MOAB: Mesh Oriented datABase
(version 5.3.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2009 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2009) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file MappingFunctionTest.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "UnitUtil.hpp" 00034 #include "LinearTetrahedron.hpp" 00035 #include "LinearTriangle.hpp" 00036 #include "PatchData.hpp" 00037 #include "IdealElements.hpp" 00038 #include <algorithm> 00039 00040 using namespace MBMesquite; 00041 00042 class MappingFunctionTest : public CppUnit::TestFixture 00043 { 00044 private: 00045 CPPUNIT_TEST_SUITE( MappingFunctionTest ); 00046 CPPUNIT_TEST( test_jacobian_2d ); 00047 CPPUNIT_TEST( test_jacobian_3d ); 00048 CPPUNIT_TEST( test_ideal_2d ); 00049 CPPUNIT_TEST( test_ideal_3d ); 00050 CPPUNIT_TEST_SUITE_END(); 00051 00052 LinearTriangle tri; 00053 LinearTetrahedron tet; 00054 00055 public: 00056 void test_jacobian_2d(); 00057 void test_jacobian_3d(); 00058 void test_ideal_2d(); 00059 void test_ideal_3d(); 00060 00061 MsqMatrix< 3, 2 > calculate_jacobian_2d( Sample s, const Vector3D* coords ); 00062 MsqMatrix< 3, 3 > calculate_jacobian_3d( Sample s, const Vector3D* coords ); 00063 }; 00064 00065 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( MappingFunctionTest, "MappingFunctionTest" ); 00066 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( MappingFunctionTest, "Unit" ); 00067 00068 void MappingFunctionTest::test_jacobian_2d() 00069 { 00070 MsqError err; 00071 PatchData pd; 00072 const size_t conn[3] = { 0, 1, 2 }; 00073 const bool fixed[3] = { false, false, false }; 00074 const double coords[3][3] = { { 0.5, 0.5, 0.0 }, { 2.0, 0.2, 0.0 }, { 0.7, 0.8, 0.0 } }; 00075 00076 size_t indices_exp[3], indices_act[3], num_exp, num_act; 00077 MsqVector< 2 > coeff_exp[3], coeff_act[3]; 00078 MsqMatrix< 3, 2 > J_exp, J_act; 00079 for( int r = 0; r < 3; ++r ) 00080 { 00081 const double verts[] = { coords[r][0], 00082 coords[r][1], 00083 coords[r][2], 00084 coords[( r + 1 ) % 3][0], 00085 coords[( r + 1 ) % 3][1], 00086 coords[( r + 1 ) % 3][2], 00087 coords[( r + 2 ) % 3][0], 00088 coords[( r + 2 ) % 3][1], 00089 coords[( r + 2 ) % 3][2] }; 00090 pd.fill( 3, verts, 1, TRIANGLE, conn, fixed, err ); 00091 ASSERT_NO_ERROR( err ); 00092 00093 for( int d = 0; d < 3; ++d ) 00094 { 00095 int n = ( d == 2 ) ? 1 : 3; 00096 for( int s = 0; s < n; ++s ) 00097 { 00098 tri.MappingFunction2D::jacobian( pd, 0, NodeSet(), Sample( d, s ), indices_act, coeff_act, num_act, 00099 J_act, err ); 00100 ASSERT_NO_ERROR( err ); 00101 CPPUNIT_ASSERT( num_act <= 3 ); 00102 CPPUNIT_ASSERT( num_act > 0 ); 00103 00104 tri.derivatives( Sample( d, s ), NodeSet(), indices_exp, coeff_exp, num_exp, err ); 00105 ASSERT_NO_ERROR( err ); 00106 CPPUNIT_ASSERT_EQUAL( num_exp, num_act ); 00107 00108 J_exp = MsqMatrix< 3, 2 >( 0.0 ); // zero 00109 for( size_t j = 0; j < num_exp; ++j ) 00110 { 00111 size_t idx = pd.element_by_index( 0 ).get_vertex_index_array()[j]; 00112 size_t k = std::find( indices_act, indices_act + num_act, idx ) - indices_act; 00113 CPPUNIT_ASSERT( k < num_act ); // found 00114 ASSERT_MATRICES_EQUAL( coeff_exp[j], coeff_act[k], 1e-10 ); 00115 00116 J_exp += MsqVector< 3 >( pd.vertex_by_index( idx ).to_array() ) * transpose( coeff_exp[j] ); 00117 } 00118 00119 ASSERT_MATRICES_EQUAL( J_exp, J_act, 1e-6 ); 00120 } 00121 } 00122 } 00123 } 00124 00125 void MappingFunctionTest::test_jacobian_3d() 00126 { 00127 MsqError err; 00128 PatchData pd; 00129 const size_t conn[4] = { 0, 1, 2, 3 }; 00130 const bool fixed[4] = { false, false, false, false }; 00131 const double coords[4][3] = { { 0.5, 0.5, 0.0 }, { 2.0, 0.2, 0.0 }, { 0.7, 0.8, 0.0 }, { 0.6, 1.1, 13. } }; 00132 00133 size_t indices_exp[4], indices_act[4], num_exp, num_act; 00134 MsqVector< 3 > coeff_exp[4], coeff_act[4]; 00135 MsqMatrix< 3, 3 > J_exp, J_act; 00136 for( int r = 0; r < 3; ++r ) 00137 { 00138 const double verts[] = { coords[r][0], 00139 coords[r][1], 00140 coords[r][2], 00141 coords[( r + 1 ) % 3][0], 00142 coords[( r + 1 ) % 3][1], 00143 coords[( r + 1 ) % 3][2], 00144 coords[( r + 2 ) % 3][0], 00145 coords[( r + 2 ) % 3][1], 00146 coords[( r + 2 ) % 3][2], 00147 coords[3][0], 00148 coords[3][1], 00149 coords[3][2] }; 00150 pd.fill( 4, verts, 1, TETRAHEDRON, conn, fixed, err ); 00151 ASSERT_NO_ERROR( err ); 00152 00153 for( int d = 0; d < 3; ++d ) 00154 { 00155 int n = ( d == 3 ) ? 