MOAB
4.9.3pre
| #define EIGEN_INTERNAL_CHECK_COST_VALUE | ( | C | ) | EIGEN_STATIC_ASSERT((C)>=0 && (C)<=HugeCost*HugeCost, EIGEN_INTERNAL_ERROR_PLEASE_FILE_A_BUG_REPORT__INVALID_COST_VALUE); |
Definition at line 210 of file StaticAssert.h.
| #define EIGEN_PREDICATE_SAME_MATRIX_SIZE | ( | TYPE0, | |
| TYPE1 | |||
(int(internal::size_of_xpr_at_compile_time<TYPE0>::ret)==0 && int(internal::size_of_xpr_at_compile_time<TYPE1>::ret)==0) \
(int(TYPE0::RowsAtCompileTime)==Eigen::Dynamic \
|| int(TYPE1::RowsAtCompileTime)==Eigen::Dynamic \
|| int(TYPE0::RowsAtCompileTime)==int(TYPE1::RowsAtCompileTime)) \
&& (int(TYPE0::ColsAtCompileTime)==Eigen::Dynamic \
|| int(TYPE1::ColsAtCompileTime)==Eigen::Dynamic \
|| int(TYPE0::ColsAtCompileTime)==int(TYPE1::ColsAtCompileTime))\
Definition at line 166 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT | ( | CONDITION, | |
| MSG | |||
| ) | if (Eigen::internal::static_assertion<static_cast<bool>(CONDITION)>::MSG) {} |
Definition at line 119 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_ARRAYXPR | ( | Derived | ) |
EIGEN_STATIC_ASSERT((internal::is_same<typename internal::traits<Derived>::XprKind, ArrayXpr>::value), \ THIS_METHOD_IS_ONLY_FOR_ARRAYS_NOT_MATRICES)
Definition at line 198 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_DYNAMIC_SIZE | ( | TYPE | ) |
EIGEN_STATIC_ASSERT(TYPE::SizeAtCompileTime==Eigen::Dynamic, \ YOU_CALLED_A_DYNAMIC_SIZE_METHOD_ON_A_FIXED_SIZE_MATRIX_OR_VECTOR)
Definition at line 144 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_FIXED_SIZE | ( | TYPE | ) |
EIGEN_STATIC_ASSERT(TYPE::SizeAtCompileTime!=Eigen::Dynamic, \ YOU_CALLED_A_FIXED_SIZE_METHOD_ON_A_DYNAMIC_SIZE_MATRIX_OR_VECTOR)
Definition at line 139 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_LVALUE | ( | Derived | ) |
EIGEN_STATIC_ASSERT(internal::is_lvalue<Derived>::value, \ THIS_EXPRESSION_IS_NOT_A_LVALUE__IT_IS_READ_ONLY)
Definition at line 194 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_MATRIX_SPECIFIC_SIZE | ( | TYPE, | |
| ROWS, | |||
| COLS | |||
EIGEN_STATIC_ASSERT(TYPE::RowsAtCompileTime==ROWS && TYPE::ColsAtCompileTime==COLS, \ THIS_METHOD_IS_ONLY_FOR_MATRICES_OF_A_SPECIFIC_SIZE)
Definition at line 154 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_NON_INTEGER | ( | TYPE | ) | EIGEN_STATIC_ASSERT(!NumTraits<TYPE>::IsInteger, THIS_FUNCTION_IS_NOT_FOR_INTEGER_NUMERIC_TYPES) |
Definition at line 179 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_SAME_MATRIX_SIZE | ( | TYPE0, | |
| TYPE1 | |||
EIGEN_STATIC_ASSERT( \ EIGEN_PREDICATE_SAME_MATRIX_SIZE(TYPE0,TYPE1),\ YOU_MIXED_MATRICES_OF_DIFFERENT_SIZES)
Definition at line 184 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_SAME_VECTOR_SIZE | ( | TYPE0, | |
| TYPE1 | |||
EIGEN_STATIC_ASSERT( \ (int(TYPE0::SizeAtCompileTime)==Eigen::Dynamic \ || int(TYPE1::SizeAtCompileTime)==Eigen::Dynamic \ || int(TYPE0::SizeAtCompileTime)==int(TYPE1::SizeAtCompileTime)),\ YOU_MIXED_VECTORS_OF_DIFFERENT_SIZES)
Definition at line 159 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_SAME_XPR_KIND | ( | Derived1, | |
| Derived2 | |||
EIGEN_STATIC_ASSERT((internal::is_same<typename internal::traits<Derived1>::XprKind, \ typename internal::traits<Derived2>::XprKind \ >::value), \ YOU_CANNOT_MIX_ARRAYS_AND_MATRICES)
Definition at line 202 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_SIZE_1x1 | ( | TYPE | ) |
EIGEN_STATIC_ASSERT((TYPE::RowsAtCompileTime == 1 || TYPE::RowsAtCompileTime == Dynamic) && \ (TYPE::ColsAtCompileTime == 1 || TYPE::ColsAtCompileTime == Dynamic), \ THIS_METHOD_IS_ONLY_FOR_1x1_EXPRESSIONS)
Definition at line 189 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_VECTOR_ONLY | ( | TYPE | ) |
EIGEN_STATIC_ASSERT(TYPE::IsVectorAtCompileTime, \ YOU_TRIED_CALLING_A_VECTOR_METHOD_ON_A_MATRIX)
Definition at line 134 of file StaticAssert.h.
| #define EIGEN_STATIC_ASSERT_VECTOR_SPECIFIC_SIZE | ( | TYPE, | |
| SIZE | |||
EIGEN_STATIC_ASSERT(TYPE::IsVectorAtCompileTime && TYPE::SizeAtCompileTime==SIZE, \ THIS_METHOD_IS_ONLY_FOR_VECTORS_OF_A_SPECIFIC_SIZE)
Definition at line 149 of file StaticAssert.h.
