MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 diachin2@llnl.gov, djmelan@sandia.gov, mbrewer@sandia.gov, 00024 pknupp@sandia.gov, tleurent@mcs.anl.gov, tmunson@mcs.anl.gov 00025 00026 ***************************************************************** */ 00027 /*! 00028 \file SteepestDescent.cpp 00029 \brief 00030 00031 Implements the SteepestDescent class member functions. 00032 00033 \author Thomas Leurent 00034 \date 2002-06-13 00035 */ 00036 00037 #include "SteepestDescent.hpp" 00038 #include "MsqFreeVertexIndexIterator.hpp" 00039 #include "MsqTimer.hpp" 00040 #include "MsqDebug.hpp" 00041 00042 #include <memory> 00043 00044 namespace MBMesquite 00045 { 00046 00047 std::string SteepestDescent::get_name() const 00048 { 00049 return "SteepestDescent"; 00050 } 00051 00052 PatchSet* SteepestDescent::get_patch_set() 00053 { 00054 return PatchSetUser::get_patch_set(); 00055 } 00056 00057 SteepestDescent::SteepestDescent( ObjectiveFunction* of ) 00058 : VertexMover( of ), PatchSetUser( true ), projectGradient( false ) //, 00059 // cosineStep(false) 00060 { 00061 } 00062 00063 void SteepestDescent::initialize( PatchData& /*pd*/, MsqError& /*err*/ ) {} 00064 00065 void SteepestDescent::initialize_mesh_iteration( PatchData& /*pd*/, MsqError& /*err*/ ) {} 00066 00067 void SteepestDescent::optimize_vertex_positions( PatchData& pd, MsqError& err ) 00068 { 00069 MSQ_FUNCTION_TIMER( "SteepestDescent::optimize_vertex_positions" ); 00070 00071 const int SEARCH_MAX = 100; 00072 const double c1 = 1e-4; 00073 // std::vector<Vector3D> unprojected(pd.num_free_vertices()); 00074 std::vector< Vector3D > gradient( pd.num_free_vertices() ); 00075 bool feasible = true; // bool for OF values 00076 double min_edge_len, max_edge_len; 00077 double step_size = 0, original_value = 0, new_value = 0; 00078 double norm_squared = 0; 00079 PatchDataVerticesMemento* pd_previous_coords; 00080 TerminationCriterion* term_crit = get_inner_termination_criterion(); 00081 OFEvaluator& obj_func = get_objective_function_evaluator(); 00082 00083 // get vertex memento so we can restore vertex coordinates for bad steps. 00084 pd_previous_coords = pd.create_vertices_memento( err );MSQ_ERRRTN( err ); 00085 // use auto_ptr to automatically delete memento when we exit this function 00086 std::auto_ptr< PatchDataVerticesMemento > memento_deleter( pd_previous_coords ); 00087 00088 // Evaluate objective function. 00089 // 00090 // Always use 'update' version when beginning optimization so that 00091 // if doing block coordinate descent the OF code knows the set of 00092 // vertices we are modifying during the optimziation (the subset 00093 // of the mesh contained in the current patch.) This has to be 00094 // done up-front because typically an OF will just store the portion 00095 // of the OF value (e.g. the numeric contribution to the sum for an 00096 // averaging OF) for the initial patch. 00097 feasible = obj_func.update( pd, original_value, gradient, err );MSQ_ERRRTN( err ); 00098 // calculate gradient dotted with itself 00099 norm_squared = length_squared( gradient ); 00100 00101 // set an error if initial patch is invalid. 00102 if( !feasible ) 00103 { 00104 MSQ_SETERR( err )( "SteepestDescent passed invalid initial patch.", MsqError::INVALID_ARG ); 00105 return; 00106 } 00107 00108 // use edge length as an initial guess for for step size 00109 pd.get_minmax_edge_length( min_edge_len, max_edge_len ); 00110 // step_size = max_edge_len / std::sqrt(norm_squared); 00111 // if (!finite(step_size)) // zero-length gradient 00112 // return; 00113 // if (norm_squared < DBL_EPSILON) 00114 // return; 00115 if( norm_squared >= DBL_EPSILON ) step_size = max_edge_len / std::sqrt( norm_squared ) * pd.num_free_vertices(); 00116 00117 // The steepest descent loop... 00118 // We loop until the user-specified termination criteria are met. 00119 while( !term_crit->terminate() ) 00120 { 00121 MSQ_DBGOUT( 3 ) << "Iteration " << term_crit->get_iteration_count() << std::endl; 00122 MSQ_DBGOUT( 3 ) << " o original_value: " << original_value << std::endl; 00123 MSQ_DBGOUT( 3 ) << " o grad norm suqared: " << norm_squared << std::endl; 00124 00125 // Save current vertex coords so that they can be restored if 00126 // the step was bad. 00127 pd.recreate_vertices_memento( pd_previous_coords, err );MSQ_ERRRTN( err ); 00128 00129 // Reduce step size until it satisfies Armijo condition 00130 int counter = 0; 00131 for( ;; ) 00132 { 00133 if( ++counter > SEARCH_MAX || step_size < DBL_EPSILON ) 00134 { 00135 MSQ_DBGOUT( 3 ) << " o No valid step found. Giving Up." << std::endl; 00136 return; 00137 } 00138 00139 // Move vertices to new positions. 