MOAB: Mesh Oriented datABase
(version 5.2.1)
#include <NonGradient.hpp>
Public Member Functions | |
MESQUITE_EXPORT | NonGradient (ObjectiveFunction *of) |
MESQUITE_EXPORT | NonGradient (ObjectiveFunction *of, MsqError &err) |
virtual MESQUITE_EXPORT | ~NonGradient () |
virtual MESQUITE_EXPORT std::string | get_name () const |
Get string name for use in diagnostic and status output. | |
virtual MESQUITE_EXPORT PatchSet * | get_patch_set () |
MESQUITE_EXPORT bool | project_gradient () const |
MESQUITE_EXPORT void | project_gradient (bool yesno) |
int | getDimension () |
double | getThreshold () |
int | getMaxNumEval () |
double | getSimplexDiameterScale () |
void | setDimension (int dimension) |
void | setThreshold (double threshold) |
void | setMaxNumEval (int maxNumEval) |
void | setExactPenaltyFunction (bool exactPenalty) |
void | setSimplexDiameterScale (double newScaleDiameter) |
void | getRowSum (int numRow, int numCol, std::vector< double > &matrix, std::vector< double > &rowSum) |
bool | testRowSum (int numRow, int numCol, double *matrix, double *rowSum) |
double | evaluate (double localArray[], PatchData &pd, MsqError &err) |
int | initSimplex (double edgeLength) |
edgeLenght is a length scale for the initial polytope. | |
void | printPatch (const PatchData &pd, MsqError &err) |
Generic patch helper function only used by NonGradient. | |
int | getPatchDimension (const PatchData &pd, MsqError &err) |
MESQUITE_EXPORT void | set_debugging_level (int level) |
Public Attributes | |
std::vector< double > | simplex |
matrix stored by column as a std::vector | |
std::vector< double > | height |
Protected Member Functions | |
virtual MESQUITE_EXPORT void | initialize (PatchData &pd, MsqError &err) |
virtual MESQUITE_EXPORT void | optimize_vertex_positions (PatchData &pd, MsqError &err) |
virtual MESQUITE_EXPORT void | initialize_mesh_iteration (PatchData &pd, MsqError &err) |
virtual MESQUITE_EXPORT void | terminate_mesh_iteration (PatchData &pd, MsqError &err) |
virtual MESQUITE_EXPORT void | cleanup () |
Private Member Functions | |
double | amotry (std::vector< double > &, std::vector< double > &, double *, int, double, PatchData &, MsqError &err) |
void | printSimplex (std::vector< double > &, std::vector< double > &) |
NonGradient (const NonGradient &pd) | |
NonGradient & | operator= (const NonGradient &pd) |
Private Attributes | |
bool | projectGradient |
int | mDimension |
double | mThreshold |
double | mTolerance |
int | mMaxNumEval |
int | mNonGradDebug |
bool | mUseExactPenaltyFunction |
double | mScaleDiameter |
This is an implementation of a derivative-free optimization algorithm Commonly referred to as the 'amoeba'. This implementation only works on patches containing one free vertex.
Definition at line 52 of file NonGradient.hpp.
Definition at line 72 of file NonGradient.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::QualityImprover::get_inner_termination_criterion(), and set_debugging_level().
: VertexMover( of ), PatchSetUser( true ), projectGradient( false ), mDimension( 0 ), mThreshold( 0.0 ), mTolerance( 0.0 ), mMaxNumEval( 0 ), mNonGradDebug( 0 ), mUseExactPenaltyFunction( true ), mScaleDiameter( 0.1 ) { set_debugging_level( 2 ); // set the default inner termination criterion TerminationCriterion* default_crit = get_inner_termination_criterion(); if( default_crit == NULL ) { return; } else { default_crit->add_iteration_limit( 5 ); } }
MBMesquite::NonGradient::NonGradient | ( | ObjectiveFunction * | of, |
MsqError & | err | ||
Definition at line 86 of file NonGradient.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::QualityImprover::get_inner_termination_criterion(), MBMesquite::MsqError::INVALID_STATE, MSQ_ERRRTN, MSQ_SETERR, and set_debugging_level().
