MOAB
4.9.3pre
#include <PlainObjectBase.h>
Static Public Member Functions | |
| static void | run (DenseBase< Derived > &_this, Index rows, Index cols) |
| static void | run (DenseBase< Derived > &_this, const DenseBase< OtherDerived > &other) |
Definition at line 881 of file PlainObjectBase.h.
| static void Eigen::internal::conservative_resize_like_impl< Derived, OtherDerived, IsVector >::run | ( | DenseBase< Derived > & | _this, |
| Index | rows, | ||
| Index | cols | ||
| ) | [inline, static] |
Definition at line 883 of file PlainObjectBase.h.
if (_this.rows() == rows && _this.cols() == cols) return;
EIGEN_STATIC_ASSERT_DYNAMIC_SIZE(Derived)
if ( ( Derived::IsRowMajor && _this.cols() == cols) || // row-major and we change only the number of rows
(!Derived::IsRowMajor && _this.rows() == rows) ) // column-major and we change only the number of columns
internal::check_rows_cols_for_overflow<Derived::MaxSizeAtCompileTime>::run(rows, cols);
_this.derived().m_storage.conservativeResize(rows*cols,rows,cols);
else
// The storage order does not allow us to use reallocation.
typename Derived::PlainObject tmp(rows,cols);
const Index common_rows = (std::min)(rows, _this.rows());
const Index common_cols = (std::min)(cols, _this.cols());
tmp.block(0,0,common_rows,common_cols) = _this.block(0,0,common_rows,common_cols);
_this.derived().swap(tmp);
| const DenseBase< OtherDerived > & | other | ||
Reimplemented in Eigen::internal::conservative_resize_like_impl< Derived, OtherDerived, true >.
Definition at line 905 of file PlainObjectBase.h.
if (_this.rows() == other.rows() && _this.cols() == other.cols()) return;
// Note: Here is space for improvement. Basically, for conservativeResize(Index,Index),
// neither RowsAtCompileTime or ColsAtCompileTime must be Dynamic. If only one of the
// dimensions is dynamic, one could use either conservativeResize(Index rows, NoChange_t) or
// conservativeResize(NoChange_t, Index cols). For these methods new static asserts like
// EIGEN_STATIC_ASSERT_DYNAMIC_ROWS and EIGEN_STATIC_ASSERT_DYNAMIC_COLS would be good.
EIGEN_STATIC_ASSERT_DYNAMIC_SIZE(OtherDerived)
if ( ( Derived::IsRowMajor && _this.cols() == other.cols()) || // row-major and we change only the number of rows
(!Derived::IsRowMajor && _this.rows() == other.rows()) ) // column-major and we change only the number of columns
const Index new_rows = other.rows() - _this.rows();
const Index new_cols = other.cols() - _this.cols();
_this.derived().m_storage.conservativeResize(other.size(),other.rows(),other.cols());
if (new_rows>0)
_this.bottomRightCorner(new_rows, other.cols()) = other.bottomRows(new_rows);
else if (new_cols>0)
_this.bottomRightCorner(other.rows(), new_cols) = other.rightCols(new_cols);
else
typename Derived::PlainObject tmp(other);
const Index common_rows = (std::min)(tmp.rows(), _this.rows());
const Index common_cols = (std::min)(tmp.cols(), _this.cols());
