MOAB: Mesh Oriented datABase
(version 5.3.1)
#include <QuasiNewton.hpp>
Public Member Functions | |
MESQUITE_EXPORT | QuasiNewton (ObjectiveFunction *of) |
virtual MESQUITE_EXPORT | ~QuasiNewton () |
PatchSet * | get_patch_set () |
MESQUITE_EXPORT std::string | get_name () const |
Get string name for use in diagnostic and status output. | |
Protected Member Functions | |
virtual void | initialize (PatchData &pd, MsqError &err) |
virtual void | optimize_vertex_positions (PatchData &pd, MsqError &err) |
virtual void | initialize_mesh_iteration (PatchData &pd, MsqError &err) |
virtual void | terminate_mesh_iteration (PatchData &pd, MsqError &err) |
virtual void | cleanup () |
void | solve (Vector3D *z, const Vector3D *v) const |
Private Types | |
enum | Constants { QNVEC = 5 } |
Private Attributes | |
PatchDataVerticesMemento * | mMemento |
std::vector< Vector3D > | x |
std::vector< Vector3D > | v [QNVEC+1] |
std::vector< Vector3D > | w [QNVEC+1] |
std::vector< Vector3D > | d |
std::vector< SymMatrix3D > | mHess |
Definition at line 45 of file QuasiNewton.hpp.
enum MBMesquite::QuasiNewton::Constants [private] |
Definition at line 59 of file QuasiNewton.cpp.
: VertexMover( of ), PatchSetUser( true ), mMemento( 0 ) {}
MBMesquite::QuasiNewton::~QuasiNewton | ( | ) | [virtual] |
Definition at line 61 of file QuasiNewton.cpp.
References mMemento.
void MBMesquite::QuasiNewton::cleanup | ( | ) | [protected, virtual] |
Implements MBMesquite::VertexMover.
Definition at line 79 of file QuasiNewton.cpp.
References d, MBMesquite::free_vector(), mHess, mMemento, v, w, and x.
{ // release memento delete mMemento; mMemento = 0; // release coordinates for( size_t i = 0; i < ( sizeof( w ) / sizeof( w[0] ) ); ++i ) free_vector( w[i] ); // release gradients for( size_t i = 0; i < ( sizeof( v ) / sizeof( v[0] ) ); ++i ) free_vector( v[i] ); // release Hessian memory free_vector( mHess ); // release temporary array memory free_vector( x ); free_vector( d ); }
std::string MBMesquite::QuasiNewton::get_name | ( | ) | const [virtual] |
Implements MBMesquite::Instruction.
Definition at line 49 of file QuasiNewton.cpp.
{ return "QuasiNewton"; }
PatchSet * MBMesquite::QuasiNewton::get_patch_set | ( | ) | [virtual] |
Reimplemented from MBMesquite::PatchSetUser.
Definition at line 54 of file QuasiNewton.cpp.
{ return PatchSetUser::get_patch_set(); }
void MBMesquite::QuasiNewton::initialize | ( | PatchData & | pd, |
MsqError & | err | ||
Definition at line 67 of file QuasiNewton.cpp.
References MBMesquite::PatchData::create_vertices_memento(), mMemento, and MSQ_CHKERR.
{ if( !mMemento ) { mMemento = pd.create_vertices_memento( err );MSQ_CHKERR( err ); } }
void MBMesquite::QuasiNewton::initialize_mesh_iteration | ( | PatchData & | pd, |
void MBMesquite::QuasiNewton::optimize_vertex_positions | ( | PatchData & | pd, |
Definition at line 169 of file QuasiNewton.cpp.