: VertexMover( of ), PatchSetUser( true ), projectGradient( false ), mDimension( 0 ), mThreshold( 0.0 ), mTolerance( 0.0 ), mMaxNumEval( 0 ), mNonGradDebug( 0 ), mUseExactPenaltyFunction( true ), mScaleDiameter( 0.1 ) { set_debugging_level( 2 ); // set the default inner termination criterion TerminationCriterion* default_crit = get_inner_termination_criterion(); if( default_crit == NULL ) { MSQ_SETERR( err ) ( "QualityImprover did not create a default inner " "termination criterion.", MsqError::INVALID_STATE ); return; } else { default_crit->add_iteration_limit( 5 );MSQ_ERRRTN( err ); } }
virtual MESQUITE_EXPORT MBMesquite::NonGradient::~NonGradient | ( | ) | [inline, virtual] |
Definition at line 61 of file NonGradient.hpp.
MBMesquite::NonGradient::NonGradient | ( | const NonGradient & | pd | ) | [private] |
double MBMesquite::NonGradient::amotry | ( | std::vector< double > & | , |
std::vector< double > & | , | ||
double * | , | ||
int | , | ||
double | , | ||
PatchData & | , | ||
) | [private] |
Definition at line 194 of file NonGradient.cpp.
References evaluate(), getDimension(), mNonGradDebug, and MSQ_PRINT.
Referenced by optimize_vertex_positions().
{ int numRow = getDimension(); // int numCol = numRow + 1; std::vector< double > ptry( numRow ); // does this make sense? double fac1 = ( 1.0 - fac ) / static_cast< double >( numRow ); double fac2 = fac1 - fac; for( int row = 0; row < numRow; row++ ) { ptry[row] = psum[row] * fac1 - p_simplex[row + ihi * numRow] * fac2; } if( mNonGradDebug >= 3 ) { std::cout << "Try "; } MSQ_PRINT( 3 )( "Try" ); double ytry = evaluate( &ptry[0], pd, err ); // value at trial point if( mNonGradDebug >= 3 ) { std::cout << ytry << std::endl; } MSQ_PRINT( 3 )( "yTry" ); if( ytry < p_height[ihi] ) // better than highest (worst) { p_height[ihi] = ytry; // swap ihi and ytry for( int row = 0; row < numRow; row++ ) { psum[row] += ( ptry[row] - p_simplex[row + ihi * numRow] ); p_simplex[row + ihi * numRow] = ptry[row]; } } return ytry; }
void MBMesquite::NonGradient::cleanup | ( | ) | [protected, virtual] |
Implements MBMesquite::VertexMover.
Definition at line 511 of file NonGradient.cpp.
References mNonGradDebug.
{ if( mNonGradDebug >= 2 ) { std::cout << " - Executing NonGradient::iteration_end()" << std::endl; } // MSQ_PRINT(2)("\n - Executing NonGradient::iteration_end() \n"); }
double MBMesquite::NonGradient::evaluate | ( | double | localArray[], |
PatchData & | pd, | ||
Definition at line 156 of file NonGradient.cpp.
References MBMesquite::TerminationCriterion::accumulate_inner(), MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::MsqError::clear(), MBMesquite::MsqError::error_code(), MBMesquite::OFEvaluator::evaluate(), MBMesquite::QualityImprover::get_inner_termination_criterion(), MBMesquite::VertexMover::get_objective_function_evaluator(), MSQ_ERRZERO, MSQ_SETERR, mUseExactPenaltyFunction, NOT_IMPLEMENTED, MBMesquite::PatchData::num_free_vertices(), MBMesquite::PatchData::set_vertex_coordinates(), MBMesquite::PatchData::snap_vertex_to_domain(), value(), and MBMesquite::PatchData::vertex_by_index().
Referenced by amotry(), and optimize_vertex_positions().
