MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2008 Gael Guennebaud <[email protected]> 00005 // Copyright (C) 2008 Benoit Jacob <[email protected]> 00006 // 00007 // This Source Code Form is subject to the terms of the Mozilla 00008 // Public License v. 2.0. If a copy of the MPL was not distributed 00009 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00010 00011 #ifndef EIGEN_STATIC_ASSERT_H 00012 #define EIGEN_STATIC_ASSERT_H 00013 00014 /* Some notes on Eigen's static assertion mechanism: 00015 * 00016 * - in EIGEN_STATIC_ASSERT(CONDITION,MSG) the parameter CONDITION must be a compile time boolean 00017 * expression, and MSG an enum listed in struct internal::static_assertion<true> 00018 * 00019 * - define EIGEN_NO_STATIC_ASSERT to disable them (and save compilation time) 00020 * in that case, the static assertion is converted to the following runtime assert: 00021 * eigen_assert(CONDITION && "MSG") 00022 * 00023 * - currently EIGEN_STATIC_ASSERT can only be used in function scope 00024 * 00025 */ 00026 00027 #ifndef EIGEN_NO_STATIC_ASSERT 00028 00029 #if __has_feature(cxx_static_assert) || (defined(__cplusplus) && __cplusplus >= 201103L) || (EIGEN_COMP_MSVC >= 1600) 00030 00031 // if native static_assert is enabled, let's use it 00032 #define EIGEN_STATIC_ASSERT(X,MSG) static_assert(X,#MSG); 00033 00034 #else // not CXX0X 00035 00036 namespace Eigen { 00037 00038 namespace internal { 00039 00040 template<bool condition> 00041 struct static_assertion {}; 00042 00043 template<> 00044 struct static_assertion<true> 00045 { 00046 enum { 00047 YOU_TRIED_CALLING_A_VECTOR_METHOD_ON_A_MATRIX, 00048 YOU_MIXED_VECTORS_OF_DIFFERENT_SIZES, 00049 YOU_MIXED_MATRICES_OF_DIFFERENT_SIZES, 00050 THIS_METHOD_IS_ONLY_FOR_VECTORS_OF_A_SPECIFIC_SIZE, 00051 THIS_METHOD_IS_ONLY_FOR_MATRICES_OF_A_SPECIFIC_SIZE, 00052 THIS_METHOD_IS_ONLY_FOR_OBJECTS_OF_A_SPECIFIC_SIZE, 00053 OUT_OF_RANGE_ACCESS, 00054 YOU_MADE_A_PROGRAMMING_MISTAKE, 00055 EIGEN_INTERNAL_ERROR_PLEASE_FILE_A_BUG_REPORT, 00056 EIGEN_INTERNAL_COMPILATION_ERROR_OR_YOU_MADE_A_PROGRAMMING_MISTAKE, 00057 YOU_CALLED_A_FIXED_SIZE_METHOD_ON_A_DYNAMIC_SIZE_MATRIX_OR_VECTOR, 00058 YOU_CALLED_A_DYNAMIC_SIZE_METHOD_ON_A_FIXED_SIZE_MATRIX_OR_VECTOR, 00059 UNALIGNED_LOAD_AND_STORE_OPERATIONS_UNIMPLEMENTED_ON_ALTIVEC, 00060 THIS_FUNCTION_IS_NOT_FOR_INTEGER_NUMERIC_TYPES, 00061 FLOATING_POINT_ARGUMENT_PASSED__INTEGER_WAS_EXPECTED, 00062 NUMERIC_TYPE_MUST_BE_REAL, 00063 COEFFICIENT_WRITE_ACCESS_TO_SELFADJOINT_NOT_SUPPORTED, 00064 