MOAB: Mesh Oriented datABase
(version 5.2.1)
Public Member Functions | |
void | test_jacobian_2d () |
void | test_jacobian_3d () |
void | test_ideal_2d () |
void | test_ideal_3d () |
MsqMatrix< 3, 2 > | calculate_jacobian_2d (Sample s, const Vector3D *coords) |
MsqMatrix< 3, 3 > | calculate_jacobian_3d (Sample s, const Vector3D *coords) |
Private Member Functions | |
CPPUNIT_TEST_SUITE (MappingFunctionTest) | |
CPPUNIT_TEST (test_jacobian_2d) | |
CPPUNIT_TEST (test_jacobian_3d) | |
CPPUNIT_TEST (test_ideal_2d) | |
CPPUNIT_TEST (test_ideal_3d) | |
CPPUNIT_TEST_SUITE_END () | |
Private Attributes | |
LinearTriangle | tri |
LinearTetrahedron | tet |
Definition at line 42 of file MappingFunctionTest.cpp.
MsqMatrix< 3, 2 > MappingFunctionTest::calculate_jacobian_2d | ( | Sample | s, |
const Vector3D * | coords | ||
MsqMatrix< 3, 3 > MappingFunctionTest::calculate_jacobian_3d | ( | Sample | s, |
MappingFunctionTest::CPPUNIT_TEST | ( | test_jacobian_2d | ) | [private] |
MappingFunctionTest::CPPUNIT_TEST | ( | test_jacobian_3d | ) | [private] |
MappingFunctionTest::CPPUNIT_TEST | ( | test_ideal_2d | ) | [private] |
MappingFunctionTest::CPPUNIT_TEST | ( | test_ideal_3d | ) | [private] |
MappingFunctionTest::CPPUNIT_TEST_SUITE | ( | MappingFunctionTest | ) | [private] |
MappingFunctionTest::CPPUNIT_TEST_SUITE_END | ( | ) | [private] |
void MappingFunctionTest::test_ideal_2d | ( | ) |
Definition at line 185 of file MappingFunctionTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::MsqMatrix< R, C >::data(), MBMesquite::det(), MBMesquite::inverse(), moab::R, MBMesquite::transpose(), MBMesquite::TRIANGLE, and MBMesquite::unit_edge_element().
{ MsqError err; MsqMatrix< 3, 2 > W_prime; tri.MappingFunction2D::ideal( Sample( 2, 0 ), W_prime, err ); ASSERT_NO_ERROR( err ); // for this test that everything is in the xy-plane CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, W_prime( 2, 0 ), 1e-12 ); CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, W_prime( 2, 1 ), 1e-12 ); MsqMatrix< 2, 2 > W( W_prime.data() ); CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( W ), 1e-6 ); const Vector3D* verts = unit_edge_element( TRIANGLE ); CPPUNIT_ASSERT( verts ); size_t indices[3], num; MsqVector< 2 > coeff[3]; tri.derivatives( Sample( 2, 0 ), NodeSet(), indices, coeff, num, err ); ASSERT_NO_ERROR( err ); MsqMatrix< 3, 2 > J_exp( 0.0 ); // zero for( size_t j = 0; j < num; ++j ) J_exp += MsqVector< 3 >( verts[j].to_array() ) * transpose( coeff[j] ); // for this test that everything is in the xy-plane CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, W_prime( 2, 0 ), 1e-12 ); CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, W_prime( 2, 1 ), 1e-12 ); MsqMatrix< 2, 2 > W_exp( J_exp.data() ); W_exp /= sqrt( det( W_exp ) ); // Matrices should be a rotation of each other. // First, calculate tentative rotation matrix MsqMatrix< 2, 2 > R = inverse( W_exp ) * W; // next check that it is a rotation CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( R ), 1e-6 ); // no scaling ASSERT_MATRICES_EQUAL( transpose( R ), inverse( R ), 1e-6 ); // orthogonal }
void MappingFunctionTest::test_ideal_3d | ( | ) |
Definition at line 224 of file MappingFunctionTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, MBMesquite::cbrt(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::det(), MBMesquite::inverse(), moab::R, MBMesquite::TETRAHEDRON, MBMesquite::transpose(), and MBMesquite::unit_edge_element().
{ MsqError err; MsqMatrix< 3, 3 > J; tet.MappingFunction3D::ideal( Sample( 3, 0 ), J, err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( J ), 1e-6 ); const Vector3D* verts = unit_edge_element( TETRAHEDRON ); CPPUNIT_ASSERT( verts ); size_t indices[4], num; MsqVector< 3 > coeff[4]; tet.derivatives( Sample( 2, 0 ), NodeSet(), indices, coeff, num, err ); ASSERT_NO_ERROR( err ); MsqMatrix< 3, 3 > J_exp( 0.0 ); // zero for( size_t j = 0; j < num; ++j ) J_exp += MsqVector< 3 >( verts[j].to_array() ) * transpose( coeff[j] ); J_exp /= MBMesquite::cbrt( det( J_exp ) ); // Matrices should be a rotation of each other. // First, calculate tentative rotation matrix MsqMatrix< 3, 3 > R = inverse( J_exp ) * J; // next check that it is a rotation CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, det( R ), 1e-6 ); // no scaling ASSERT_MATRICES_EQUAL( transpose( R ), inverse( R ), 1e-6 ); // orthogonal }
Definition at line 68 of file MappingFunctionTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, conn, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::PatchData::fill(), fixed, MBMesquite::MsqMeshEntity::get_vertex_index_array(), n, MBMesquite::Vector3D::to_array(), MBMesquite::transpose(), MBMesquite::TRIANGLE, and MBMesquite::PatchData::vertex_by_index().
