0 ); int result = 0; if( ( p4 - e0 ).length() > epsilon ) result |= 1; if( ( p5 - e1 ).length() > epsilon ) result |= 2; if( ( p6 - e2 ).length() > epsilon ) result |= 4; if( ( p7 - e3 ).length() > epsilon ) result |= 8; return result; }
int tet_mid_edge_nodes_edge_center | ( | const Vector3D & | p3, |
const Vector3D & | p8, | ||
const Vector3D & | p9, | ||
Definition at line 589 of file HigherOrderTest.cpp.
References epsilon, IDEAL_TET_BASE, and IDEAL_TET_SIDE.
Referenced by HigherOrderTest::test_tet_basic_apex_down(), HigherOrderTest::test_tet_basic_apex_over(), HigherOrderTest::test_tet_basic_apex_up(), HigherOrderTest::test_tet_basic_ideal(), HigherOrderTest::test_tet_basic_mid_convex(), and HigherOrderTest::test_tet_basic_mid_spin().
{ const Vector3D p0( 0.0, 0.0, 0.0 ); const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 ); const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 ); const Vector3D e0 = 0.5 * ( p0 + p1 ); const Vector3D e1 = 0.5 * ( p1 + p2 ); const Vector3D e2 = 0.5 * ( p2 + p0 ); const Vector3D e3 = 0.5 * ( p0 + p3 ); const Vector3D e4 = 0.5 * ( p1 + p3 ); const Vector3D e5 = 0.5 * ( p2 + p3 ); int result = 0; if( ( p4 - e0 ).length() > epsilon ) result |= 1; if( ( p5 - e1 ).length() > epsilon ) result |= 2; if( ( p6 - e2 ).length() > epsilon ) result |= 4; if( ( p7 - e3 ).length() > epsilon ) result |= 8; if( ( p8 - e4 ).length() > epsilon ) result |= 16; if( ( p9 - e5 ).length() > epsilon ) result |= 32; return result; }
int tri_mid_edge_nodes_edge_center | ( | double | x2, |
double | y2, | ||
double | x3, | ||
double | y3, | ||
double | x4, | ||
double | y4, | ||
double | x5, | ||
double | y5, | ||
Definition at line 198 of file HigherOrderTest.cpp.
References dist(), epsilon, and IDEAL_TRI_SIDE.
Referenced by HigherOrderTest::test_tri_basic_ideal(), HigherOrderTest::test_tri_basic_mid_convex(), HigherOrderTest::test_tri_basic_mid_spin(), HigherOrderTest::test_tri_basic_peak_down(), HigherOrderTest::test_tri_basic_peak_over(), and HigherOrderTest::test_tri_basic_peak_up().
{ double x0 = 0.0, y0 = 0.0; double x1 = IDEAL_TRI_SIDE, y1 = 0.0; double x01 = 0.5 * ( x0 + x1 ); double x12 = 0.5 * ( x1 + x2 ); double x20 = 0.5 * ( x2 + x0 ); double y01 = 0.5 * ( y0 + y1 ); double y12 = 0.5 * ( y1 + y2 ); double y20 = 0.5 * ( y2 + y0 ); int result = 0; if( dist( x3, y3, x01, y01 ) > epsilon ) result |= 1; if( dist( x4, y4, x12, y12 ) > epsilon ) result |= 2; if( dist( x5, y5, x20, y20 ) > epsilon ) result |= 4; return result; }
const double IDEAL_TET_BASE = sqrt( 3.0 ) * 0.5 * IDEAL_TET_SIDE |
Definition at line 586 of file HigherOrderTest.cpp.
Referenced by HigherOrderTest::basic_tet_test(), get_ideal_tet(), HigherOrderTest::test_tet_basic_apex_down(), HigherOrderTest::test_tet_basic_apex_over(), HigherOrderTest::test_tet_basic_apex_up(), HigherOrderTest::test_tet_basic_ideal(), HigherOrderTest::test_tet_basic_mid_convex(), HigherOrderTest::test_tet_basic_mid_spin(), and tet_mid_edge_nodes_edge_center().
const double IDEAL_TET_HEIGHT = sqrt( 2.0 / 3.0 ) * IDEAL_TET_SIDE |
Definition at line 587 of file HigherOrderTest.cpp.
Referenced by get_ideal_tet(), HigherOrderTest::test_tet_basic_apex_down(), HigherOrderTest::test_tet_basic_apex_over(), HigherOrderTest::test_tet_basic_apex_up(), HigherOrderTest::test_tet_basic_ideal(), HigherOrderTest::test_tet_basic_mid_convex(), and HigherOrderTest::test_tet_basic_mid_spin().
const double IDEAL_TET_SIDE = 2.0 / pow( 33, 1.0 / 6.0 ) |
Definition at line 585 of file HigherOrderTest.cpp.
const double IDEAL_TRI_HEIGHT = 1 / IDEAL_TRI_SIDE |
Definition at line 196 of file HigherOrderTest.cpp.
const double IDEAL_TRI_SIDE = sqrt( 2.0 / sqrt( 3.0 ) ) |
Definition at line 195 of file HigherOrderTest.cpp.
Referenced by HigherOrderTest::basic_tri_test(), HigherOrderTest::test_tri_basic_ideal(), HigherOrderTest::test_tri_basic_mid_convex(), HigherOrderTest::test_tri_basic_mid_spin(), HigherOrderTest::test_tri_basic_peak_down(), HigherOrderTest::test_tri_basic_peak_over(), HigherOrderTest::test_tri_basic_peak_up(), and tri_mid_edge_nodes_edge_center().
const int MAX_ITERATIONS = 1000 |
Definition at line 72 of file HigherOrderTest.cpp.
Referenced by HigherOrderTest::HigherOrderTest(), and HigherOrderTest::hit_iteration_limit().
const double QEL = 1.0 |
Definition at line 73 of file HigherOrderTest.cpp.
Referenced by HigherOrderTest::basic_quad_test(), get_ideal_quad(), quad_mid_edge_nodes_edge_center(), HigherOrderTest::test_quad_basic_ideal(), HigherOrderTest::test_quad_basic_left_down(), HigherOrderTest::test_quad_basic_left_over(), HigherOrderTest::test_quad_basic_mid_convex(), HigherOrderTest::test_quad_basic_mid_spin(), HigherOrderTest::test_quad_basic_right_up(), and HigherOrderTest::test_quad_basic_top_down().
