MOAB: Mesh Oriented datABase
(version 5.2.1)
Base class for all objects inserted into InstructionQueue. More...
#include <Instruction.hpp>
Public Member Functions | |
virtual | ~Instruction () |
virtual void | initialize_queue (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err)=0 |
virtual double | loop_over_mesh (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err)=0 |
virtual double | loop_over_mesh (ParallelMesh *mesh, MeshDomain *domain, const Settings *settings, MsqError &err) |
virtual std::string | get_name () const =0 |
Get string name for use in diagnostic and status output. | |
Static Public Member Functions | |
static void | initialize_vertex_byte (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err) |
Definition at line 45 of file Instruction.hpp.
Instruction::~Instruction | ( | ) | [virtual] |
Definition at line 47 of file Instruction.cpp.
virtual std::string MBMesquite::Instruction::get_name | ( | ) | const [pure virtual] |
Implemented in TCTFauxOptimizer, DummyVertexSlaver, MBMesquite::QualityAssessor, MBMesquite::TagVertexMesh, MBMesquite::FeasibleNewton, MBMesquite::SlaveBoundaryVertices, MBMesquite::MeshTransform, MBMesquite::TargetWriter, MBMesquite::NonGradient, MBMesquite::NonSmoothDescent, MBMesquite::SteepestDescent, MBMesquite::Randomize, MBMesquite::ConjugateGradient, MBMesquite::LaplacianSmoother, MBMesquite::QuasiNewton, MBMesquite::TrustRegion, UnOptimizer, and MBMesquite::SmartLaplacianSmoother.
virtual void MBMesquite::Instruction::initialize_queue | ( | MeshDomainAssoc * | mesh_and_domain, |
const Settings * | settings, | ||
MsqError & | err | ||
) | [pure virtual] |
Called for all instructions in queue before loop_over_mesh is called for any insetruction in queue. Default behavior is to do nothing.
Implemented in MBMesquite::QualityAssessor, DummyVertexSlaver, MBMesquite::TagVertexMesh, MBMesquite::SlaveBoundaryVertices, MBMesquite::QualityImprover, MBMesquite::MeshTransform, MBMesquite::VertexMover, and MBMesquite::TargetWriter.
void Instruction::initialize_vertex_byte | ( | MeshDomainAssoc * | mesh_and_domain, |
) | [static] |
Using data from query methods in MeshInterface or calculating as necessary depending on values in Settings, initialize MSQ_HARD_FIXED and MSQ_SLAVED flags on vertices, and clear MSQ_CULLED flag on all vertices. SLAVE_ALL setting is handled in PatchData rather than here for efficiency.
Definition at line 55 of file Instruction.cpp.
References MBMesquite::arrptr(), corners, dim, dof(), MBMesquite::MeshDomain::domain_DoF(), MBMesquite::Mesh::elements_get_attached_vertices(), MBMesquite::Mesh::elements_get_topologies(), mhdf_FileDesc::elems, MBMesquite::Settings::FIXED_FLAG, MBMesquite::Mesh::get_all_elements(), MBMesquite::Mesh::get_all_vertices(), MBMesquite::MeshDomainAssoc::get_domain(), MBMesquite::Settings::get_fixed_vertex_mode(), MBMesquite::MeshDomainAssoc::get_mesh(), MBMesquite::Settings::get_slaved_ho_node_mode(), MBMesquite::MsqError::INVALID_STATE, mesh, MBMesquite::MsqVertex::MSQ_DEPENDENT, MSQ_ERRRTN, MBMesquite::MsqVertex::MSQ_HARD_FIXED, MSQ_SETERR, MBMesquite::POLYGON, MBMesquite::Settings::SLAVE_ALL, MBMesquite::Settings::SLAVE_CALCULATED, MBMesquite::Settings::SLAVE_FLAG, u, MBMesquite::Mesh::vertices_get_byte(), MBMesquite::Mesh::vertices_get_fixed_flag(), MBMesquite::Mesh::vertices_get_slaved_flag(), and MBMesquite::Mesh::vertices_set_byte().
Referenced by check_global_patch_slaved(), PatchDataTest::check_higher_order_vertices_slaved(), MBMesquite::VertexMover::loop_over_mesh(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), MBMesquite::UntangleWrapper::run_wrapper(), VtkTest::test_elements(), and PatchDataTest::test_fixed_by_geom_dim().
