MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retian certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file NodeSetTest.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "NodeSet.hpp" 00034 #include "UnitUtil.hpp" 00035 00036 using namespace MBMesquite; 00037 using namespace std; 00038 00039 class NodeSetTest : public CppUnit::TestFixture 00040 { 00041 private: 00042 CPPUNIT_TEST_SUITE( NodeSetTest ); 00043 CPPUNIT_TEST( test_init ); 00044 CPPUNIT_TEST( test_clear ); 00045 CPPUNIT_TEST( test_set_get_clear_simple ); 00046 CPPUNIT_TEST( test_set_get_clear_dim ); 00047 CPPUNIT_TEST( test_set_node ); 00048 CPPUNIT_TEST( test_clear_node ); 00049 CPPUNIT_TEST( test_num_nodes ); 00050 CPPUNIT_TEST( test_have_any ); 00051 CPPUNIT_TEST( test_set_all ); 00052 CPPUNIT_TEST( test_clear_all ); 00053 CPPUNIT_TEST( test_num_before ); 00054 CPPUNIT_TEST_SUITE_END(); 00055 00056 public: 00057 void test_init(); 00058 void test_clear(); 00059 void test_set_get_clear_simple(); 00060 void test_set_get_clear_dim(); 00061 void test_set_node(); 00062 void test_clear_node(); 00063 void test_num_nodes(); 00064 void test_have_any(); 00065 void test_set_all(); 00066 void test_clear_all(); 00067 void test_num_before(); 00068 }; 00069 00070 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( NodeSetTest, "NodeSetTest" ); 00071 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( NodeSetTest, "Unit" ); 00072 00073 void NodeSetTest::test_init() 00074 { 00075 NodeSet set; 00076 CPPUNIT_ASSERT( !set.get_bits() ); 00077 } 00078 00079 void NodeSetTest::test_clear() 00080 { 00081 NodeSet set; 00082 set.set_corner_node( 1 ); 00083 set.clear(); 00084 CPPUNIT_ASSERT( !set.get_bits() ); 00085 set.set_mid_edge_node( 2 ); 00086 set.clear(); 00087 CPPUNIT_ASSERT( !set.get_bits() ); 00088 set.set_mid_region_node(); 00089 set.clear(); 00090 CPPUNIT_ASSERT( !set.get_bits() ); 00091 } 00092 00093 void NodeSetTest::test_set_get_clear_simple() 00094 { 00095 NodeSet set; 00096 for( unsigned i = 0; i < NodeSet::NUM_CORNER_BITS; ++i ) 00097 { 00098 CPPUNIT_ASSERT( !set.corner_node( i ) ); 00099 set.set_corner_node( i ); 00100 CPPUNIT_ASSERT( set.corner_node( i ) ); 00101 set.clear_corner_node( i ); 00102 CPPUNIT_ASSERT( !set.corner_node( i ) ); 00103 } 00104 for( unsigned i = 0; i < NodeSet::NUM_EDGE_BITS; ++i ) 00105 { 00106 CPPUNIT_ASSERT( !set.mid_edge_node( i ) ); 00107 set.set_mid_edge_node( i ); 00108 CPPUNIT_ASSERT( set.mid_edge_node( i ) ); 00109 set.clear_mid_edge_node( i ); 00110 CPPUNIT_ASSERT( !set.mid_edge_node( i ) ); 00111 } 00112 for( unsigned i = 0; i < NodeSet::NUM_FACE_BITS; ++i ) 00113 { 00114 CPPUNIT_ASSERT( !set.mid_face_node( i ) ); 00115 set.set_mid_face_node( i ); 00116 CPPUNIT_ASSERT( set.mid_face_node( i ) ); 00117 set.clear_mid_face_node( i ); 00118 CPPUNIT_ASSERT( !set.mid_face_node( i ) ); 00119 } 00120 for( unsigned i = 0; i < NodeSet::NUM_REGION_BITS; ++i ) 00121 { 00122 CPPUNIT_ASSERT( !set.mid_region_node( i ) ); 00123 set.set_mid_region_node( i ); 00124 CPPUNIT_ASSERT( set.mid_region_node( i ) ); 00125 set.clear_mid_region_node( i ); 00126 CPPUNIT_ASSERT( !set.mid_region_node( i ) ); 00127 } 00128 } 00129 00130 void NodeSetTest::test_set_get_clear_dim() 00131 { 00132 NodeSet set; 00133 for( unsigned i = 0; i < NodeSet::NUM_CORNER_BITS; ++i ) 00134 { 00135 CPPUNIT_ASSERT( !set.node( Sample( 0, i ) ) ); 00136 set.set_node( Sample( 0, i ) ); 00137 CPPUNIT_ASSERT( set.node( Sample( 0, i ) ) ); 00138 set.clear_node( Sample( 0, i ) ); 00139 CPPUNIT_ASSERT( !set.node( Sample( 0, i ) ) ); 00140 } 00141 for( unsigned i = 0; i < NodeSet::NUM_EDGE_BITS; ++i ) 00142 { 00143 CPPUNIT_ASSERT( !set.node( Sample( 1, i ) ) ); 00144 set.set_node( Sample( 1, i ) ); 00145 CPPUNIT_ASSERT( set.node( Sample( 1, i ) ) ); 00146 set.clear_node( Sample( 1, i ) ); 00147 CPPUNIT_ASSERT( !set.node( Sample( 1, i ) ) ); 00148 } 00149 for( unsigned i = 0; i < NodeSet::NUM_FACE_BITS; ++i ) 00150 { 00151 CPPUNIT_ASSERT( !set.node( Sample( 2, i ) ) ); 00152 set.set_node( Sample( 2, i ) ); 00153 CPPUNIT_ASSERT( set.node( Sample( 2, i ) ) ); 00154 set.clear_node( Sample( 2, i ) ); 00155 CPPUNIT_ASSERT( !set.node( Sample( 2, i ) ) ); 00156 } 00157 for( unsigned i = 0; i < NodeSet::NUM_REGION_BITS; ++i ) 00158 { 00159 CPPUNIT_ASSERT( !set.node( Sample( 3, i ) ) ); 00160 set.set_node( Sample( 3, i ) ); 00161 CPPUNIT_ASSERT( set.node( Sample( 3, i ) ) ); 00162 set.clear_node( Sample( 3, i ) ); 00163 CPPUNIT_ASSERT( !set.node( Sample( 3, i ) ) ); 00164 } 00165 } 00166 00167 void NodeSetTest::test_set_node() 00168 { 00169 NodeSet set; 00170 for( unsigned i = 0; i < NodeSet::NUM_CORNER_BITS; ++i ) 00171 { 00172 set.set_corner_node( i ); 00173 CPPUNIT_ASSERT_EQUAL( 1u << ( NodeSet::CORNER_OFFSET + i ), set.get_bits() ); 00174 set.clear(); 00175 } 00176 for( unsigned i = 0; i < NodeSet::NUM_EDGE_BITS; ++i ) 00177 { 00178 set.set_mid_edge_node( i ); 00179 CPPUNIT_ASSERT_EQUAL( 1u << ( NodeSet::EDGE_OFFSET + i ), set.get_bits() ); 00180 set.clear(); 00181 } 00182 for( unsigned i = 0; i < NodeSet::NUM_FACE_BITS; ++i ) 00183 { 00184 set.set_mid_face_node( i ); 00185 CPPUNIT_ASSERT_EQUAL( 1u << ( NodeSet::FACE_OFFSET + i ), set.get_bits() ); 00186 set.clear(); 00187 } 00188 for( unsigned i = 0; i < NodeSet::NUM_REGION_BITS; ++i ) 00189 { 00190 set.set_mid_region_node( i ); 00191 CPPUNIT_ASSERT_EQUAL( 1u << ( NodeSet::REGION_OFFSET + i ), set.get_bits() ); 00192 set.clear(); 00193 } 00194 } 00195 00196 void NodeSetTest::test_clear_node() 00197 { 00198 const EntityTopology type = HEXAHEDRON; 00199 NodeSet set; 00200 NodeSet::BitSet expected; 00201 for( unsigned i = 0; i < TopologyInfo::corners( type ); ++i ) 00202 { 00203 set.set_all_nodes( type ); 00204 expected = set.get_bits() & ~( 1u << ( NodeSet::CORNER_OFFSET + i ) ); 00205 set.clear_corner_node( i ); 00206 CPPUNIT_ASSERT_EQUAL( expected, set.get_bits() ); 00207 } 00208 for( unsigned i = 0; i < TopologyInfo::edges( type ); ++i ) 00209 { 00210 set.set_all_nodes( type ); 00211 expected = set.get_bits() & ~( 1u << ( NodeSet::EDGE_OFFSET + i ) ); 00212 set.clear_mid_edge_node( i ); 00213 CPPUNIT_ASSERT_EQUAL( expected, set.get_bits() ); 00214 } 00215 for( unsigned i = 0; i < TopologyInfo::faces( type ); ++i ) 00216 { 00217 set.set_all_nodes( type ); 00218 expected = set.get_bits() & ~( 1u << ( NodeSet::FACE_OFFSET + i ) ); 00219 set.clear_mid_face_node( i ); 00220 CPPUNIT_ASSERT_EQUAL( expected, set.get_bits() ); 00221 } 00222 00223 set.set_all_nodes( type ); 00224 expected = set.get_bits() & ~( 1u << ( NodeSet::REGION_OFFSET ) ); 00225 set.clear_mid_region_node( 0 ); 00226 CPPUNIT_ASSERT_EQUAL( expected, set.get_bits() ); 00227 } 00228 00229 void NodeSetTest::test_num_nodes() 00230 { 00231 NodeSet set; 00232 set.clear(); 00233 set.set_corner_node( 1 ); 00234 CPPUNIT_ASSERT_EQUAL( 1u, set.num_nodes() ); 00235 set.set_corner_node( 3 ); 00236 CPPUNIT_ASSERT_EQUAL( 2u, set.num_nodes() ); 00237 set.set_mid_region_node( 0 ); 00238 CPPUNIT_ASSERT_EQUAL( 3u, set.num_nodes() ); 00239 set.set_mid_edge_node( 1 ); 00240 set.set_mid_edge_node( 2 ); 00241 CPPUNIT_ASSERT_EQUAL( 5u, set.num_nodes() ); 00242 set.set_all_nodes( HEXAHEDRON ); 00243 CPPUNIT_ASSERT_EQUAL( 27u, set.num_nodes() ); 00244 set.clear(); 00245 set.set_all_nodes( TETRAHEDRON ); 00246 CPPUNIT_ASSERT_EQUAL( 15u, set.num_nodes() ); 00247 set.clear(); 00248 set.set_all_nodes( TRIANGLE ); 00249 CPPUNIT_ASSERT_EQUAL( 7u, set.num_nodes() ); 00250 set.clear(); 00251 set.set_all_nodes( QUADRILATERAL ); 00252 CPPUNIT_ASSERT_EQUAL( 9u, set.num_nodes() ); 00253 set.clear(); 00254 set.set_all_nodes( PYRAMID ); 00255 CPPUNIT_ASSERT_EQUAL( 19u, set.num_nodes() ); 00256 set.clear(); 00257 set.set_all_nodes( PRISM ); 00258 CPPUNIT_ASSERT_EQUAL( 21u, set.num_nodes() ); 00259 } 00260 00261 void NodeSetTest::test_have_any() 00262 { 00263 NodeSet set; 00264 set.clear(); 00265 00266 CPPUNIT_ASSERT( !set.have_any_corner_node() ); 00267 set.set_corner_node( 0 ); 00268 CPPUNIT_ASSERT( set.have_any_corner_node() ); 00269 set.clear_corner_node( 0 ); 00270 CPPUNIT_ASSERT( !set.have_any_corner_node() ); 00271 set.set_corner_node( NodeSet::NUM_CORNER_BITS - 1 ); 00272 CPPUNIT_ASSERT( set.have_any_corner_node() ); 00273 CPPUNIT_ASSERT( !set.have_any_mid_node() ); 00274 00275 CPPUNIT_ASSERT( !set.have_any_mid_edge_node() ); 00276 set.set_mid_edge_node( 0 ); 00277 CPPUNIT_ASSERT( set.have_any_mid_edge_node() ); 00278 CPPUNIT_ASSERT( set.have_any_mid_node() ); 00279 set.clear_mid_edge_node( 0 ); 00280 CPPUNIT_ASSERT( !set.have_any_mid_edge_node() ); 00281 CPPUNIT_ASSERT( !set.have_any_mid_node() ); 00282 set.set_mid_edge_node( NodeSet::NUM_EDGE_BITS - 1 ); 00283 CPPUNIT_ASSERT( set.have_any_mid_edge_node() ); 00284 CPPUNIT_ASSERT( set.have_any_mid_node() ); 00285 set.clear(); 00286 00287 CPPUNIT_ASSERT( !set.have_any_mid_face_node() ); 00288 set.set_mid_face_node( 0 ); 00289 