References MBMesquite::TerminationCriterion::accumulate_inner(), MBMesquite::TerminationCriterion::accumulate_patch(), MBMesquite::arrptr(), b, MBMesquite::MsqError::BARRIER_VIOLATED, beta, MBMesquite::MsqError::clear(), d, epsilon, MBMesquite::MsqError::error_code(), MBMesquite::OFEvaluator::evaluate(), MBMesquite::PatchData::get_free_vertex_coordinates(), MBMesquite::QualityImprover::get_inner_termination_criterion(), MBMesquite::VertexMover::get_objective_function_evaluator(), MBMesquite::inner(), INTERNAL_ERROR, MBMesquite::MsqError::INVALID_MESH, MBMesquite::length(), mHess, mMemento, MBMesquite::PatchData::move_free_vertices_constrained(), MSQ_ERRRTN, MSQ_SETERR, MBMesquite::PatchData::num_free_vertices(), MBMesquite::plus_eq_scaled(), QNVEC, MBMesquite::PatchData::recreate_vertices_memento(), MBMesquite::PatchData::set_free_vertices_constrained(), MBMesquite::PatchData::set_to_vertices_memento(), solve(), MBMesquite::TerminationCriterion::terminate(), MBMesquite::OFEvaluator::update(), v, w, and x.
{ TerminationCriterion& term = *get_inner_termination_criterion(); OFEvaluator& func = get_objective_function_evaluator(); const double sigma = 1e-4; const double beta0 = 0.25; const double beta1 = 0.80; const double tol1 = 1e-8; const double epsilon = 1e-10; // double norm_r; //, norm_g; double alpha, beta; double obj, objn; size_t i; // Initialize stuff const size_t nn = pd.num_free_vertices(); double a[QNVEC], b[QNVEC], r[QNVEC]; for( i = 0; i < QNVEC; ++i ) r[i] = 0; for( i = 0; i <= QNVEC; ++i ) { v[i].clear(); v[i].resize( nn, Vector3D( 0.0 ) ); w[i].clear(); w[i].resize( nn, Vector3D( 0.0 ) ); } d.resize( nn ); mHess.resize( nn ); // hMesh(mesh); bool valid = func.update( pd, obj, v[QNVEC], mHess, err );MSQ_ERRRTN( err ); if( !valid ) { MSQ_SETERR( err )( "Initial objective function is not valid", MsqError::INVALID_MESH ); return; } while( !term.terminate() ) { pd.recreate_vertices_memento( mMemento, err );MSQ_ERRRTN( err ); pd.get_free_vertex_coordinates( w[QNVEC] ); x = v[QNVEC]; for( i = QNVEC; i--; ) { a[i] = r[i] * inner( &( w[i][0] ), arrptr( x ), nn ); plus_eq_scaled( arrptr( x ), -a[i], &v[i][0], nn ); } solve( arrptr( d ), arrptr( x ) ); for( i = QNVEC; i--; ) { b[i] = r[i] * inner( &( v[i][0] ), arrptr( d ), nn ); plus_eq_scaled( arrptr( d ), a[i] - b[i], &( w[i][0] ), nn ); } alpha = -inner( &( v[QNVEC][0] ), arrptr( d ), nn ); /* direction is negated */ if( alpha > 0.0 ) { MSQ_SETERR( err )( "No descent.", MsqError::INVALID_MESH ); return; } alpha *= sigma; beta = 1.0; pd.move_free_vertices_constrained( arrptr( d ), nn, -beta, err );MSQ_ERRRTN( err ); valid = func.evaluate( pd, objn, v[QNVEC], err ); if( err.error_code() == err.BARRIER_VIOLATED ) err.clear(); // barrier violated does not represent an actual error here MSQ_ERRRTN( err ); if( !valid || ( obj - objn < -alpha * beta - epsilon && length( &( v[QNVEC][0] ), nn ) >= tol1 ) ) { if( !valid ) // function not defined at trial point beta *= beta0; else // unacceptable iterate beta *= beta1; for( ;; ) { if( beta < tol1 ) { pd.set_to_vertices_memento( mMemento, err );MSQ_ERRRTN( err ); MSQ_SETERR( err )( "Newton step not good", MsqError::INTERNAL_ERROR ); return; } pd.set_free_vertices_constrained( mMemento, arrptr( d ), nn, -beta, err );MSQ_ERRRTN( err ); valid = func.evaluate( pd, objn, err ); if( err.error_code() == err.BARRIER_VIOLATED ) err.clear(); // barrier violated does not represent an actual error here MSQ_ERRRTN( err ); if( !valid ) // function undefined at trial point beta *= beta0; else if( obj - objn < -alpha * beta - epsilon ) // unacceptlable iterate beta *= beta1; else break; } } for( i = 0; i < QNVEC - 1; ++i ) { r[i] = r[i + 1]; w[i].swap( w[i + 1] ); v[i].swap( v[i + 1] ); } w[QNVEC - 1].swap( w[0] ); v[QNVEC - 1].swap( v[0] ); func.update( pd, obj, v[QNVEC], mHess, err );MSQ_ERRRTN( err ); // norm_r = length_squared( &(v[QNVEC][0]), nn ); // norm_g = sqrt(norm_r); // checks stopping criterion term.accumulate_patch( pd, err );MSQ_ERRRTN( err ); term.accumulate_inner( pd, objn, &v[QNVEC][0], err );MSQ_ERRRTN( err ); } }
void MBMesquite::QuasiNewton::solve | ( | Vector3D * | z, |
const Vector3D * | v | ||
) | const [protected] |
Definition at line 108 of file QuasiNewton.cpp.
