MOAB
4.9.3pre
The matrix class, also used for vectors and row-vectors. More...
#include <Matrix.h>
Public Types | |
| enum | { Options = _Options } |
| typedef PlainObjectBase< Matrix > | Base |
| Base class typedef. | |
| typedef Base::PlainObject | PlainObject |
Public Member Functions | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Matrix & | operator= (const Matrix &other) |
| Assigns matrices to each other. | |
| template<typename OtherDerived > | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Matrix & | operator= (const DenseBase< OtherDerived > &other) |
Copies the value of the expression other into *this with automatic resizing. | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Matrix & | operator= (const EigenBase< OtherDerived > &other) |
| Copies the generic expression other into *this. | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Matrix & | operator= (const ReturnByValue< OtherDerived > &func) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Matrix () |
| Default constructor. | |
| EIGEN_DEVICE_FUNC | Matrix (internal::constructor_without_unaligned_array_assert) |
| template<typename T > | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Matrix (const T &x) |
| template<typename T0 , typename T1 > | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Matrix (const T0 &x, const T1 &y) |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Matrix (const Scalar &x, const Scalar &y, const Scalar &z) |
| Constructs an initialized 3D vector with given coefficients. | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Matrix (const Scalar &x, const Scalar &y, const Scalar &z, const Scalar &w) |
| Constructs an initialized 4D vector with given coefficients. | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Matrix (const Matrix &other) |
| Copy constructor. | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE | Matrix (const EigenBase< OtherDerived > &other) |
| Copy constructor for generic expressions. | |
| EIGEN_DEVICE_FUNC Index | innerStride () const |
| EIGEN_DEVICE_FUNC Index | outerStride () const |
| EIGEN_DEVICE_FUNC | Matrix (const RotationBase< OtherDerived, ColsAtCompileTime > &r) |
| Constructs a Dim x Dim rotation matrix from the rotation r. | |
| EIGEN_DEVICE_FUNC Matrix & | operator= (const RotationBase< OtherDerived, ColsAtCompileTime > &r) |
| Set a Dim x Dim rotation matrix from the rotation r. | |
Friends | |
| struct | internal::conservative_resize_like_impl |
The Matrix class is the work-horse for all dense (note) matrices and vectors within Eigen. Vectors are matrices with one column, and row-vectors are matrices with one row.
The Matrix class encompasses both fixed-size and dynamic-size objects (note).
The first three template parameters are required:
| _Scalar | Numeric type, e.g. float, double, int or std::complex<float>. User defined scalar types are supported as well (see here). |
| _Rows | Number of rows, or Dynamic |
| _Cols | Number of columns, or Dynamic |
The remaining template parameters are optional -- in most cases you don't have to worry about them.
| _Options | A combination of either RowMajor or ColMajor, and of either AutoAlign or DontAlign. The former controls storage order, and defaults to column-major. The latter controls alignment, which is required for vectorization. It defaults to aligning matrices except for fixed sizes that aren't a multiple of the packet size. |
| _MaxRows | Maximum number of rows. Defaults to _Rows (note). |
| _MaxCols | Maximum number of columns. Defaults to _Cols (note). |
Eigen provides a number of typedefs covering the usual cases. Here are some examples:
Matrix2d is a 2x2 square matrix of doubles (Matrix<double, 2, 2>) Vector4f is a vector of 4 floats (Matrix<float, 4, 1>) RowVector3i is a row-vector of 3 ints (Matrix<int, 1, 3>)MatrixXf is a dynamic-size matrix of floats (Matrix<float, Dynamic, Dynamic>) VectorXf is a dynamic-size vector of floats (Matrix<float, Dynamic, 1>)Matrix2Xf is a partially fixed-size (dynamic-size) matrix of floats (Matrix<float, 2, Dynamic>) MatrixX3d is a partially dynamic-size (fixed-size) matrix of double (Matrix<double, Dynamic, 3>)See this page for a complete list of predefined Matrix and Vector typedefs.
You can access elements of vectors and matrices using normal subscripting:
Eigen::VectorXd v(10); v[0] = 0.1; v[1] = 0.2; v(0) = 0.3; v(1) = 0.4; Eigen::MatrixXi m(10, 10); m(0, 1) = 1; m(0, 2) = 2; m(0, 3) = 3;
This class can be extended with the help of the plugin mechanism described on the page TopicCustomizingEigen by defining the preprocessor symbol EIGEN_MATRIX_PLUGIN.
Some notes:
This Matrix class handles dense, not sparse matrices and vectors. For sparse matrices and vectors, see the Sparse module.
Dense matrices and vectors are plain usual arrays of coefficients. All the coefficients are stored, in an ordinary contiguous array. This is unlike Sparse matrices and vectors where the coefficients are stored as a list of nonzero coefficients.
Fixed-size means that the numbers of rows and columns are known are compile-time. In this case, Eigen allocates the array of coefficients as a fixed-size array, as a class member. This makes sense for very small matrices, typically up to 4x4, sometimes up to 16x16. Larger matrices should be declared as dynamic-size even if one happens to know their size at compile-time.
Dynamic-size means that the numbers of rows or columns are not necessarily known at compile-time. In this case they are runtime variables, and the array of coefficients is allocated dynamically on the heap.
