MOAB: Mesh Oriented datABase
(version 5.2.1)
Base type for per-vertex quality metrics. More...
#include <VertexQM.hpp>
Public Member Functions | |
virtual MESQUITE_EXPORT | ~VertexQM () |
virtual MESQUITE_EXPORT MetricType | get_metric_type () const |
virtual MESQUITE_EXPORT void | get_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err) |
Returns list of vertex indices in PatchData. | |
Static Public Member Functions | |
static MESQUITE_EXPORT void | get_vertex_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err) |
static MESQUITE_EXPORT void | get_vertex_corner_handles (PatchData &pd, size_t vertex_index, std::vector< size_t > &handles_out, MsqError &err) |
Definition at line 42 of file VertexQM.hpp.
MBMesquite::VertexQM::~VertexQM | ( | ) | [virtual] |
Definition at line 40 of file VertexQM.cpp.
void MBMesquite::VertexQM::get_evaluations | ( | PatchData & | pd, |
std::vector< size_t > & | handles, | ||
bool | free_vertices_only, | ||
MsqError & | err | ||
) | [virtual] |
Implements MBMesquite::QualityMetric.
Definition at line 42 of file VertexQM.cpp.
References get_vertex_evaluations().
Referenced by PMeanPTemplateTest::check_result(), and PMeanPMetricTest::test_get_vertex_evaluations().
{ get_vertex_evaluations( pd, handles, free_vertices_only, err ); }
virtual MESQUITE_EXPORT MetricType MBMesquite::VertexQM::get_metric_type | ( | ) | const [inline, virtual] |
Definition at line 47 of file VertexQM.hpp.
References MBMesquite::QualityMetric::VERTEX_BASED.
Referenced by PMeanPMetricTest::test_get_metric_type().
{ return VERTEX_BASED; }
void MBMesquite::VertexQM::get_vertex_corner_handles | ( | PatchData & | pd, |
size_t | vertex_index, | ||
std::vector< size_t > & | handles_out, | ||
) | [static] |
Definition at line 65 of file VertexQM.cpp.
References MBMesquite::PatchData::element_by_index(), MBMesquite::PatchData::get_vertex_element_adjacencies(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::ElemSampleQM::handle(), MSQ_ERRRTN, and MBMesquite::MsqMeshEntity::node_count().
Referenced by MBMesquite::VertexMaxQM::evaluate(), MBMesquite::VertexPMeanP::evaluate(), MBMesquite::VertexPMeanP::evaluate_with_gradient(), MBMesquite::VertexPMeanP::evaluate_with_Hessian(), MBMesquite::VertexPMeanP::evaluate_with_Hessian_diagonal(), MBMesquite::VertexMaxQM::evaluate_with_indices(), and MBMesquite::VertexPMeanP::evaluate_with_indices().
{ size_t len; const size_t* elems = pd.get_vertex_element_adjacencies( vtx_idx, len, err );MSQ_ERRRTN( err ); handles.resize( len ); for( size_t i = 0; i < len; ++i ) { const MsqMeshEntity& elem = pd.element_by_index( elems[i] ); const size_t* verts = elem.get_vertex_index_array(); const size_t* ptr = std::find( verts, verts + elem.node_count(), vtx_idx ); unsigned idx = ptr - verts; handles[i] = ElemSampleQM::handle( Sample( 0, idx ), elems[i] ); } }
void MBMesquite::VertexQM::get_vertex_evaluations | ( | PatchData & | pd, |
) | [static] |
Definition at line 47 of file VertexQM.cpp.
References MBMesquite::MsqVertex::get_flags(), MBMesquite::MsqVertex::MSQ_PATCH_FIXED, MBMesquite::PatchData::num_free_vertices(), MBMesquite::PatchData::num_nodes(), and MBMesquite::PatchData::vertex_by_index().
Referenced by get_evaluations().
{ if( free_vertices_only ) { handles.resize( pd.num_free_vertices() ); for( size_t i = 0; i < pd.num_free_vertices(); ++i ) handles[i] = i; } else { handles.clear(); handles.reserve( pd.num_nodes() ); for( size_t i = 0; i < pd.num_nodes(); ++i ) if( !( pd.vertex_by_index( i ).get_flags() & MsqVertex::MSQ_PATCH_FIXED ) ) handles.push_back( i ); } }
