MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Lawrence Livermore National Laboratory. Under 00005 the terms of Contract B545069 with the University of Wisconsin -- 00006 Madison, Lawrence Livermore National Laboratory retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file NumericalQMTest.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "ObjectiveFunctionTemplate.hpp" 00034 #include "UnitUtil.hpp" 00035 #include "PatchData.hpp" 00036 #include "MsqHessian.hpp" 00037 00038 #include "cppunit/extensions/HelperMacros.h" 00039 00040 using namespace MBMesquite; 00041 using namespace std; 00042 00043 const double EPSILON = 1e-6; 00044 00045 class NumericalOFTest : public CppUnit::TestFixture 00046 { 00047 private: 00048 CPPUNIT_TEST_SUITE( NumericalOFTest ); 00049 CPPUNIT_TEST( test_gradient_constant ); 00050 CPPUNIT_TEST( test_gradient_linear ); 00051 CPPUNIT_TEST( test_handles_eval_failure ); 00052 CPPUNIT_TEST( test_handles_eval_false ); 00053 CPPUNIT_TEST( test_changed ); 00054 CPPUNIT_TEST( test_unchanged ); 00055 CPPUNIT_TEST( test_Hessian_fails ); 00056 CPPUNIT_TEST_SUITE_END(); 00057 00058 PatchData pd; 00059 00060 public: 00061 void setUp(); 00062 void test_gradient_values( bool constant ); 00063 00064 void test_gradient_constant() 00065 { 00066 test_gradient_values( true ); 00067 } 00068 void test_gradient_linear() 00069 { 00070 test_gradient_values( false ); 00071 } 00072 00073 void test_handles_eval_failure(); 00074 void test_handles_eval_false(); 00075 void test_changed(); 00076 void test_unchanged(); 00077 void test_Hessian_fails(); 00078 }; 00079 00080 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( NumericalOFTest, "NumericalOFTest" ); 00081 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( NumericalOFTest, "Unit" ); 00082 00083 /** Define a dummy ObjectiveFunction on which to do numerical gradient calculation 00084 * 00085 * If 'constant' flag is true, returns a constant value. 00086 * If 'constant' flag is false, returns a linear function of vertex coordinates. 00087 */ 00088 class NumericalTestOF : public ObjectiveFunctionTemplate 00089 { 00090 public: 00091 NumericalTestOF( bool should_fail, bool should_return_false, bool constant_func ) 00092 : changed( false ), fail( should_fail ), return_false( should_return_false ), constant( constant_func ), 00093 linearGrad( 1, 2, 3 ) 00094 { 00095 } 00096 00097 bool evaluate( EvalType type, PatchData& pd, double& val, bool free, MsqError& ); 00098 00099 ObjectiveFunction* clone() const 00100 { 00101 return new NumericalTestOF( *this ); 00102 } 00103 00104 void clear() 00105 { 00106 changed = true; 00107 } 00108 00109 bool changed; // "accumulated value" has changed (tester should initialize) 00110 bool fail; // if true, calls to accumulate will unconditionally fail 00111 bool return_false; // if true, evaluate will return false. 00112 bool constant; // if true, OF value is constant, otherwise linear. 00113 00114 const Vector3D linearGrad; 00115 }; 00116 00117 bool NumericalTestOF::evaluate( EvalType type, PatchData& pd, double& val, bool free, MsqError& err ) 00118 { 00119 if( fail ) 00120 { 00121 MSQ_SETERR( err )( "Expected failure of OF::evaluate", MsqError::INVALID_ARG ); 00122 return false; 00123 } 00124 00125 if( pd.num_free_vertices() < 1 ) 00126 { 00127 MSQ_SETERR( err )( "PatchData without free vertices.", MsqError::INVALID_ARG ); 00128 return false; 00129 } 00130 00131 if( type != ObjectiveFunction::CALCULATE && type != ObjectiveFunction::TEMPORARY ) changed = true; 00132 00133 if( constant ) 00134 { 00135 val = 1.0; 00136 return !return_false; 00137 } 00138 00139 val = 0.0; 