{ if( pd.num_free_vertices() > 1 ) { MSQ_SETERR( err ) ( "Only one free vertex per patch implemented", MsqError::NOT_IMPLEMENTED ); } const size_t vertexIndex = 0; Vector3D originalVec = pd.vertex_by_index( vertexIndex ); Vector3D pointVec; for( int index = 0; index < 3; index++ ) { pointVec[index] = point[index]; } pd.set_vertex_coordinates( pointVec, vertexIndex, err ); pd.snap_vertex_to_domain( vertexIndex, err ); OFEvaluator& obj_func = get_objective_function_evaluator(); TerminationCriterion* term_crit = get_inner_termination_criterion(); double value; bool feasible = obj_func.evaluate( pd, value, err ); // MSQ_ERRZERO(err); term_crit->accumulate_inner( pd, value, 0, err ); // MSQ_CHKERR(err); if( err.error_code() == err.BARRIER_VIOLATED ) err.clear(); // barrier violation not an error here MSQ_ERRZERO( err ); pd.set_vertex_coordinates( originalVec, vertexIndex, err ); if( !feasible && mUseExactPenaltyFunction ) { // "value" undefined btw double ensureFiniteRtol = .25; value = DBL_MAX * ensureFiniteRtol; // std::cout << " Infeasible patch: " << value << std::endl; printPatch( pd, err ); } return value; }
std::string MBMesquite::NonGradient::get_name | ( | ) | const [virtual] |
Implements MBMesquite::Instruction.
Definition at line 62 of file NonGradient.cpp.
{ return "NonGradient"; }
PatchSet * MBMesquite::NonGradient::get_patch_set | ( | ) | [virtual] |
Reimplemented from MBMesquite::PatchSetUser.
Definition at line 67 of file NonGradient.cpp.
{ return PatchSetUser::get_patch_set(); }
int MBMesquite::NonGradient::getDimension | ( | ) | [inline] |
Definition at line 79 of file NonGradient.hpp.
References mDimension.
Referenced by amotry(), optimize_vertex_positions(), and printSimplex().
{ return ( mDimension ); }
int MBMesquite::NonGradient::getMaxNumEval | ( | ) | [inline] |
int MBMesquite::NonGradient::getPatchDimension | ( | const PatchData & | pd, |
Definition at line 268 of file NonGradient.cpp.
References MBMesquite::PatchData::element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::MsqError::INVALID_MESH, MSQ_SETERR, and MBMesquite::PatchData::num_elements().
Referenced by initialize_mesh_iteration().
{ const size_t numElt = pd.num_elements(); unsigned edimMax = 0; // in case numElt == 0 for( size_t elementId = 0; elementId < numElt; elementId++ ) { const MsqMeshEntity& element = pd.element_by_index( elementId ); EntityTopology type = element.get_element_type(); unsigned edim = TopologyInfo::dimension( type ); if( elementId == 0 ) { edimMax = edim; } else { if( edimMax != edim ) { MSQ_SETERR( err ) ( "A patch has elements of different dimensions", MsqError::INVALID_MESH ); std::cout << "A patch has elements of different dimensions" << edimMax << " " << edim << std::endl; if( edimMax < edim ) { edimMax = edim; } } } } return ( edimMax ); }
void MBMesquite::NonGradient::getRowSum | ( | int | numRow, |
int | numCol, | ||
std::vector< double > & | matrix, | ||
std::vector< double > & | rowSum | ||
Definition at line 141 of file NonGradient.cpp.
{ for( int row = 0; row < numRow; row++ ) { rowSum[row] = 0.; } for( int col = 0; col < numCol; col++ ) { for( int row = 0; row < numRow; row++ ) { rowSum[row] += matrix[row + col * numRow]; } } }
double MBMesquite::NonGradient::getSimplexDiameterScale | ( | ) | [inline] |
Definition at line 95 of file NonGradient.hpp.
References mScaleDiameter.
{ return ( mScaleDiameter ); }
double MBMesquite::NonGradient::getThreshold | ( | ) | [inline] |
void MBMesquite::NonGradient::initialize | ( | PatchData & | pd, |
void MBMesquite::NonGradient::initialize_mesh_iteration | ( | PatchData & | pd, |
Definition at line 294 of file NonGradient.cpp.
References MBMesquite::PatchData::get_minmax_edge_length(), MBMesquite::PatchData::get_vertex_array(), getPatchDimension(), mNonGradDebug, mScaleDiameter, MSQ_PRINT, MSQ_SETERR, NOT_IMPLEMENTED, MBMesquite::PatchData::num_free_vertices(), MBMesquite::MsqError::OUT_OF_MEMORY, scale(), setDimension(), setMaxNumEval(), setThreshold(), and simplex.
