transform.cpp File Reference
#include "MeshTransform.hpp"
#include "MeshImpl.hpp"
#include "CLArgs.hpp"
#include "MsqError.hpp"
#include <iostream>
+ Include dependency graph for transform.cpp:
Classes
class  RotateArg
class  ScaleArg
class  TranslateArg
Functions
int main (int argc, char *argv[])
Variables
const char ROTATE_FLAG = 'r'
const char SCALE_FLAG = 's'
const char TRANSLATE_FLAG = 't'
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 62 of file transform.cpp.
References CLArgs::add_required_arg(), args, CLArgs::double_list_flag(), input_file, CLArgs::limit_list_flag(), MBMesquite::MeshTransform::loop_over_mesh(), MBMesquite::MeshImpl::mark_skin_fixed(), mesh, CLArgs::parse_options(), CLArgs::print_usage(), MBMesquite::MeshImpl::read_vtk(), ROTATE_FLAG, SCALE_FLAG, skin(), MBMesquite::MeshTransform::skip_fixed_vertices(), CLArgs::toggle_flag(), TRANSLATE_FLAG, CLArgs::ArgTemplate< T >::value(), and MBMesquite::MeshImpl::write_vtk().
    MeshTransform xform;
    RotateArg rotate_arg( &xform );
    ScaleArg scale_arg( &xform );
    TranslateArg translate_arg( &xform );
    CLArgs::ToggleArg freeonly, skin;
    CLArgs args( "vtkxform", "Transform a mesh",
                 "Apply one or more transformations to vertex coordinates "
                 "in a mesh read from a VTK file." );
    const char* ROTATE_VALS[] = { "a", "i", "j", "k" };
    args.double_list_flag( ROTATE_FLAG, "Specify a rotation as an angle in degrees counter-clockwise about a vector",
                           &rotate_arg );
    args.limit_list_flag( ROTATE_FLAG, 4, ROTATE_VALS );
    const char* SCALE_VALS[] = { "s", "sx", "sy", "sz" };
    args.double_list_flag( SCALE_FLAG, "Specify factor(s) by which to scale mesh about origin", &scale_arg );
    args.limit_list_flag( SCALE_FLAG, 1, SCALE_VALS );
    args.limit_list_flag( SCALE_FLAG, 3, SCALE_VALS + 1 );
    const char* TRANSLATE_VALS[] = { "dx", "dy", "dz" };
    args.double_list_flag( TRANSLATE_FLAG, "Specify translation of vertex coordinates.", &translate_arg );
    args.limit_list_flag( TRANSLATE_FLAG, 3, TRANSLATE_VALS );
    args.toggle_flag( 'f', "Do not move fixed vertices.", &freeonly );
    args.toggle_flag( 'k', "Mark boundary vertices as fixed", &skin );
    args.add_required_arg( "input_file" );
    args.add_required_arg( "output_file" );
    std::vector< std::string > files;
    if( !args.parse_options( argc, argv, files, std::cerr ) )
        args.print_usage( std::cerr );
        exit( 1 );
    std::string input_file  = files[0];
    std::string output_file = files[1];
    MeshImpl mesh;
    MsqError err;
    mesh.read_vtk( input_file.c_str(), err );
    if( err )
        std::cerr << err << std::endl << "Failed to read file: " << input_file << std::endl;
        return 1;
    if( skin.value() )
        mesh.mark_skin_fixed( err, false );
        if( err )
            std::cerr << err << std::endl << "Failed to skin mesh from file: " << input_file << std::endl;
            return 1;
    xform.skip_fixed_vertices( freeonly.value() );
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, 0 );
    xform.loop_over_mesh( &mesh_and_domain, 0, err );
    if( err )
        std::cerr << err << std::endl;
        return 2;
    mesh.write_vtk( output_file.c_str(), err );
    if( err )
        std::cerr << err << std::endl << "Failed to write file: " << output_file << std::endl;
        return 1;
    return 0;
Variable Documentation
Definition at line 10 of file transform.cpp.
Referenced by main().
Definition at line 11 of file transform.cpp.
Definition at line 12 of file transform.cpp.