00140 for( size_t i = 0; i < pd.num_nodes(); ++i ) 00141 { 00142 const MsqVertex& v = pd.vertex_by_index( i ); 00143 val += linearGrad[0] * v[0] + linearGrad[1] * v[1] + linearGrad[2] * v[2]; 00144 } 00145 00146 return !return_false; 00147 } 00148 00149 void NumericalOFTest::setUp() 00150 { 00151 MsqPrintError err( std::cout ); 00152 00153 // Create a triangle mesh with three free vertices 00154 const double coords[] = { 1, 1, 0, 2, 1, 0, 3, 1, 0, 2, 2, 0, 1, 3, 0, 1, 2, 0 }; 00155 const bool fixed_vtx[] = { true, false, true, false, true, false }; 00156 const size_t tri_conn[] = { 0, 1, 5, 1, 2, 3, 3, 4, 5, 1, 3, 5 }; 00157 pd.fill( 6, coords, 4, TRIANGLE, tri_conn, fixed_vtx, err ); 00158 ASSERT_NO_ERROR( err ); 00159 } 00160 00161 void NumericalOFTest::test_gradient_values( bool constant ) 00162 { 00163 NumericalTestOF func( false, false, constant ); 00164 MsqPrintError err( std::cout ); 00165 double value; 00166 vector< Vector3D > gradient; 00167 00168 bool rval = func.evaluate_with_gradient( ObjectiveFunction::CALCULATE, pd, value, gradient, err ); 00169 ASSERT_NO_ERROR( err ); 00170 CPPUNIT_ASSERT( rval ); 00171 00172 Vector3D expected = constant ? Vector3D( 0, 0, 0 ) : func.linearGrad; 00173 CPPUNIT_ASSERT( gradient.size() == pd.num_free_vertices() ); 00174 for( vector< Vector3D >::iterator i = gradient.begin(); i != gradient.end(); ++i ) 00175 CPPUNIT_ASSERT_VECTORS_EQUAL( expected, *i, EPSILON ); 00176 } 00177 00178 void NumericalOFTest::test_handles_eval_failure() 00179 { 00180 MsqError err; 00181 NumericalTestOF func( true, false, true ); 00182 double value; 00183 vector< Vector3D > gradient; 00184 00185 func.evaluate_with_gradient( ObjectiveFunction::CALCULATE, pd, value, gradient, err ); 00186 CPPUNIT_ASSERT( err ); 00187 } 00188 00189 void NumericalOFTest::test_handles_eval_false() 00190 { 00191 MsqError err; 00192 NumericalTestOF func( false, true, true ); 00193 double value; 00194 vector< Vector3D > gradient; 00195 00196 bool rval = func.evaluate_with_gradient( ObjectiveFunction::CALCULATE, pd, value, gradient, err ); 00197 ASSERT_NO_ERROR( err ); 00198 CPPUNIT_ASSERT( !rval ); 00199 } 00200 00201 void NumericalOFTest::test_changed() 00202 { 00203 MsqPrintError err( cout ); 00204 NumericalTestOF func( false, false, true ); 00205 double value; 00206 vector< Vector3D > gradient; 00207 bool rval; 00208 00209 func.changed = false; 00210 rval = func.evaluate_with_gradient( ObjectiveFunction::SAVE, pd, value, gradient, err ); 00211 ASSERT_NO_ERROR( err ); 00212 CPPUNIT_ASSERT( rval ); 00213 CPPUNIT_ASSERT( func.changed ); 00214 00215 func.changed = false; 00216 rval = func.evaluate_with_gradient( ObjectiveFunction::UPDATE, pd, value, gradient, err ); 00217 ASSERT_NO_ERROR( err ); 00218 CPPUNIT_ASSERT( rval ); 00219 CPPUNIT_ASSERT( func.changed ); 00220 } 00221 00222 void NumericalOFTest::test_unchanged() 00223 { 00224 MsqPrintError err( cout ); 00225 NumericalTestOF func( false, false, true ); 00226 double value; 00227 vector< Vector3D > gradient; 00228 bool rval; 00229 00230 func.changed = false; 00231 rval = func.evaluate_with_gradient( ObjectiveFunction::TEMPORARY, pd, value, gradient, err ); 00232 ASSERT_NO_ERROR( err ); 00233 CPPUNIT_ASSERT( rval ); 00234 CPPUNIT_ASSERT( !func.changed ); 00235 } 00236 00237 void NumericalOFTest::test_Hessian_fails() 00238 { 00239 MsqError err; 00240 NumericalTestOF func( false, false, true ); 00241 double value; 00242 vector< Vector3D > gradient; 00243 MsqHessian Hessian; 00244 00245 func.evaluate_with_Hessian( ObjectiveFunction::CALCULATE, pd, value, gradient, Hessian, err ); 00246 CPPUNIT_ASSERT( err ); 00247 }
