MOAB: Mesh Oriented datABase
(version 5.3.1)
#include <SmartLaplacianSmoother.hpp>
Public Member Functions | |
MESQUITE_EXPORT | SmartLaplacianSmoother (ObjectiveFunction *OF=NULL) |
MESQUITE_EXPORT | ~SmartLaplacianSmoother () |
virtual MESQUITE_EXPORT std::string | get_name () const |
Get string name for use in diagnostic and status output. | |
Static Public Member Functions | |
static MESQUITE_EXPORT size_t | num_inverted (PatchData &pd, MsqError &err) |
Protected Member Functions | |
virtual MESQUITE_EXPORT void | optimize_vertex_positions (PatchData &pd, MsqError &err) |
Private Attributes | |
std::vector< size_t > | adjVtxList |
Definition at line 13 of file SmartLaplacianSmoother.hpp.
MESQUITE_EXPORT MBMesquite::SmartLaplacianSmoother::SmartLaplacianSmoother | ( | ObjectiveFunction * | OF = NULL | ) | [inline] |
OF | ObjectiveFunction used by some termination criteria |
Definition at line 20 of file SmartLaplacianSmoother.hpp.
: RelaxationSmoother( OF ) {}
Definition at line 27 of file SmartLaplacianSmoother.cpp.
std::string MBMesquite::SmartLaplacianSmoother::get_name | ( | ) | const [virtual] |
Implements MBMesquite::Instruction.
Definition at line 22 of file SmartLaplacianSmoother.cpp.
{ return "SmartLaplacianSmoother"; }
size_t MBMesquite::SmartLaplacianSmoother::num_inverted | ( | PatchData & | pd, |
MsqError & | err | ||
) | [static] |
Definition at line 9 of file SmartLaplacianSmoother.cpp.
References MBMesquite::MsqMeshEntity::check_element_orientation(), MBMesquite::PatchData::element_by_index(), MSQ_ERRZERO, and MBMesquite::PatchData::num_elements().
Referenced by optimize_vertex_positions().
{ size_t result = 0; int inverted, junk; for( size_t i = 0; i < pd.num_elements(); ++i ) { pd.element_by_index( i ).check_element_orientation( pd, inverted, junk, err ); MSQ_ERRZERO( err ); if( inverted ) ++result; } return result; }
void MBMesquite::SmartLaplacianSmoother::optimize_vertex_positions | ( | PatchData & | pd, |
) | [protected, virtual] |
Implements MBMesquite::RelaxationSmoother.
Definition at line 29 of file SmartLaplacianSmoother.cpp.
References adjVtxList, MBMesquite::PatchData::get_adjacent_vertex_indices(), MBMesquite::PatchData::get_vertex_array(), MSQ_ERRRTN, n, MBMesquite::PatchData::num_free_vertices(), num_inverted(), MBMesquite::PatchData::set_vertex_coordinates(), and MBMesquite::PatchData::snap_vertex_to_domain().
{ assert( pd.num_free_vertices() == 1 ); const size_t center_vtx_index = 0; const size_t init_inverted = num_inverted( pd, err );MSQ_ERRRTN( err ); adjVtxList.clear(); pd.get_adjacent_vertex_indices( center_vtx_index, adjVtxList, err );MSQ_ERRRTN( err ); if( adjVtxList.empty() ) return; const MsqVertex* verts = pd.get_vertex_array( err ); const size_t n = adjVtxList.size(); const Vector3D orig_pos = verts[center_vtx_index]; Vector3D new_pos = verts[adjVtxList[0]]; for( size_t i = 1; i < n; ++i ) new_pos += verts[adjVtxList[i]]; new_pos *= 1.0 / n; pd.set_vertex_coordinates( new_pos, center_vtx_index, err ); pd.snap_vertex_to_domain( center_vtx_index, err );MSQ_ERRRTN( err ); const size_t new_inverted = num_inverted( pd, err );MSQ_ERRRTN( err ); if( new_inverted > init_inverted ) pd.set_vertex_coordinates( orig_pos, center_vtx_index, err ); }
std::vector< size_t > MBMesquite::SmartLaplacianSmoother::adjVtxList [private] |
Definition at line 36 of file SmartLaplacianSmoother.hpp.
