MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2009 Benoit Jacob <[email protected]> 00005 // 00006 // This Source Code Form is subject to the terms of the Mozilla 00007 // Public License v. 2.0. If a copy of the MPL was not distributed 00008 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00009 00010 #ifndef EIGEN_MISC_KERNEL_H 00011 #define EIGEN_MISC_KERNEL_H 00012 00013 namespace Eigen { 00014 00015 namespace internal { 00016 00020 template<typename DecompositionType> 00021 struct traits<kernel_retval_base<DecompositionType> > 00022 { 00023 typedef typename DecompositionType::MatrixType MatrixType; 00024 typedef Matrix< 00025 typename MatrixType::Scalar, 00026 MatrixType::ColsAtCompileTime, // the number of rows in the "kernel matrix" 00027 // is the number of cols of the original matrix 00028 // so that the product "matrix * kernel = zero" makes sense 00029 Dynamic, // we don't know at compile-time the dimension of the kernel 00030 MatrixType::Options, 00031 MatrixType::MaxColsAtCompileTime, // see explanation for 2nd template parameter 00032 MatrixType::MaxColsAtCompileTime // the kernel is a subspace of the domain space, 00033 // whose dimension is the number of columns of the original matrix 00034 > ReturnType; 00035 }; 00036 00037 template<typename _DecompositionType> struct kernel_retval_base 00038 : public ReturnByValue<kernel_retval_base<_DecompositionType> > 00039 { 00040 typedef _DecompositionType DecompositionType; 00041 typedef ReturnByValue<kernel_retval_base> Base; 00042 00043 explicit kernel_retval_base(const DecompositionType& dec) 00044 : m_dec(dec), 00045 m_rank(dec.rank()), 00046 m_cols(m_rank==dec.cols() ? 1 : dec.cols() - m_rank) 00047 {} 00048 00049 inline Index rows() const { return m_dec.cols(); } 00050 inline Index cols() const { return m_cols; } 00051 inline Index rank() const { return m_rank; } 00052 inline const DecompositionType& dec() const { return m_dec; } 00053 00054 template<typename Dest> inline void evalTo(Dest& dst) const 00055 { 00056 static_cast<const kernel_retval<DecompositionType>*>(this)->evalTo(dst); 00057 } 00058 00059 protected: 00060 const DecompositionType& m_dec; 00061 Index m_rank, m_cols; 00062 }; 00063 00064 } // end namespace internal 00065 00066 #define EIGEN_MAKE_KERNEL_HELPERS(DecompositionType) \ 00067 typedef typename DecompositionType::MatrixType MatrixType; \ 00068 typedef typename MatrixType::Scalar Scalar; \ 00069 typedef typename MatrixType::RealScalar RealScalar; \ 00070 typedef Eigen::internal::kernel_retval_base<DecompositionType> Base; \ 00071 using Base::dec; \ 00072 using Base::rank; \ 00073 using Base::rows; \ 00074 using Base::cols; \ 00075 kernel_retval(const DecompositionType& p_dec) : Base(p_dec) {} 00076 00077 } // end namespace Eigen 00078 00079 #endif // EIGEN_MISC_KERNEL_H
