MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 #include "MeshTransform.hpp" 00002 #include "MeshImpl.hpp" 00003 #include "CLArgs.hpp" 00004 #include "MsqError.hpp" 00005 00006 #include <iostream> 00007 00008 using namespace MBMesquite; 00009 00010 const char ROTATE_FLAG = 'r'; 00011 const char SCALE_FLAG = 's'; 00012 const char TRANSLATE_FLAG = 't'; 00013 00014 class RotateArg : public CLArgs::DoubleListArgI 00015 { 00016 private: 00017 MeshTransform* mTransform; 00018 00019 public: 00020 RotateArg( MeshTransform* xform ) : mTransform( xform ) {} 00021 bool value( const std::vector< double >& vals ); 00022 }; 00023 class ScaleArg : public CLArgs::DoubleListArgI 00024 { 00025 private: 00026 MeshTransform* mTransform; 00027 00028 public: 00029 ScaleArg( MeshTransform* xform ) : mTransform( xform ) {} 00030 bool value( const std::vector< double >& vals ); 00031 }; 00032 class TranslateArg : public CLArgs::DoubleListArgI 00033 { 00034 private: 00035 MeshTransform* mTransform; 00036 00037 public: 00038 TranslateArg( MeshTransform* xform ) : mTransform( xform ) {} 00039 bool value( const std::vector< double >& vals ); 00040 }; 00041 bool RotateArg::value( const std::vector< double >& vals ) 00042 { 00043 mTransform->add_rotation( Vector3D( vals[1], vals[2], vals[3] ), vals[0] * M_PI / 180 ); 00044 return true; 00045 } 00046 bool ScaleArg::value( const std::vector< double >& vals ) 00047 { 00048 for( unsigned i = 0; i < vals.size(); ++i ) 00049 if( vals[i] <= 0 ) return false; 00050 if( vals.size() == 1 ) 00051 mTransform->add_scale( vals[0] ); 00052 else 00053 mTransform->add_scale( Vector3D( vals[0], vals[1], vals[2] ) ); 00054 return true; 00055 } 00056 bool TranslateArg::value( const std::vector< double >& vals ) 00057 { 00058 mTransform->add_translation( Vector3D( vals[0], vals[1], vals[2] ) ); 00059 return true; 00060 } 00061 00062 int main( int argc, char* argv[] ) 00063 { 00064 MeshTransform xform; 00065 RotateArg rotate_arg( &xform ); 00066 ScaleArg scale_arg( &xform ); 00067 TranslateArg translate_arg( &xform ); 00068 CLArgs::ToggleArg freeonly, skin; 00069 00070 CLArgs args( "vtkxform", "Transform a mesh", 00071 "Apply one or more transformations to vertex coordinates " 00072 "in a mesh read from a VTK file." ); 00073 00074 const char* ROTATE_VALS[] = { "a", "i", "j", "k" }; 00075 args.double_list_flag( ROTATE_FLAG, "Specify a rotation as an angle in degrees counter-clockwise about a vector", 00076 &rotate_arg ); 00077 args.limit_list_flag( ROTATE_FLAG, 4, ROTATE_VALS ); 00078 00079 const char* SCALE_VALS[] = { "s", "sx", "sy", "sz" }; 00080 args.double_list_flag( SCALE_FLAG, "Specify factor(s) by which to scale mesh about origin", &scale_arg ); 00081 args.limit_list_flag( SCALE_FLAG, 1, SCALE_VALS ); 00082 args.limit_list_flag( SCALE_FLAG, 3, SCALE_VALS + 1 ); 00083 00084 const char* TRANSLATE_VALS[] = { "dx", "dy", "dz" }; 00085 args.double_list_flag( TRANSLATE_FLAG, "Specify translation of vertex coordinates.", &translate_arg ); 00086 args.limit_list_flag( TRANSLATE_FLAG, 3, TRANSLATE_VALS ); 00087 00088 args.toggle_flag( 'f', "Do not move fixed vertices.", &freeonly ); 00089 args.toggle_flag( 'k', "Mark boundary vertices as fixed", &skin ); 00090 00091 args.add_required_arg( "input_file" ); 00092 args.add_required_arg( "output_file" ); 00093 00094 std::vector< std::string > files; 00095 if( !args.parse_options( argc, argv, files, std::cerr ) ) 00096 { 00097 args.print_usage( std::cerr ); 00098 exit( 1 ); 00099 } 00100 std::string input_file = files[0]; 00101 std::string output_file = files[1]; 00102 00103 MeshImpl mesh; 00104 MsqError err; 00105 mesh.read_vtk( input_file.c_str(), err ); 00106 if( err ) 00107 { 00108 std::cerr << err << std::endl << "Failed to read file: " << input_file << std::endl; 00109 return 1; 00110 } 00111 00112 if( skin.value() ) 00113 { 00114 mesh.mark_skin_fixed( err, false ); 00115 if( err ) 00116 { 00117 std::cerr << err << std::endl << "Failed to skin mesh from file: " << input_file << std::endl; 00118 return 1; 00119 } 00120 } 00121 00122 xform.skip_fixed_vertices( freeonly.value() ); 00123 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, 0 ); 00124 xform.loop_over_mesh( &mesh_and_domain, 0, err ); 00125 if( err ) 00126 { 00127 std::cerr << err << std::endl; 00128 return 2; 00129 } 00130 00131 mesh.write_vtk( output_file.c_str(), err ); 00132 if( err ) 00133 { 00134 std::cerr << err << std::endl << "Failed to write file: " << output_file << std::endl; 00135 return 1; 00136 } 00137 00138 return 0; 00139 }