{ unsigned elementDimension = getPatchDimension( pd, err ); // to do: react to error unsigned dimension = elementDimension * pd.num_free_vertices(); // printPatch( pd, err ); setDimension( dimension ); int maxNumEval = 100 * dimension; // 1. Make this a user parameter setMaxNumEval( maxNumEval ); double threshold = 1.e-10; // avoid division by zero setThreshold( threshold ); double minEdgeLen = 0.0; double maxEdgeLen = 0.0; // double ftol = 0.; if( dimension > 0 ) { pd.get_minmax_edge_length( minEdgeLen, maxEdgeLen ); // ftol = minEdgeLen * 1.e-4; // Turn off Amoeba convergence criterion if( mNonGradDebug >= 1 ) { std::cout << "minimum edge length " << minEdgeLen << " maximum edge length " << maxEdgeLen << std::endl; } MSQ_PRINT( 3 ) ( "minimum edge length %e maximum edge length %e\n", minEdgeLen, maxEdgeLen ); } // setTolerance(ftol); unsigned numRow = dimension; unsigned numCol = numRow + 1; if( numRow * numCol <= simplex.max_size() ) { simplex.assign( numRow * numCol, 0. ); // guard against previous simplex value double scale = minEdgeLen * mScaleDiameter; ; const MsqVertex* coord = pd.get_vertex_array( err ); if( pd.num_free_vertices() > 1 ) { MSQ_SETERR( err ) ( "Only one free vertex per patch implemented", MsqError::NOT_IMPLEMENTED ); } size_t index = 0; for( unsigned col = 0; col < numCol; col++ ) { for( unsigned row = 0; row < numRow; row++ ) { simplex[row + col * numRow] = coord[index][row]; if( row == col - 1 ) { simplex[row + col * numRow] += scale / static_cast< double >( numCol ); } } } } else { MSQ_SETERR( err )( "Use patch with fewer free vertices", MsqError::OUT_OF_MEMORY ); if( mNonGradDebug >= 1 ) { std::cout << "ERROR: Too many free vertices in patch" << std::endl; } // MSQ_PRINT(1)("ERROR: Too many free vertices in patch\n"); } }
int MBMesquite::NonGradient::initSimplex | ( | double | edgeLength | ) |
NonGradient& MBMesquite::NonGradient::operator= | ( | const NonGradient & | pd | ) | [private] |
void MBMesquite::NonGradient::optimize_vertex_positions | ( | PatchData & | pd, |
Definition at line 348 of file NonGradient.cpp.
References amotry(), evaluate(), MBMesquite::QualityImprover::get_inner_termination_criterion(), getDimension(), getRowSum(), mNonGradDebug, MSQ_FUNCTION_TIMER, MSQ_SETERR, NOT_IMPLEMENTED, MBMesquite::PatchData::num_free_vertices(), printSimplex(), MBMesquite::PatchData::set_vertex_coordinates(), simplex, MBMesquite::PatchData::snap_vertex_to_domain(), and MBMesquite::TerminationCriterion::terminate().