{ MsqError err; PatchData pd; const size_t conn[3] = { 0, 1, 2 }; const bool fixed[3] = { false, false, false }; const double coords[3][3] = { { 0.5, 0.5, 0.0 }, { 2.0, 0.2, 0.0 }, { 0.7, 0.8, 0.0 } }; size_t indices_exp[3], indices_act[3], num_exp, num_act; MsqVector< 2 > coeff_exp[3], coeff_act[3]; MsqMatrix< 3, 2 > J_exp, J_act; for( int r = 0; r < 3; ++r ) { const double verts[] = { coords[r][0], coords[r][1], coords[r][2], coords[( r + 1 ) % 3][0], coords[( r + 1 ) % 3][1], coords[( r + 1 ) % 3][2], coords[( r + 2 ) % 3][0], coords[( r + 2 ) % 3][1], coords[( r + 2 ) % 3][2] }; pd.fill( 3, verts, 1, TRIANGLE, conn, fixed, err ); ASSERT_NO_ERROR( err ); for( int d = 0; d < 3; ++d ) { int n = ( d == 2 ) ? 1 : 3; for( int s = 0; s < n; ++s ) { tri.MappingFunction2D::jacobian( pd, 0, NodeSet(), Sample( d, s ), indices_act, coeff_act, num_act, J_act, err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT( num_act <= 3 ); CPPUNIT_ASSERT( num_act > 0 ); tri.derivatives( Sample( d, s ), NodeSet(), indices_exp, coeff_exp, num_exp, err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_EQUAL( num_exp, num_act ); J_exp = MsqMatrix< 3, 2 >( 0.0 ); // zero for( size_t j = 0; j < num_exp; ++j ) { size_t idx = pd.element_by_index( 0 ).get_vertex_index_array()[j]; size_t k = std::find( indices_act, indices_act + num_act, idx ) - indices_act; CPPUNIT_ASSERT( k < num_act ); // found ASSERT_MATRICES_EQUAL( coeff_exp[j], coeff_act[k], 1e-10 ); J_exp += MsqVector< 3 >( pd.vertex_by_index( idx ).to_array() ) * transpose( coeff_exp[j] ); } ASSERT_MATRICES_EQUAL( J_exp, J_act, 1e-6 ); } } } }
Definition at line 125 of file MappingFunctionTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, conn, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::PatchData::fill(), fixed, MBMesquite::MsqMeshEntity::get_vertex_index_array(), n, MBMesquite::TETRAHEDRON, MBMesquite::Vector3D::to_array(), MBMesquite::transpose(), and MBMesquite::PatchData::vertex_by_index().
{ MsqError err; PatchData pd; const size_t conn[4] = { 0, 1, 2, 3 }; const bool fixed[4] = { false, false, false, false }; const double coords[4][3] = { { 0.5, 0.5, 0.0 }, { 2.0, 0.2, 0.0 }, { 0.7, 0.8, 0.0 }, { 0.6, 1.1, 13. } }; size_t indices_exp[4], indices_act[4], num_exp, num_act; MsqVector< 3 > coeff_exp[4], coeff_act[4]; MsqMatrix< 3, 3 > J_exp, J_act; for( int r = 0; r < 3; ++r ) { const double verts[] = { coords[r][0], coords[r][1], coords[r][2], coords[( r + 1 ) % 3][0], coords[( r + 1 ) % 3][1], coords[( r + 1 ) % 3][2], coords[( r + 2 ) % 3][0], coords[( r + 2 ) % 3][1], coords[( r + 2 ) % 3][2], coords[3][0], coords[3][1], coords[3][2] }; pd.fill( 4, verts, 1, TETRAHEDRON, conn, fixed, err ); ASSERT_NO_ERROR( err ); for( int d = 0; d < 3; ++d ) { int n = ( d == 3 ) ? 1 : ( d == 1 ) ? 6 : 4; for( int s = 0; s < n; ++s ) { tet.MappingFunction3D::jacobian( pd, 0, NodeSet(), Sample( d, s ), indices_act, coeff_act, num_act, J_act, err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT( num_act <= 4 ); CPPUNIT_ASSERT( num_act > 0 ); tet.derivatives( Sample( d, s ), NodeSet(), indices_exp, coeff_exp, num_exp, err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_EQUAL( num_exp, num_act ); J_exp = MsqMatrix< 3, 3 >( 0.0 ); // zero for( size_t j = 0; j < num_exp; ++j ) { size_t idx = pd.element_by_index( 0 ).get_vertex_index_array()[j]; size_t k = std::find( indices_act, indices_act + num_act, idx ) - indices_act; CPPUNIT_ASSERT( k < num_act ); // found ASSERT_MATRICES_EQUAL( coeff_exp[j], coeff_act[k], 1e-10 ); J_exp += MsqVector< 3 >( pd.vertex_by_index( idx ).to_array() ) * transpose( coeff_exp[j] ); } ASSERT_MATRICES_EQUAL( J_exp, J_act, 1e-6 ); } } } }
LinearTetrahedron MappingFunctionTest::tet [private] |
Definition at line 53 of file MappingFunctionTest.cpp.
LinearTriangle MappingFunctionTest::tri [private] |
Definition at line 52 of file MappingFunctionTest.cpp.