{ std::vector< Mesh::VertexHandle > verts; std::vector< unsigned char > bytes; Mesh* mesh = mesh_and_domain->get_mesh(); MeshDomain* domain = mesh_and_domain->get_domain(); // Handle SLAVE_ALL first because we want to work with vertices // in element connectivity lists rather than one big array of // vertex handles. bool use_existing_slaved_flag = false; if( !settings || settings->get_slaved_ho_node_mode() == Settings::SLAVE_ALL ) { std::vector< Mesh::ElementHandle > elems; std::vector< size_t > junk; mesh->get_all_elements( elems, err );MSQ_ERRRTN( err ); for( size_t i = 0; i < elems.size(); ++i ) { EntityTopology type; mesh->elements_get_topologies( &elems[i], &type, 1, err );MSQ_ERRRTN( err ); unsigned ncorner = TopologyInfo::corners( type ); verts.clear(); junk.clear(); mesh->elements_get_attached_vertices( &elems[i], 1, verts, junk, err );MSQ_ERRRTN( err ); if( ncorner < verts.size() && type != POLYGON ) use_existing_slaved_flag = true; bytes.clear(); bytes.resize( verts.size(), 0 ); std::fill( bytes.begin() + TopologyInfo::corners( type ), bytes.end(), MsqVertex::MSQ_DEPENDENT ); mesh->vertices_set_byte( arrptr( verts ), arrptr( bytes ), verts.size(), err );MSQ_ERRRTN( err ); } } else if( settings && settings->get_slaved_ho_node_mode() == Settings::SLAVE_CALCULATED ) use_existing_slaved_flag = true; std::vector< bool > flags; verts.clear(); mesh->get_all_vertices( verts, err );MSQ_ERRRTN( err ); bytes.clear(); bytes.resize( verts.size(), 0 ); // Normally we start out with all bits cleared. However, if // we're doing SLAVE_CALCULATED mode then we need to perserve // the exinsting value of that bit because it was presumably // set by a previous tool in the InstructionQueue. Also, if doing // SLAVE_ALL, preserve the value we just set. if( use_existing_slaved_flag ) { mesh->vertices_get_byte( arrptr( verts ), arrptr( bytes ), verts.size(), err );MSQ_ERRRTN( err ); for( size_t i = 0; i < bytes.size(); ++i ) bytes[i] &= (unsigned char)MsqVertex::MSQ_DEPENDENT; } // If getting slaved flag for higher-order nodes from application, // copy it into vertex byte now. else if( settings && settings->get_slaved_ho_node_mode() == Settings::SLAVE_FLAG ) { mesh->vertices_get_slaved_flag( arrptr( verts ), flags, verts.size(), err );MSQ_ERRRTN( err ); for( size_t i = 0; i < bytes.size(); ++i ) if( flags[i] ) bytes[i] |= (unsigned char)MsqVertex::MSQ_DEPENDENT; } // If using application-specified fixed flag, copy that into // vertex byte now. if( !settings || settings->get_fixed_vertex_mode() == Settings::FIXED_FLAG ) { mesh->vertices_get_fixed_flag( arrptr( verts ), flags, verts.size(), err );MSQ_ERRRTN( err ); for( size_t i = 0; i < bytes.size(); ++i ) if( flags[i] ) bytes[i] |= (unsigned char)MsqVertex::MSQ_HARD_FIXED; } // otherwise need to mark vertices as fixed based on geometric domain else { if( !domain ) { MSQ_SETERR( err ) ( "Request to fix vertices by domain classification " "requres a domain.", MsqError::INVALID_STATE ); return; } const unsigned short dim = settings->get_fixed_vertex_mode(); assert( dim < 4u ); std::vector< unsigned short > dof( verts.size() ); domain->domain_DoF( arrptr( verts ), arrptr( dof ), verts.size(), err );MSQ_ERRRTN( err ); for( size_t i = 0; i < bytes.size(); ++i ) if( dof[i] <= dim ) bytes[i] |= (unsigned char)MsqVertex::MSQ_HARD_FIXED; } // Copy flag values back to mesh instance mesh->vertices_set_byte( arrptr( verts ), arrptr( bytes ), verts.size(), err );MSQ_ERRRTN( err ); }
virtual double MBMesquite::Instruction::loop_over_mesh | ( | MeshDomainAssoc * | mesh_and_domain, |
Virtual fuction implementing primary functionaliy of instruction instance.
Implemented in MBMesquite::QualityAssessor, DummyVertexSlaver, MBMesquite::TagVertexMesh, MBMesquite::SlaveBoundaryVertices, MBMesquite::MeshTransform, MBMesquite::VertexMover, and MBMesquite::TargetWriter.
Referenced by loop_over_mesh().
double Instruction::loop_over_mesh | ( | ParallelMesh * | mesh, |
MeshDomain * | domain, | ||
) | [virtual] |
Virtual fuction implementing primary functionaliy of instruction instance for parallel mesh.
Reimplemented in MBMesquite::QualityAssessor, and MBMesquite::VertexMover.
Definition at line 49 of file Instruction.cpp.
References loop_over_mesh().
{ MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( (Mesh*)mesh, domain, false, true ); return loop_over_mesh( &mesh_and_domain, settings, err ); }