{ MSQ_FUNCTION_TIMER( "NonGradient::optimize_vertex_positions" ); int numRow = getDimension(); int numCol = numRow + 1; std::vector< double > p_height( numCol ); for( int col = 0; col < numCol; col++ ) { p_height[col] = evaluate( &simplex[col * numRow], pd, err ); // eval patch stuff } if( mNonGradDebug > 0 ) { printSimplex( simplex, p_height ); } // standardization TerminationCriterion* term_crit = get_inner_termination_criterion(); // int maxNumEval = getMaxNumEval(); // double threshold = getThreshold(); // double ftol = getTolerance(); int ilo = 0; // height[ilo]<=... int inhi = 0; //...<=height[inhi]<= int ihi = 0; //<=height[ihi] // double rtol = 2.*ftol; double ysave; double ytry; bool afterEvaluation = false; std::vector< double > rowSum( numRow ); getRowSum( numRow, numCol, simplex, rowSum ); while( !( term_crit->terminate() ) ) { if( mNonGradDebug > 0 ) { printSimplex( simplex, p_height ); } // std::cout << "rtol " << rtol << " ftol " << ftol << " MesquiteIter " << // term_crit->get_iteration_count() << " Done " << term_crit->terminate() << std::endl; if( afterEvaluation ) { // reflect highPt through opposite face // p_height[0] may vanish /* if( !testRowSum( numRow, numCol, &simplex[0], &rowSum[0]) ) { // Before uncommenting here and ... //MSQ_SETERR(err)("Internal check sum test A failed", MsqError::INTERNAL_ERROR); //MSQ_ERRRTN(err); } */ ytry = amotry( simplex, p_height, &rowSum[0], ihi, -1.0, pd, err ); /* if( !testRowSum( numRow, numCol, &simplex[0], &rowSum[0]) ) { // ... here, determine a maxVal majorizing the previous as well as the current simplex. //MSQ_SETERR(err)("Internal check sum test B failed", MsqError::INTERNAL_ERROR); //MSQ_ERRRTN(err); } */ /* if( p_height[0] == 0.) { MSQ_SETERR(err)("(B) Zero objective function value", MsqError::INTERNAL_ERROR); exit(-1); } */ if( ytry <= p_height[ilo] ) { ytry = amotry( simplex, p_height, &rowSum[0], ihi, -2.0, pd, err ); if( mNonGradDebug >= 3 ) { std::cout << "Reflect and Expand from highPt " << ytry << std::endl; } // MSQ_PRINT(3)("Reflect and Expand from highPt : %e\n",ytry); } else { if( ytry >= p_height[inhi] ) { ysave = p_height[ihi]; // Contract along highPt ytry = amotry( simplex, p_height, &rowSum[0], ihi, 0.5, pd, err ); if( ytry >= ysave ) { // contract all directions toward lowPt for( int col = 0; col < numCol; col++ ) { if( col != ilo ) { for( int row = 0; row < numRow; row++ ) { rowSum[row] = 0.5 * ( simplex[row + col * numRow] + simplex[row + ilo * numRow] ); simplex[row + col * numRow] = rowSum[row]; } p_height[col] = evaluate( &rowSum[0], pd, err ); if( mNonGradDebug >= 3 ) { std::cout << "Contract all directions toward lowPt value( " << col << " ) = " << p_height[col] << " ilo = " << ilo << std::endl; } // MSQ_PRINT(3)("Contract all directions toward lowPt value( %d ) = // %e ilo = %d\n", col, p_height[col], ilo); } } } } } // ytri > h(ilo) } // after evaluation ilo = 1; // conditional operator or inline if ihi = p_height[0] > p_height[1] ? ( inhi = 1, 0 ) : ( inhi = 0, 1 ); for( int col = 0; col < numCol; col++ ) { if( p_height[col] <= p_height[ilo] ) { ilo = col; // ilo := argmin height } if( p_height[col] > p_height[ihi] ) { inhi = ihi; ihi = col; } else // p_height[ihi] >= p_height[col] if( col != ihi && p_height[col] > p_height[inhi] ) inhi = col; } // rtol=2.0*fabs( p_height[ihi]-p_height[ilo] )/ // ( fabs(p_height[ihi])+fabs(p_height[ilo])+threshold ); afterEvaluation = true; } // while not converged // Always set to current best mesh. { if( ilo != 0 ) { double yTemp = p_height[0]; p_height[0] = p_height[ilo]; // height dimension numCol p_height[ilo] = yTemp; for( int row = 1; row < numRow; row++ ) { yTemp = simplex[row]; simplex[row] = simplex[row + ilo * numRow]; simplex[row + ilo * numRow] = yTemp; } } } if( pd.num_free_vertices() > 1 ) { MSQ_SETERR( err ) ( "Only one free vertex per patch implemented", MsqError::NOT_IMPLEMENTED ); } Vector3D newPoint( &simplex[0] ); size_t vertexIndex = 0; // fix c.f. freeVertexIndex pd.set_vertex_coordinates( newPoint, vertexIndex, err ); pd.snap_vertex_to_domain( vertexIndex, err ); if( term_crit->terminate() ) { if( mNonGradDebug >= 1 ) { std::cout << "Optimization Termination OptStatus: Max Iter Exceeded" << std::endl; } // MSQ_PRINT(1)("Optimization Termination OptStatus: Max Iter Exceeded\n"); } }
void MBMesquite::NonGradient::printPatch | ( | const PatchData & | pd, |
Definition at line 223 of file NonGradient.cpp.