CPPUNIT_ASSERT( set.have_any_mid_face_node() ); 00290 CPPUNIT_ASSERT( set.have_any_mid_node() ); 00291 set.clear_mid_face_node( 0 ); 00292 CPPUNIT_ASSERT( !set.have_any_mid_face_node() ); 00293 CPPUNIT_ASSERT( !set.have_any_mid_node() ); 00294 set.set_mid_face_node( NodeSet::NUM_FACE_BITS - 1 ); 00295 CPPUNIT_ASSERT( set.have_any_mid_face_node() ); 00296 CPPUNIT_ASSERT( set.have_any_mid_node() ); 00297 set.clear(); 00298 00299 CPPUNIT_ASSERT( !set.have_any_mid_region_node() ); 00300 set.set_mid_region_node( 0 ); 00301 CPPUNIT_ASSERT( set.have_any_mid_region_node() ); 00302 CPPUNIT_ASSERT( set.have_any_mid_node() ); 00303 set.clear_mid_region_node( 0 ); 00304 CPPUNIT_ASSERT( !set.have_any_mid_region_node() ); 00305 CPPUNIT_ASSERT( !set.have_any_mid_node() ); 00306 set.set_mid_region_node( NodeSet::NUM_REGION_BITS - 1 ); 00307 CPPUNIT_ASSERT( set.have_any_mid_region_node() ); 00308 CPPUNIT_ASSERT( set.have_any_mid_node() ); 00309 set.clear(); 00310 } 00311 00312 static bool check_all( EntityTopology type, NodeSet set, unsigned dim, bool value ) 00313 { 00314 unsigned count = TopologyInfo::adjacent( type, dim ); 00315 for( unsigned i = 0; i < count; ++i ) 00316 if( set.node( Sample( dim, i ) ) != value ) return false; 00317 return true; 00318 } 00319 00320 static bool check_range_set( EntityTopology type, NodeSet set, unsigned dim, bool value = true ) 00321 { 00322 const unsigned max_count[] = { NodeSet::NUM_CORNER_BITS, NodeSet::NUM_EDGE_BITS, NodeSet::NUM_FACE_BITS, 00323 NodeSet::NUM_REGION_BITS }; 00324 00325 // test that any bits corresponding to some other dimension are not set. 00326 for( unsigned d = 0; d <= 3; ++d ) 00327 { 00328 if( d == dim ) continue; 00329 00330 for( unsigned i = 0; i < max_count[d]; ++i ) 00331 if( !set.node( Sample( d, i ) ) != value ) return false; 00332 } 00333 00334 // test that any bits for this dimension beyond the number for this 00335 // type are not set 00336 for( unsigned i = TopologyInfo::adjacent( type, dim ); i < max_count[dim]; ++i ) 00337 if( !set.node( Sample( dim, i ) ) != value ) return false; 00338 00339 // test that any bits for the type and dimension are set 00340 for( unsigned i = 0; i < TopologyInfo::adjacent( type, dim ); ++i ) 00341 if( set.node( Sample( dim, i ) ) == value ) return false; 00342 00343 return true; 00344 } 00345 00346 void NodeSetTest::test_set_all() 00347 { 00348 const EntityTopology types[] = { TRIANGLE, QUADRILATERAL, TETRAHEDRON, HEXAHEDRON, PRISM, PYRAMID }; 00349 const int num_types = sizeof( types ) / sizeof( types[0] ); 00350 00351 for( int i = 0; i < num_types; ++i ) 00352 { 00353 NodeSet set; 00354 set.set_all_corner_nodes( types[i] ); 00355 check_range_set( types[i], set, 0 ); 00356 set.clear(); 00357 set.set_all_mid_edge_nodes( types[i] ); 00358 check_range_set( types[i], set, 1 ); 00359 set.clear(); 00360 set.set_all_mid_face_nodes( types[i] ); 00361 check_range_set( types[i], set, 2 ); 00362 set.clear(); 00363 set.set_all_mid_region_nodes( types[i] ); 