Referenced by optimize_vertex_positions().
{ SymMatrix3D pd; const double small = DBL_EPSILON; const size_t nn = mHess.size(); for( size_t i = 0; i < nn; ++i ) { // ensure positive definite: perturb a bit if // diagonal values are zero. SymMatrix3D dd = mHess[i]; while( fabs( dd[0] ) < small || fabs( dd[3] ) < small || fabs( dd[5] ) < small ) dd += small; // factor pd[0] = 1.0 / dd[0]; pd[1] = dd[1] * pd[0]; pd[2] = dd[2] * pd[0]; pd[3] = 1.0 / ( dd[3] - dd[1] * pd[1] ); pd[5] = dd[4] - dd[2] * pd[1]; pd[4] = pd[3] * pd[5]; pd[5] = 1.0 / ( dd[5] - dd[2] * pd[2] - pd[4] * pd[5] ); if( pd[0] <= 0.0 || pd[3] <= 0.0 || pd[5] <= 0.0 ) { if( dd[0] + dd[3] + dd[5] <= 0 ) { // switch to diagonal pd[0] = 1.0 / fabs( dd[0] ); pd[1] = 0.0; pd[2] = 0.0; pd[3] = 1.0 / fabs( dd[3] ); pd[4] = 0.0; pd[5] = 1.0 / fabs( dd[5] ); } else { // diagonal preconditioner pd[0] = pd[3] = pd[5] = 1.0 / ( dd[0] + dd[3] + dd[5] ); pd[1] = pd[2] = pd[4] = 0.0; } } // solve const Vector3D& vv = v_arr[i]; Vector3D& z = z_arr[i]; z[0] = vv[0]; z[1] = vv[1] - pd[1] * z[0]; z[2] = vv[2] - pd[2] * z[0] - pd[4] * z[1]; z[0] *= pd[0]; z[1] *= pd[3]; z[2] *= pd[5]; z[1] -= pd[4] * z[2]; z[0] -= pd[1] * z[1] + pd[2] * z[2]; } }
void MBMesquite::QuasiNewton::terminate_mesh_iteration | ( | PatchData & | pd, |
std::vector< Vector3D > MBMesquite::QuasiNewton::d [private] |
Definition at line 72 of file QuasiNewton.hpp.
Referenced by cleanup(), and optimize_vertex_positions().
std::vector< SymMatrix3D > MBMesquite::QuasiNewton::mHess [private] |
Definition at line 73 of file QuasiNewton.hpp.
Referenced by cleanup(), optimize_vertex_positions(), and solve().
Definition at line 71 of file QuasiNewton.hpp.
Referenced by cleanup(), initialize(), optimize_vertex_positions(), and ~QuasiNewton().
std::vector< Vector3D > MBMesquite::QuasiNewton::v[QNVEC+1] [private] |
std::vector< Vector3D > MBMesquite::QuasiNewton::w[QNVEC+1] [private] |
std::vector< Vector3D > MBMesquite::QuasiNewton::x [private] |