References MBMesquite::PatchData::get_vertex_array(), mNonGradDebug, MSQ_PRINT, MBMesquite::PatchData::num_corners(), MBMesquite::PatchData::num_elements(), MBMesquite::PatchData::num_free_vertices(), MBMesquite::PatchData::num_nodes(), MBMesquite::PatchData::num_slave_vertices(), and numVert.
{ if( mNonGradDebug == 0 ) { return; } const size_t numNode = pd.num_nodes(); // 27, 27 what? MSQ_PRINT( 3 )( "Number of Vertices: %d\n", (int)pd.num_nodes() ); const size_t numVert = pd.num_free_vertices(); // 1 MSQ_PRINT( 3 )( "Num Free = %d\n", (int)pd.num_free_vertices() ); const size_t numSlaveVert = pd.num_slave_vertices(); // 0 const size_t numCoin = pd.num_corners(); // 64 const MsqVertex* coord = pd.get_vertex_array( err ); MSQ_PRINT( 3 )( "Number of Vertices: %d\n", (int)pd.num_nodes() ); std::cout << "Patch " << numNode << " " << numVert << " " << numSlaveVert << " " << numCoin << std::endl; MSQ_PRINT( 3 )( "\n" ); std::cout << "Coordinate "; std::cout << " " << std::endl; for( size_t index = 0; index < numVert; index++ ) { std::cout << coord[index][0] << " " << coord[index][1] << " " << coord[index][2] << std::endl; } // const size_t numElt = pd.num_elements(); if( mNonGradDebug >= 3 ) { std::cout << "Number of Elements: " << pd.num_elements() << std::endl; } MSQ_PRINT( 3 )( "Number of Elements: %d\n", (int)pd.num_elements() ); }
void MBMesquite::NonGradient::printSimplex | ( | std::vector< double > & | p_simplex, |
std::vector< double > & | p_height | ||
) | [private] |
Definition at line 248 of file NonGradient.cpp.
References getDimension().
{ int numRow = getDimension(); int numCol = numRow + 1; for( int col = 0; col < numCol; col++ ) { // std::cout << "simplex[ " << col << "]= " ; for( int row = 0; row < numRow; row++ ) { std::cout << p_simplex[row + col * numRow] << " "; } // std::cout << " " << p_height[col] << std::endl; } for( int col = 0; col < numCol; col++ ) { std::cout << p_height[col] << " "; } std::cout << std::endl; }
MESQUITE_EXPORT bool MBMesquite::NonGradient::project_gradient | ( | ) | const [inline] |
Definition at line 68 of file NonGradient.hpp.
References projectGradient.
{ return projectGradient; }
MESQUITE_EXPORT void MBMesquite::NonGradient::project_gradient | ( | bool | yesno | ) | [inline] |
Definition at line 74 of file NonGradient.hpp.
{ projectGradient = yesno; }
MESQUITE_EXPORT void MBMesquite::NonGradient::set_debugging_level | ( | int | level | ) | [inline] |
Obtain diagnostic data during optimization off=level 0, ... level 3 = maximal
Definition at line 137 of file NonGradient.hpp.
Referenced by main(), and NonGradient().
{ mNonGradDebug = level; }
void MBMesquite::NonGradient::setDimension | ( | int | dimension | ) | [inline] |
Definition at line 99 of file NonGradient.hpp.
{ mDimension = dimension; }
void MBMesquite::NonGradient::setExactPenaltyFunction | ( | bool | exactPenalty | ) | [inline] |
Definition at line 115 of file NonGradient.hpp.
References mUseExactPenaltyFunction.
Referenced by main().
{ mUseExactPenaltyFunction = exactPenalty; }
void MBMesquite::NonGradient::setMaxNumEval | ( | int | maxNumEval | ) | [inline] |
Definition at line 111 of file NonGradient.hpp.