1 : ( d == 1 ) ? 6 : 4; 00156 for( int s = 0; s < n; ++s ) 00157 { 00158 tet.MappingFunction3D::jacobian( pd, 0, NodeSet(), Sample( d, s ), indices_act, coeff_act, num_act, 00159 J_act, err ); 00160 ASSERT_NO_ERROR( err ); 00161 CPPUNIT_ASSERT( num_act <= 4 ); 00162 CPPUNIT_ASSERT( num_act > 0 ); 00163 00164 tet.derivatives( Sample( d, s ), NodeSet(), indices_exp, coeff_exp, num_exp, err ); 00165 ASSERT_NO_ERROR( err ); 00166 CPPUNIT_ASSERT_EQUAL( num_exp, num_act ); 00167 00168 J_exp = MsqMatrix< 3, 3 >( 0.0 ); // zero 00169 for( size_t j = 0; j < num_exp; ++j ) 00170 { 00171 size_t idx = pd.element_by_index( 0 ).get_vertex_index_array()[j]; 00172 size_t k = std::find( indices_act, indices_act + num_act, idx ) - indices_act; 00173 CPPUNIT_ASSERT( k < num_act ); // found 00174 ASSERT_MATRICES_EQUAL( coeff_exp[j], coeff_act[k], 1e-10 ); 00175 00176 J_exp += MsqVector< 3 >( pd.vertex_by_index( idx ).to_array() ) * transpose( coeff_exp[j] ); 00177 } 00178 00179 ASSERT_MATRICES_EQUAL( J_exp, J_act, 1e-6 ); 00180 } 00181 } 00182 } 00183 } 00184 00185 void MappingFunctionTest::test_ideal_2d() 00186 { 00187 MsqError err; 00188 MsqMatrix< 3, 2 > W_prime; 00189 tri.MappingFunction2D::ideal( Sample( 2, 0 ), W_prime, err ); 00190 ASSERT_NO_ERROR( err ); 00191 00192 // for this test that everything is in the xy-plane 00193 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, W_prime( 2, 0 ), 1e-12 ); 00194 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, W_prime( 2, 1 ), 1e-12 ); 00195 MsqMatrix< 2, 2 > W( W_prime.data() ); 00196 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( W ), 1e-6 ); 00197 00198 const Vector3D* verts = unit_edge_element( TRIANGLE ); 00199 CPPUNIT_ASSERT( verts ); 00200 00201 size_t indices[3], num; 00202 MsqVector< 2 > coeff[3]; 00203 tri.derivatives( Sample( 2, 0 ), NodeSet(), indices, coeff, num, err ); 00204 ASSERT_NO_ERROR( err ); 00205 00206 MsqMatrix< 3, 2 > J_exp( 0.0 ); // zero 00207 for( size_t j = 0; j < num; ++j ) 00208 J_exp += MsqVector< 3 >( verts[j].to_array() ) * transpose( coeff[j] ); 00209 00210 // for this test that everything is in the xy-plane 00211 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, W_prime( 2, 0 ), 1e-12 ); 00212 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, W_prime( 2, 1 ), 1e-12 ); 00213 MsqMatrix< 2, 2 > W_exp( J_exp.data() ); 00214 W_exp /= sqrt( det( W_exp ) ); 00215 00216 // Matrices should be a rotation of each other. 00217 // First, calculate tentative rotation matrix 00218 MsqMatrix< 2, 2 > R = inverse( W_exp ) * W; 00219 // next check that it is a rotation 00220 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( R ), 1e-6 ); // no scaling 00221 ASSERT_MATRICES_EQUAL( transpose( R ), inverse( R ), 1e-6 ); // orthogonal 00222 } 00223 00224 void MappingFunctionTest::test_ideal_3d() 00225 { 00226 MsqError err; 00227 MsqMatrix< 3, 3 > J; 00228 tet.MappingFunction3D::ideal( Sample( 3, 0 ), J, err ); 00229 ASSERT_NO_ERROR( err ); 00230 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( J ), 1e-6 ); 00231 00232 const Vector3D* verts = unit_edge_element( TETRAHEDRON ); 00233 CPPUNIT_ASSERT( verts ); 00234 00235 size_t indices[4], num; 00236 MsqVector< 3 > coeff[4]; 00237 tet.derivatives( Sample( 2, 0 ), NodeSet(), indices, coeff, num, err ); 00238 ASSERT_NO_ERROR( err ); 00239 00240 MsqMatrix< 3, 3 > J_exp( 0.0 ); // zero 00241 for( size_t j = 0; j < num; ++j ) 00242 J_exp += MsqVector< 3 >( verts[j].to_array() ) * transpose( coeff[j] ); 00243 J_exp /= MBMesquite::cbrt( det( J_exp ) ); 00244 00245 // Matrices should be a rotation of each other. 00246 // First, calculate tentative rotation matrix 00247 MsqMatrix< 3, 3 > R = inverse( J_exp ) * J; 00248 // next check that it is a rotation 00249 CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( R ), 1e-6 ); // no scaling 00250 ASSERT_MATRICES_EQUAL( transpose( R ), inverse( R ), 1e-6 ); // orthogonal 00251 }