WRITING_TO_TRIANGULAR_PART_WITH_UNIT_DIAGONAL_IS_NOT_SUPPORTED, 00065 THIS_METHOD_IS_ONLY_FOR_FIXED_SIZE, 00066 INVALID_MATRIX_PRODUCT, 00067 INVALID_VECTOR_VECTOR_PRODUCT__IF_YOU_WANTED_A_DOT_OR_COEFF_WISE_PRODUCT_YOU_MUST_USE_THE_EXPLICIT_FUNCTIONS, 00068 INVALID_MATRIX_PRODUCT__IF_YOU_WANTED_A_COEFF_WISE_PRODUCT_YOU_MUST_USE_THE_EXPLICIT_FUNCTION, 00069 YOU_MIXED_DIFFERENT_NUMERIC_TYPES__YOU_NEED_TO_USE_THE_CAST_METHOD_OF_MATRIXBASE_TO_CAST_NUMERIC_TYPES_EXPLICITLY, 00070 THIS_METHOD_IS_ONLY_FOR_COLUMN_MAJOR_MATRICES, 00071 THIS_METHOD_IS_ONLY_FOR_ROW_MAJOR_MATRICES, 00072 INVALID_MATRIX_TEMPLATE_PARAMETERS, 00073 INVALID_MATRIXBASE_TEMPLATE_PARAMETERS, 00074 BOTH_MATRICES_MUST_HAVE_THE_SAME_STORAGE_ORDER, 00075 THIS_METHOD_IS_ONLY_FOR_DIAGONAL_MATRIX, 00076 THE_MATRIX_OR_EXPRESSION_THAT_YOU_PASSED_DOES_NOT_HAVE_THE_EXPECTED_TYPE, 00077 THIS_METHOD_IS_ONLY_FOR_EXPRESSIONS_WITH_DIRECT_MEMORY_ACCESS_SUCH_AS_MAP_OR_PLAIN_MATRICES, 00078 YOU_ALREADY_SPECIFIED_THIS_STRIDE, 00079 INVALID_STORAGE_ORDER_FOR_THIS_VECTOR_EXPRESSION, 00080 THE_BRACKET_OPERATOR_IS_ONLY_FOR_VECTORS__USE_THE_PARENTHESIS_OPERATOR_INSTEAD, 00081 PACKET_ACCESS_REQUIRES_TO_HAVE_INNER_STRIDE_FIXED_TO_1, 00082 THIS_METHOD_IS_ONLY_FOR_SPECIFIC_TRANSFORMATIONS, 00083 YOU_CANNOT_MIX_ARRAYS_AND_MATRICES, 00084 YOU_PERFORMED_AN_INVALID_TRANSFORMATION_CONVERSION, 00085 THIS_EXPRESSION_IS_NOT_A_LVALUE__IT_IS_READ_ONLY, 00086 YOU_ARE_TRYING_TO_USE_AN_INDEX_BASED_ACCESSOR_ON_AN_EXPRESSION_THAT_DOES_NOT_SUPPORT_THAT, 00087 THIS_METHOD_IS_ONLY_FOR_1x1_EXPRESSIONS, 00088 THIS_METHOD_IS_ONLY_FOR_INNER_OR_LAZY_PRODUCTS, 00089 THIS_METHOD_IS_ONLY_FOR_EXPRESSIONS_OF_BOOL, 00090 THIS_METHOD_IS_ONLY_FOR_ARRAYS_NOT_MATRICES, 00091 YOU_PASSED_A_ROW_VECTOR_BUT_A_COLUMN_VECTOR_WAS_EXPECTED, 00092 YOU_PASSED_A_COLUMN_VECTOR_BUT_A_ROW_VECTOR_WAS_EXPECTED, 00093 THE_INDEX_TYPE_MUST_BE_A_SIGNED_TYPE, 00094 THE_STORAGE_ORDER_OF_BOTH_SIDES_MUST_MATCH, 00095 OBJECT_ALLOCATED_ON_STACK_IS_TOO_BIG, 00096 IMPLICIT_CONVERSION_TO_SCALAR_IS_FOR_INNER_PRODUCT_ONLY, 00097 STORAGE_LAYOUT_DOES_NOT_MATCH, 00098 EIGEN_INTERNAL_ERROR_PLEASE_FILE_A_BUG_REPORT__INVALID_COST_VALUE, 00099 THIS_COEFFICIENT_ACCESSOR_TAKING_ONE_ACCESS_IS_ONLY_FOR_EXPRESSIONS_ALLOWING_LINEAR_ACCESS, 00100 MATRIX_FREE_CONJUGATE_GRADIENT_IS_COMPATIBLE_WITH_UPPER_UNION_LOWER_MODE_ONLY, 00101 THIS_TYPE_IS_NOT_SUPPORTED 00102 }; 00103 }; 00104 00105 } // end namespace internal 00106 00107 } // end namespace Eigen 00108 00109 // Specialized implementation for MSVC to avoid "conditional 00110 // expression is constant" warnings. This implementation doesn't 00111 // appear to work under GCC, hence the multiple implementations. 