00364 check_range_set( types[i], set, 3 ); 00365 } 00366 } 00367 00368 void NodeSetTest::test_clear_all() 00369 { 00370 const EntityTopology type = HEXAHEDRON; 00371 NodeSet set; 00372 set.set_all_nodes( type ); 00373 set.clear_all_corner_nodes(); 00374 CPPUNIT_ASSERT( check_all( type, set, 0, false ) ); 00375 CPPUNIT_ASSERT( check_all( type, set, 1, true ) ); 00376 CPPUNIT_ASSERT( check_all( type, set, 2, true ) ); 00377 CPPUNIT_ASSERT( check_all( type, set, 3, true ) ); 00378 set.set_all_nodes( type ); 00379 set.clear_all_mid_edge_nodes(); 00380 CPPUNIT_ASSERT( check_all( type, set, 0, true ) ); 00381 CPPUNIT_ASSERT( check_all( type, set, 1, false ) ); 00382 CPPUNIT_ASSERT( check_all( type, set, 2, true ) ); 00383 CPPUNIT_ASSERT( check_all( type, set, 3, true ) ); 00384 set.set_all_nodes( type ); 00385 set.clear_all_mid_face_nodes(); 00386 CPPUNIT_ASSERT( check_all( type, set, 0, true ) ); 00387 CPPUNIT_ASSERT( check_all( type, set, 1, true ) ); 00388 CPPUNIT_ASSERT( check_all( type, set, 2, false ) ); 00389 CPPUNIT_ASSERT( check_all( type, set, 3, true ) ); 00390 set.set_all_nodes( type ); 00391 set.clear_all_mid_region_nodes(); 00392 CPPUNIT_ASSERT( check_all( type, set, 0, true ) ); 00393 CPPUNIT_ASSERT( check_all( type, set, 1, true ) ); 00394 CPPUNIT_ASSERT( check_all( type, set, 2, true ) ); 00395 CPPUNIT_ASSERT( check_all( type, set, 3, false ) ); 00396 } 00397 00398 void NodeSetTest::test_num_before() 00399 { 00400 const EntityTopology type = HEXAHEDRON; 00401 NodeSet set; 00402 set.clear(); 00403 set.set_mid_face_node( 2 ); 00404 CPPUNIT_ASSERT_EQUAL( 0u, set.num_before_mid_face( 2 ) ); 00405 CPPUNIT_ASSERT_EQUAL( 1u, set.num_before_mid_face( 3 ) ); 00406 set.set_corner_node( 0 ); 00407 CPPUNIT_ASSERT_EQUAL( 1u, set.num_before_mid_face( 2 ) ); 00408 CPPUNIT_ASSERT_EQUAL( 2u, set.num_before_mid_face( 3 ) ); 00409 CPPUNIT_ASSERT_EQUAL( 0u, set.num_before_corner( 0 ) ); 00410 CPPUNIT_ASSERT_EQUAL( 1u, set.num_before_corner( 1 ) ); 00411 set.set_all_corner_nodes( type ); 00412 CPPUNIT_ASSERT_EQUAL( TopologyInfo::corners( type ), set.num_before_mid_edge( 0 ) ); 00413 CPPUNIT_ASSERT_EQUAL( TopologyInfo::corners( type ) - 1, 00414 set.num_before_corner( TopologyInfo::corners( type ) - 1 ) ); 00415 CPPUNIT_ASSERT_EQUAL( 0u, set.num_before_corner( 0 ) ); 00416 CPPUNIT_ASSERT_EQUAL( 1u, set.num_before_corner( 1 ) ); 00417 CPPUNIT_ASSERT_EQUAL( 2u, set.num_before_corner( 2 ) ); 00418 CPPUNIT_ASSERT_EQUAL( 3u, set.num_before_corner( 3 ) ); 00419 CPPUNIT_ASSERT_EQUAL( 4u, set.num_before_corner( 4 ) ); 00420 00421 const unsigned total_nodes = 27; 00422 set.set_all_nodes( type ); 00423 CPPUNIT_ASSERT_EQUAL( total_nodes - 1, set.num_before_mid_region( 0 ) ); 00424 set.clear_mid_edge_node( 0 ); 00425 CPPUNIT_ASSERT_EQUAL( total_nodes - 2, set.num_before_mid_region( 0 ) ); 00426 set.clear_mid_edge_node( 1 ); 00427 CPPUNIT_ASSERT_EQUAL( total_nodes - 3, set.num_before_mid_region( 0 ) ); 00428 }