Note that dense matrices, be they Fixed-size or Dynamic-size, do not expand dynamically in the sense of a std::map. If you want this behavior, see the Sparse module.
ABI and storage layout
The table below summarizes the ABI of some possible Matrix instances which is fixed thorough the lifetime of Eigen 3.
| Matrix type | Equivalent C structure |
Matrix<T,Dynamic,Dynamic> | struct { T *data; // with (size_t(data)%EIGEN_MAX_ALIGN_BYTES)==0 Eigen::Index rows, cols; }; |
Matrix<T,Dynamic,1> Matrix<T,1,Dynamic> | struct { T *data; // with (size_t(data)%EIGEN_MAX_ALIGN_BYTES)==0 Eigen::Index size; }; |
Matrix<T,Rows,Cols> | |
Matrix<T,Dynamic,Dynamic,0,MaxRows,MaxCols> | struct { T data[MaxRows*MaxCols]; // with (size_t(data)%A(MaxRows*MaxCols*sizeof(T)))==0 Eigen::Index rows, cols; }; |
Note that in this table Rows, Cols, MaxRows and MaxCols are all positive integers. A(S) is defined to the largest possible power-of-two smaller to EIGEN_MAX_STATIC_ALIGN_BYTES.
| typedef PlainObjectBase<Matrix> Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Base |
Base class typedef.
Reimplemented from Eigen::PlainObjectBase< Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols > >.
| typedef Base::PlainObject Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::PlainObject |
| anonymous enum |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Matrix | ( | ) | [inline] |
For fixed-size matrices, does nothing.
For dynamic-size matrices, creates an empty matrix of size 0. Does not allocate any array. Such a matrix is called a null matrix. This constructor is the unique way to create null matrices: resizing a matrix to 0 is not supported.
| EIGEN_DEVICE_FUNC Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Matrix | ( | internal::constructor_without_unaligned_array_assert | ) | [inline, explicit] |
Definition at line 267 of file Matrix.h.
: Base(internal::constructor_without_unaligned_array_assert()) { Base::_check_template_params(); EIGEN_INITIALIZE_COEFFS_IF_THAT_OPTION_IS_ENABLED }
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Matrix | ( | const T & | x | ) | [inline, explicit] |
Definition at line 293 of file Matrix.h.
Base::template _init1<T>(x);
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Matrix | ( | const T0 & | x, |
| const T1 & | y | ||
| ) | [inline] |
Definition at line 301 of file Matrix.h.
Base::template _init2<T0,T1>(x, y);
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Matrix | ( | const Scalar & | x, |
| const Scalar & | y, | ||
| const Scalar & | z | ||
| ) | [inline] |
| const Scalar & | z, | ||
| const Scalar & | w | ||
| ) | [inline] |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Matrix | ( | const Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols > & | other | ) | [inline] |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::Matrix | ( | const EigenBase< OtherDerived > & | other | ) | [inline] |
| Eigen::Matrix< _Scalar, _Rows, _Cols, _Storage, _MaxRows, _MaxCols >::Matrix | ( | const RotationBase< OtherDerived, ColsAtCompileTime > & | r | ) | [explicit] |
Definition at line 141 of file RotationBase.h.
EIGEN_STATIC_ASSERT_MATRIX_SPECIFIC_SIZE(Matrix,int(OtherDerived::Dim),int(OtherDerived::Dim))
*this = r.toRotationMatrix();
| EIGEN_DEVICE_FUNC Index Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::innerStride | ( | ) | const [inline] |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Matrix& Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::operator= | ( | const Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols > & | other | ) | [inline] |
Definition at line 206 of file Matrix.h.
return Base::_set(other);
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Matrix& Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::operator= | ( | const DenseBase< OtherDerived > & | other | ) | [inline] |
*this might be resized to match the dimensions of other. If *this was a null matrix (not already initialized), it will be initialized.
Note that copying a row-vector into a vector (and conversely) is allowed. The resizing, if any, is then done in the appropriate way so that row-vectors remain row-vectors and vectors remain vectors.
Definition at line 223 of file Matrix.h.
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Matrix& Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::operator= | ( | const EigenBase< OtherDerived > & | other | ) | [inline] |
The expression must provide a (templated) evalTo(Derived& dst) const function which does the actual job. In practice, this allows any user to write its own special matrix without having to modify MatrixBase
Definition at line 236 of file Matrix.h.
return Base::operator=(other);
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Matrix& Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::operator= | ( | const ReturnByValue< OtherDerived > & | func | ) | [inline] |
Definition at line 243 of file Matrix.h.
return Base::operator=(func);
| Matrix< _Scalar, _Rows, _Cols, _Storage, _MaxRows, _MaxCols > & Eigen::Matrix< _Scalar, _Rows, _Cols, _Storage, _MaxRows, _MaxCols >::operator= | ( | const RotationBase< OtherDerived, ColsAtCompileTime > & | r | ) |
Definition at line 155 of file RotationBase.h.
return *this = r.toRotationMatrix();
| EIGEN_DEVICE_FUNC Index Eigen::Matrix< _Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols >::outerStride | ( | ) | const [inline] |
friend struct internal::conservative_resize_like_impl [friend] |