00112 #if EIGEN_COMP_MSVC 00113 00114 #define EIGEN_STATIC_ASSERT(CONDITION,MSG) \ 00115 {Eigen::internal::static_assertion<bool(CONDITION)>::MSG;} 00116 00117 #else 00118 // In some cases clang interprets bool(CONDITION) as function declaration 00119 #define EIGEN_STATIC_ASSERT(CONDITION,MSG) \ 00120 if (Eigen::internal::static_assertion<static_cast<bool>(CONDITION)>::MSG) {} 00121 00122 #endif 00123 00124 #endif // not CXX0X 00125 00126 #else // EIGEN_NO_STATIC_ASSERT 00127 00128 #define EIGEN_STATIC_ASSERT(CONDITION,MSG) eigen_assert((CONDITION) && #MSG); 00129 00130 #endif // EIGEN_NO_STATIC_ASSERT 00131 00132 00133 // static assertion failing if the type \a TYPE is not a vector type 00134 #define EIGEN_STATIC_ASSERT_VECTOR_ONLY(TYPE) \ 00135 EIGEN_STATIC_ASSERT(TYPE::IsVectorAtCompileTime, \ 00136 YOU_TRIED_CALLING_A_VECTOR_METHOD_ON_A_MATRIX) 00137 00138 // static assertion failing if the type \a TYPE is not fixed-size 00139 #define EIGEN_STATIC_ASSERT_FIXED_SIZE(TYPE) \ 00140 EIGEN_STATIC_ASSERT(TYPE::SizeAtCompileTime!=Eigen::Dynamic, \ 00141 YOU_CALLED_A_FIXED_SIZE_METHOD_ON_A_DYNAMIC_SIZE_MATRIX_OR_VECTOR) 00142 00143 // static assertion failing if the type \a TYPE is not dynamic-size 00144 #define EIGEN_STATIC_ASSERT_DYNAMIC_SIZE(TYPE) \ 00145 EIGEN_STATIC_ASSERT(TYPE::SizeAtCompileTime==Eigen::Dynamic, \ 00146 YOU_CALLED_A_DYNAMIC_SIZE_METHOD_ON_A_FIXED_SIZE_MATRIX_OR_VECTOR) 00147 00148 // static assertion failing if the type \a TYPE is not a vector type of the given size 00149 #define EIGEN_STATIC_ASSERT_VECTOR_SPECIFIC_SIZE(TYPE, SIZE) \ 00150 EIGEN_STATIC_ASSERT(TYPE::IsVectorAtCompileTime && TYPE::SizeAtCompileTime==SIZE, \ 00151 THIS_METHOD_IS_ONLY_FOR_VECTORS_OF_A_SPECIFIC_SIZE) 00152 00153 // static assertion failing if the type \a TYPE is not a vector type of the given size 00154 #define EIGEN_STATIC_ASSERT_MATRIX_SPECIFIC_SIZE(TYPE, ROWS, COLS) \ 00155 EIGEN_STATIC_ASSERT(TYPE::RowsAtCompileTime==ROWS && TYPE::ColsAtCompileTime==COLS, \ 00156 THIS_METHOD_IS_ONLY_FOR_MATRICES_OF_A_SPECIFIC_SIZE) 00157 00158 // static assertion failing if the two vector expression types are not compatible (same fixed-size or dynamic size) 00159 #define EIGEN_STATIC_ASSERT_SAME_VECTOR_SIZE(TYPE0,TYPE1) \ 00160 EIGEN_STATIC_ASSERT( \ 00161 (int(TYPE0::SizeAtCompileTime)==Eigen::Dynamic \ 00162 || int(TYPE1::SizeAtCompileTime)==Eigen::Dynamic \ 00163 || int(TYPE0::SizeAtCompileTime)==int(TYPE1::SizeAtCompileTime)),\ 