MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <MeshTransform.hpp>
Public Member Functions | |
MeshTransform (bool skip_fixed=false) | |
MeshTransform (Matrix3D &in_mat, Vector3D &in_vec, bool skip_fixed=false) | |
virtual | ~MeshTransform () |
virtual double | loop_over_mesh (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err) |
Loop over the mesh and perform the affine transformation. | |
virtual std::string | get_name () const |
Return the name of this PatchDataUser: Mesh Transform. | |
virtual void | initialize_queue (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err) |
void | add_translation (const Vector3D &offset) |
void | add_rotation (const Vector3D &axis, double radians) |
void | add_scale (double factor) |
void | add_scale (const Vector3D &factors) |
bool | skipping_fixed_vertices () const |
void | skip_fixed_vertices (bool yesno) |
Private Attributes | |
Matrix3D | mMat |
Vector3D | mVec |
Matrix for the affine transformation. | |
bool | skipFixed |
Vector for the affine transformation. |
Perform an Affine transformation on Mesh vertex positions. Essentially define the new vertex position, v_new, from the original vertex position, v_old, s.t. v_new = (mMat * v_old) + mVec, where mMat is a constant matrix and mVec is a constant vector.
Definition at line 55 of file MeshTransform.hpp.
MBMesquite::MeshTransform::MeshTransform | ( | bool | skip_fixed = false | ) | [inline] |
Definition at line 58 of file MeshTransform.hpp.
MBMesquite::MeshTransform::MeshTransform | ( | Matrix3D & | in_mat, |
Vector3D & | in_vec, | ||
) | [inline] |
Definition at line 61 of file MeshTransform.hpp.
MBMesquite::MeshTransform::~MeshTransform | ( | ) | [virtual] |
Definition at line 45 of file MeshTransform.cpp.
void MBMesquite::MeshTransform::add_rotation | ( | const Vector3D & | axis, |
double | radians | ||
Definition at line 87 of file MeshTransform.cpp.
References MBMesquite::Vector3D::length(), mMat, mVec, and MBMesquite::Matrix3D::outer_product().
{ const double c = cos( radians ); const double s = sin( radians ); const Vector3D a = axis / axis.length(); const Matrix3D m1( c, -a[2] * s, a[1] * s, a[2] * s, c, -a[0] * s, -a[1] * s, a[0] * s, c ); Matrix3D m2; m2.outer_product( a, a ); Matrix3D rot = m1 + ( 1.0 - c ) * m2; mMat = rot * mMat; mVec = rot * mVec; }
void MBMesquite::MeshTransform::add_scale | ( | double | factor | ) |
Definition at line 100 of file MeshTransform.cpp.
{ add_scale( Vector3D( factor ) ); }
void MBMesquite::MeshTransform::add_scale | ( | const Vector3D & | factors | ) |
void MBMesquite::MeshTransform::add_translation | ( | const Vector3D & | offset | ) |
virtual std::string MBMesquite::MeshTransform::get_name | ( | ) | const [inline, virtual] |
Implements MBMesquite::Instruction.
Definition at line 73 of file MeshTransform.hpp.
{ return "Mesh Transform"; }
void MBMesquite::MeshTransform::initialize_queue | ( | MeshDomainAssoc * | mesh_and_domain, |
const Settings * | settings, | ||
MsqError & | err | ||
) | [virtual] |
Called for all instructions in queue before loop_over_mesh is called for any insetruction in queue. Default behavior is to do nothing.
Definition at line 116 of file MeshTransform.cpp.
double MBMesquite::MeshTransform::loop_over_mesh | ( | MeshDomainAssoc * | mesh_and_domain, |
) | [virtual] |
Actually apply the affine transformation
Definition at line 50 of file MeshTransform.cpp.
References fixed, MBMesquite::Mesh::get_all_vertices(), MBMesquite::MeshDomainAssoc::get_mesh(), mesh, mMat, MSQ_CHKERR, mVec, skipFixed, MBMesquite::Mesh::vertex_set_coordinates(), MBMesquite::Mesh::vertices_get_coordinates(), and MBMesquite::Mesh::vertices_get_fixed_flag().
Referenced by main().
{ Mesh* mesh = mesh_and_domain->get_mesh(); std::vector< Mesh::VertexHandle > handle_list; mesh->get_all_vertices( handle_list, err ); if( MSQ_CHKERR( err ) ) return 1.0; std::vector< bool > fixed( 1 ); MsqVertex vertex; std::vector< Mesh::VertexHandle >::const_iterator iter; for( iter = handle_list.begin(); iter != handle_list.end(); ++iter ) { mesh->vertices_get_coordinates( &*iter, &vertex, 1, err ); if( MSQ_CHKERR( err ) ) return 1.0; if( skipFixed ) { mesh->vertices_get_fixed_flag( &*iter, fixed, 1, err ); if( MSQ_CHKERR( err ) ) return 1.0; if( fixed.front() ) continue; } vertex = mMat * vertex + mVec; mesh->vertex_set_coordinates( *iter, vertex, err ); if( MSQ_CHKERR( err ) ) return 1.0; } return 0.0; }
void MBMesquite::MeshTransform::skip_fixed_vertices | ( | bool | yesno | ) | [inline] |
bool MBMesquite::MeshTransform::skipping_fixed_vertices | ( | ) | const [inline] |
Definition at line 85 of file MeshTransform.hpp.
{ return skipFixed; }
Matrix3D MBMesquite::MeshTransform::mMat [private] |
Definition at line 95 of file MeshTransform.hpp.
Referenced by add_rotation(), add_scale(), and loop_over_mesh().
Vector3D MBMesquite::MeshTransform::mVec [private] |
Definition at line 96 of file MeshTransform.hpp.
Referenced by add_rotation(), add_scale(), add_translation(), and loop_over_mesh().
bool MBMesquite::MeshTransform::skipFixed [private] |
Definition at line 97 of file MeshTransform.hpp.
Referenced by loop_over_mesh().