00140 // Note: step direction is -gradient so we pass +gradient and 00141 // -step_size to achieve the same thing. 00142 pd.move_free_vertices_constrained( arrptr( gradient ), gradient.size(), -step_size, err );MSQ_ERRRTN( err ); 00143 // Evaluate objective function for new vertices. We call the 00144 // 'evaluate' form here because we aren't sure yet if we want to 00145 // keep these vertices. Until we call 'update', we have the option 00146 // of reverting a block coordinate decent objective function's state 00147 // to that of the initial vertex coordinates. However, for block 00148 // coordinate decent to work correctly, we will need to call an 00149 // 'update' form if we decide to keep the new vertex coordinates. 00150 feasible = obj_func.evaluate( pd, new_value, err ); 00151 if( err.error_code() == err.BARRIER_VIOLATED ) 00152 err.clear(); // barrier violated does not represent an actual error here 00153 MSQ_ERRRTN( err ); 00154 MSQ_DBGOUT( 3 ) << " o step_size: " << step_size << std::endl; 00155 MSQ_DBGOUT( 3 ) << " o new_value: " << new_value << std::endl; 00156 00157 if( !feasible ) 00158 { 00159 // OF value is invalid, decrease step_size a lot 00160 step_size *= 0.2; 00161 } 00162 else if( new_value > original_value - c1 * step_size * norm_squared ) 00163 { 00164 // Armijo condition not met. 00165 step_size *= 0.5; 00166 } 00167 else 00168 { 00169 // Armijo condition met, stop 00170 break; 00171 } 00172 00173 // undo previous step : restore vertex coordinates 00174 pd.set_to_vertices_memento( pd_previous_coords, err );MSQ_ERRRTN( err ); 00175 } 00176 00177 // Re-evaluate objective function to get gradient. 00178 // Calling the 'update' form here incorporates the new vertex 00179 // positions into the 'accumulated' value if we are doing a 00180 // block coordinate descent optimization. 00181 obj_func.update( pd, original_value, gradient, err );MSQ_ERRRTN( err ); 00182 if( projectGradient ) 00183 { 00184 // if (cosineStep) { 00185 // unprojected = gradient; 00186 // pd.project_gradient( gradient, err ); MSQ_ERRRTN(err); 00187 // double dot = inner_product( arrptr(gradient), arrptr(unprojected), gradient.size() 00188 // ); double lensqr1 = length_squared( gradient ); double lensqr2 = length_squared( 00189 // unprojected ); double cossqr = dot * dot / lensqr1 / lensqr2; step_size *= 00190 // sqrt(cossqr); 00191 //} 00192 // else { 00193 pd.project_gradient( gradient, err );MSQ_ERRRTN( err ); 00194 //} 00195 } 00196 00197 // Update terination criterion for next iteration. 00198 // This is necessary for efficiency. Some values can be adjusted 00199 // for each iteration so we don't need to re-caculate the value 00200 // over the entire mesh. 00201 term_crit->accumulate_patch( pd, err );MSQ_ERRRTN( err ); 00202 term_crit->accumulate_inner( pd, original_value, arrptr( gradient ), err );MSQ_ERRRTN( err ); 00203 00204 // Calculate initial step size for next iteration using step size 00205 // from this iteration 00206 step_size *= norm_squared; 00207 norm_squared = length_squared( gradient ); 00208 // if (norm_squared < DBL_EPSILON) 00209 // break; 00210 if( norm_squared >= DBL_EPSILON ) step_size /= norm_squared; 00211 } 00212 } 00213 00214 void SteepestDescent::terminate_mesh_iteration( PatchData& /*pd*/, MsqError& /*err*/ ) 00215 { 00216 // cout << "- Executing SteepestDescent::iteration_complete()\n"; 00217 } 00218 00219 void SteepestDescent::cleanup() 00220 { 00221 // cout << "- Executing SteepestDescent::iteration_end()\n"; 00222 } 00223 00224 } // namespace MBMesquite