00164 YOU_MIXED_VECTORS_OF_DIFFERENT_SIZES) 00165 00166 #define EIGEN_PREDICATE_SAME_MATRIX_SIZE(TYPE0,TYPE1) \ 00167 ( \ 00168 (int(internal::size_of_xpr_at_compile_time<TYPE0>::ret)==0 && int(internal::size_of_xpr_at_compile_time<TYPE1>::ret)==0) \ 00169 || (\ 00170 (int(TYPE0::RowsAtCompileTime)==Eigen::Dynamic \ 00171 || int(TYPE1::RowsAtCompileTime)==Eigen::Dynamic \ 00172 || int(TYPE0::RowsAtCompileTime)==int(TYPE1::RowsAtCompileTime)) \ 00173 && (int(TYPE0::ColsAtCompileTime)==Eigen::Dynamic \ 00174 || int(TYPE1::ColsAtCompileTime)==Eigen::Dynamic \ 00175 || int(TYPE0::ColsAtCompileTime)==int(TYPE1::ColsAtCompileTime))\ 00176 ) \ 00177 ) 00178 00179 #define EIGEN_STATIC_ASSERT_NON_INTEGER(TYPE) \ 00180 EIGEN_STATIC_ASSERT(!NumTraits<TYPE>::IsInteger, THIS_FUNCTION_IS_NOT_FOR_INTEGER_NUMERIC_TYPES) 00181 00182 00183 // static assertion failing if it is guaranteed at compile-time that the two matrix expression types have different sizes 00184 #define EIGEN_STATIC_ASSERT_SAME_MATRIX_SIZE(TYPE0,TYPE1) \ 00185 EIGEN_STATIC_ASSERT( \ 00186 EIGEN_PREDICATE_SAME_MATRIX_SIZE(TYPE0,TYPE1),\ 00187 YOU_MIXED_MATRICES_OF_DIFFERENT_SIZES) 00188 00189 #define EIGEN_STATIC_ASSERT_SIZE_1x1(TYPE) \ 00190 EIGEN_STATIC_ASSERT((TYPE::RowsAtCompileTime == 1 || TYPE::RowsAtCompileTime == Dynamic) && \ 00191 (TYPE::ColsAtCompileTime == 1 || TYPE::ColsAtCompileTime == Dynamic), \ 00192 THIS_METHOD_IS_ONLY_FOR_1x1_EXPRESSIONS) 00193 00194 #define EIGEN_STATIC_ASSERT_LVALUE(Derived) \ 00195 EIGEN_STATIC_ASSERT(internal::is_lvalue<Derived>::value, \ 00196 THIS_EXPRESSION_IS_NOT_A_LVALUE__IT_IS_READ_ONLY) 00197 00198 #define EIGEN_STATIC_ASSERT_ARRAYXPR(Derived) \ 00199 EIGEN_STATIC_ASSERT((internal::is_same<typename internal::traits<Derived>::XprKind, ArrayXpr>::value), \ 00200 THIS_METHOD_IS_ONLY_FOR_ARRAYS_NOT_MATRICES) 00201 00202 #define EIGEN_STATIC_ASSERT_SAME_XPR_KIND(Derived1, Derived2) \ 00203 EIGEN_STATIC_ASSERT((internal::is_same<typename internal::traits<Derived1>::XprKind, \ 00204 typename internal::traits<Derived2>::XprKind \ 00205 >::value), \ 00206 YOU_CANNOT_MIX_ARRAYS_AND_MATRICES) 00207 00208 // Check that a cost value is positive, and that is stay within a reasonable range 00209 // TODO this check could be enabled for internal debugging only 00210 #define EIGEN_INTERNAL_CHECK_COST_VALUE(C) \ 00211 EIGEN_STATIC_ASSERT((C)>=0 && (C)<=HugeCost*HugeCost, EIGEN_INTERNAL_ERROR_PLEASE_FILE_A_BUG_REPORT__INVALID_COST_VALUE); 00212 00213 #endif // EIGEN_STATIC_ASSERT_H