References mMaxNumEval.
{ mMaxNumEval = maxNumEval; }
void MBMesquite::NonGradient::setSimplexDiameterScale | ( | double | newScaleDiameter | ) | [inline] |
Definition at line 119 of file NonGradient.hpp.
{ mScaleDiameter = newScaleDiameter; }
void MBMesquite::NonGradient::setThreshold | ( | double | threshold | ) | [inline] |
Definition at line 103 of file NonGradient.hpp.
References mThreshold.
{ mThreshold = threshold; }
void MBMesquite::NonGradient::terminate_mesh_iteration | ( | PatchData & | pd, |
Definition at line 505 of file NonGradient.cpp.
{ if( mNonGradDebug >= 2 ) { std::cout << "- Executing NonGradient::iteration_complete()" << std::endl; } // MSQ_PRINT(2)("\n - Executing NonGradient::iteration_complete() \n"); }
bool MBMesquite::NonGradient::testRowSum | ( | int | numRow, |
int | numCol, | ||
double * | matrix, | ||
double * | rowSum | ||
Definition at line 107 of file NonGradient.cpp.
References mNonGradDebug, and MSQ_PRINT.
{ bool same = true; std::vector< double > rowSum( numRow, 0. ); double maxVal = 0.; for( int col = 0; col < numCol; col++ ) { for( int row = 0; row < numRow; row++ ) { rowSum[row] += matrix[row + col * numRow]; if( fabs( matrix[row + col * numRow] ) > maxVal ) { maxVal = fabs( matrix[row + col * numRow] ); } } } double machEps = 1.e-14 * static_cast< double >( numRow ); // better to use system parameters double upperBound = machEps * maxVal + 1.e-15; for( int row = 0; row < numRow; row++ ) { if( fabs( rowSum[row] - oldRowSum[row] ) > upperBound ) { same = false; if( mNonGradDebug >= 2 ) { std::cout << " Warning: NonGradient Row Sum " << row << " Test: value " << rowSum[row] << " Discrepancy " << rowSum[row] - oldRowSum[row] << " maxVal " << maxVal << " numRow " << numRow << " numCol " << numCol << std::endl; } MSQ_PRINT( 2 ) ( "NonGradient Row Sum [%d] Test failure: value %22.15e difference %22.15e \n", row, rowSum[row], rowSum[row] - oldRowSum[row] ); } } return ( same ); }
std::vector< double > MBMesquite::NonGradient::height |
Definition at line 130 of file NonGradient.hpp.
int MBMesquite::NonGradient::mDimension [private] |
Definition at line 151 of file NonGradient.hpp.
Referenced by getDimension(), and setDimension().
int MBMesquite::NonGradient::mMaxNumEval [private] |
Definition at line 154 of file NonGradient.hpp.
Referenced by getMaxNumEval(), and setMaxNumEval().
int MBMesquite::NonGradient::mNonGradDebug [private] |
Definition at line 157 of file NonGradient.hpp.
Referenced by amotry(), cleanup(), initialize_mesh_iteration(), optimize_vertex_positions(), printPatch(), set_debugging_level(), terminate_mesh_iteration(), and testRowSum().
double MBMesquite::NonGradient::mScaleDiameter [private] |
Definition at line 159 of file NonGradient.hpp.
Referenced by getSimplexDiameterScale(), initialize_mesh_iteration(), and setSimplexDiameterScale().
double MBMesquite::NonGradient::mThreshold [private] |
Definition at line 152 of file NonGradient.hpp.
Referenced by getThreshold(), and setThreshold().
double MBMesquite::NonGradient::mTolerance [private] |
Definition at line 153 of file NonGradient.hpp.
bool MBMesquite::NonGradient::mUseExactPenaltyFunction [private] |
Definition at line 158 of file NonGradient.hpp.
Referenced by evaluate(), and setExactPenaltyFunction().
bool MBMesquite::NonGradient::projectGradient [private] |
Definition at line 150 of file NonGradient.hpp.
Referenced by project_gradient().
std::vector< double > MBMesquite::NonGradient::simplex |
Definition at line 129 of file NonGradient.hpp.
Referenced by initialize_mesh_iteration(), and optimize_vertex_positions().
