MOAB: Mesh Oriented datABase
(version 5.2.1)
Public Member Functions | |
TCTFauxOptimizer (double pertubation_amount) | |
virtual | ~TCTFauxOptimizer () |
virtual std::string | get_name () const |
Get string name for use in diagnostic and status output. | |
virtual PatchSet * | get_patch_set () |
virtual void | initialize (PatchData &pd, MsqError &err) |
virtual void | initialize_mesh_iteration (PatchData &pd, MsqError &err) |
virtual void | optimize_vertex_positions (PatchData &pd, MsqError &err) |
virtual void | terminate_mesh_iteration (PatchData &pd, MsqError &err) |
virtual void | cleanup () |
int | num_passes () const |
bool | should_have_terminated () const |
Private Attributes | |
std::set< Mesh::VertexHandle > | culled |
std::set< Mesh::VertexHandle > | visited |
std::vector< Mesh::VertexHandle > | all |
VertexPatches | mPatchSet |
int | numPasses |
count number of outer iterations | |
int | perturbFrac |
perturb 1/perturbFrac of the free vertices | |
double | mDelta |
distance to perturb vertices |
Definition at line 666 of file TerminationCriterionTest.cpp.
TCTFauxOptimizer::TCTFauxOptimizer | ( | double | pertubation_amount | ) | [inline] |
Definition at line 669 of file TerminationCriterionTest.cpp.
: mDelta( pertubation_amount ) {}
virtual TCTFauxOptimizer::~TCTFauxOptimizer | ( | ) | [inline, virtual] |
Definition at line 670 of file TerminationCriterionTest.cpp.
virtual void TCTFauxOptimizer::cleanup | ( | ) | [inline, virtual] |
Implements MBMesquite::VertexMover.
Definition at line 683 of file TerminationCriterionTest.cpp.
{ all.clear(); }
virtual std::string TCTFauxOptimizer::get_name | ( | ) | const [inline, virtual] |
Implements MBMesquite::Instruction.
Definition at line 671 of file TerminationCriterionTest.cpp.
{ return "Optimizer for TerminationCriterionTest"; }
virtual PatchSet* TCTFauxOptimizer::get_patch_set | ( | ) | [inline, virtual] |
Implements MBMesquite::QualityImprover.
Definition at line 675 of file TerminationCriterionTest.cpp.
{ return &mPatchSet; }
void TCTFauxOptimizer::initialize | ( | PatchData & | pd, |
MsqError & | err | ||
) | [virtual] |
Definition at line 705 of file TerminationCriterionTest.cpp.
References CPPUNIT_ASSERT, fixed, MBMesquite::Mesh::get_all_vertices(), MBMesquite::PatchData::get_mesh(), MSQ_ERRRTN, and MBMesquite::Mesh::vertices_get_fixed_flag().
{ CPPUNIT_ASSERT( all.empty() ); culled.clear(); visited.clear(); numPasses = 1; pd.get_mesh()->get_all_vertices( all, err );MSQ_ERRRTN( err ); std::vector< bool > fixed; pd.get_mesh()->vertices_get_fixed_flag( &all[0], fixed, all.size(), err ); size_t w = 0; for( size_t r = 0; r < all.size(); ++r ) if( !fixed[r] ) all[w++] = all[r]; all.resize( w );MSQ_ERRRTN( err ); perturbFrac = 1; }
virtual void TCTFauxOptimizer::initialize_mesh_iteration | ( | PatchData & | pd, |
int TCTFauxOptimizer::num_passes | ( | ) | const [inline] |
Definition at line 687 of file TerminationCriterionTest.cpp.
Referenced by TerminationCriterionTest::test_abs_vtx_movement_culling().
{ return numPasses; }
void TCTFauxOptimizer::optimize_vertex_positions | ( | PatchData & | pd, |
) | [virtual] |
Definition at line 723 of file TerminationCriterionTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, MBMesquite::PatchData::get_vertex_handles_array(), MBMesquite::PatchData::move_vertex(), MBMesquite::PatchData::num_nodes(), and MBMesquite::sign.
{ Mesh::VertexHandle free_vtx = pd.get_vertex_handles_array()[0]; if( visited.insert( free_vtx ).second == false ) { // already visited this one // The inner termination criterion should include an iteration limit of 1. // So if we are seeing the same vertex again, this means that we *should* // be stating a new pass over the mesh. // We are presumably starting a new pass over the mesh. // Verify that we visisted all of the free, non-culled vertices for( size_t i = 0; i < all.size(); ++i ) { if( culled.find( all[i] ) == culled.end() ) { if( visited.find( all[i] ) == visited.end() ) { std::ostringstream str; str << "Did not visit vertex " << i << " (handle " << all[i] << ") in pass " << numPasses << std::endl; CPPUNIT_FAIL( str.str() ); } } } visited.clear(); visited.insert( free_vtx ); ++numPasses; // Check that we terminate when expected CPPUNIT_ASSERT( !should_have_terminated() ); perturbFrac *= 2; // for each pass, perturb half as many vertices } // check that we are not visiting a culled vertex CPPUNIT_ASSERT( culled.find( free_vtx ) == culled.end() ); // for each pass, perturb half as many vertices size_t idx = std::find( all.begin(), all.end(), free_vtx ) - all.begin(); CPPUNIT_ASSERT( idx < all.size() ); // not a free vertex???? if( 0 == ( ( idx + 1 ) % perturbFrac ) ) { // perturb vertex double sign = numPasses % 2 == 0 ? 1 : -1; Vector3D delta( sign * mDelta, 0, 0 ); pd.move_vertex( delta, 0, err ); ASSERT_NO_ERROR( err ); // any adjacent vertices should not be culled for( size_t i = 0; i < pd.num_nodes(); ++i ) culled.erase( pd.get_vertex_handles_array()[i] ); } else { // If we're not moving this vertex, then it should get culled culled.insert( free_vtx ); } }
bool TCTFauxOptimizer::should_have_terminated | ( | ) | const [inline] |
Definition at line 691 of file TerminationCriterionTest.cpp.
{ return perturbFrac > (int)all.size(); }
virtual void TCTFauxOptimizer::terminate_mesh_iteration | ( | PatchData & | pd, |
std::vector< Mesh::VertexHandle > TCTFauxOptimizer::all [private] |
Definition at line 698 of file TerminationCriterionTest.cpp.
std::set< Mesh::VertexHandle > TCTFauxOptimizer::culled [private] |
Definition at line 697 of file TerminationCriterionTest.cpp.
double TCTFauxOptimizer::mDelta [private] |
Definition at line 702 of file TerminationCriterionTest.cpp.
VertexPatches TCTFauxOptimizer::mPatchSet [private] |
Definition at line 699 of file TerminationCriterionTest.cpp.
int TCTFauxOptimizer::numPasses [private] |
Definition at line 700 of file TerminationCriterionTest.cpp.
int TCTFauxOptimizer::perturbFrac [private] |
Definition at line 701 of file TerminationCriterionTest.cpp.
std::set< Mesh::VertexHandle > TCTFauxOptimizer::visited [private] |
