MOAB
4.9.3pre
#include <StaticAssert.h>
Definition at line 44 of file StaticAssert.h.
| anonymous enum |
Definition at line 46 of file StaticAssert.h.
YOU_TRIED_CALLING_A_VECTOR_METHOD_ON_A_MATRIX,
YOU_MIXED_VECTORS_OF_DIFFERENT_SIZES,
YOU_MIXED_MATRICES_OF_DIFFERENT_SIZES,
THIS_METHOD_IS_ONLY_FOR_VECTORS_OF_A_SPECIFIC_SIZE,
THIS_METHOD_IS_ONLY_FOR_MATRICES_OF_A_SPECIFIC_SIZE,
THIS_METHOD_IS_ONLY_FOR_OBJECTS_OF_A_SPECIFIC_SIZE,
OUT_OF_RANGE_ACCESS,
YOU_MADE_A_PROGRAMMING_MISTAKE,
EIGEN_INTERNAL_ERROR_PLEASE_FILE_A_BUG_REPORT,
EIGEN_INTERNAL_COMPILATION_ERROR_OR_YOU_MADE_A_PROGRAMMING_MISTAKE,
YOU_CALLED_A_FIXED_SIZE_METHOD_ON_A_DYNAMIC_SIZE_MATRIX_OR_VECTOR,
YOU_CALLED_A_DYNAMIC_SIZE_METHOD_ON_A_FIXED_SIZE_MATRIX_OR_VECTOR,
UNALIGNED_LOAD_AND_STORE_OPERATIONS_UNIMPLEMENTED_ON_ALTIVEC,
THIS_FUNCTION_IS_NOT_FOR_INTEGER_NUMERIC_TYPES,
FLOATING_POINT_ARGUMENT_PASSED__INTEGER_WAS_EXPECTED,
NUMERIC_TYPE_MUST_BE_REAL,
COEFFICIENT_WRITE_ACCESS_TO_SELFADJOINT_NOT_SUPPORTED,
WRITING_TO_TRIANGULAR_PART_WITH_UNIT_DIAGONAL_IS_NOT_SUPPORTED,
THIS_METHOD_IS_ONLY_FOR_FIXED_SIZE,
INVALID_MATRIX_PRODUCT,
INVALID_VECTOR_VECTOR_PRODUCT__IF_YOU_WANTED_A_DOT_OR_COEFF_WISE_PRODUCT_YOU_MUST_USE_THE_EXPLICIT_FUNCTIONS,
INVALID_MATRIX_PRODUCT__IF_YOU_WANTED_A_COEFF_WISE_PRODUCT_YOU_MUST_USE_THE_EXPLICIT_FUNCTION,
YOU_MIXED_DIFFERENT_NUMERIC_TYPES__YOU_NEED_TO_USE_THE_CAST_METHOD_OF_MATRIXBASE_TO_CAST_NUMERIC_TYPES_EXPLICITLY,
THIS_METHOD_IS_ONLY_FOR_COLUMN_MAJOR_MATRICES,
THIS_METHOD_IS_ONLY_FOR_ROW_MAJOR_MATRICES,
INVALID_MATRIX_TEMPLATE_PARAMETERS,
INVALID_MATRIXBASE_TEMPLATE_PARAMETERS,
BOTH_MATRICES_MUST_HAVE_THE_SAME_STORAGE_ORDER,
THIS_METHOD_IS_ONLY_FOR_DIAGONAL_MATRIX,
THE_MATRIX_OR_EXPRESSION_THAT_YOU_PASSED_DOES_NOT_HAVE_THE_EXPECTED_TYPE,
THIS_METHOD_IS_ONLY_FOR_EXPRESSIONS_WITH_DIRECT_MEMORY_ACCESS_SUCH_AS_MAP_OR_PLAIN_MATRICES,
YOU_ALREADY_SPECIFIED_THIS_STRIDE,
INVALID_STORAGE_ORDER_FOR_THIS_VECTOR_EXPRESSION,
THE_BRACKET_OPERATOR_IS_ONLY_FOR_VECTORS__USE_THE_PARENTHESIS_OPERATOR_INSTEAD,
PACKET_ACCESS_REQUIRES_TO_HAVE_INNER_STRIDE_FIXED_TO_1,
THIS_METHOD_IS_ONLY_FOR_SPECIFIC_TRANSFORMATIONS,
YOU_CANNOT_MIX_ARRAYS_AND_MATRICES,
YOU_PERFORMED_AN_INVALID_TRANSFORMATION_CONVERSION,
THIS_EXPRESSION_IS_NOT_A_LVALUE__IT_IS_READ_ONLY,
YOU_ARE_TRYING_TO_USE_AN_INDEX_BASED_ACCESSOR_ON_AN_EXPRESSION_THAT_DOES_NOT_SUPPORT_THAT,
THIS_METHOD_IS_ONLY_FOR_1x1_EXPRESSIONS,
THIS_METHOD_IS_ONLY_FOR_INNER_OR_LAZY_PRODUCTS,
THIS_METHOD_IS_ONLY_FOR_EXPRESSIONS_OF_BOOL,
THIS_METHOD_IS_ONLY_FOR_ARRAYS_NOT_MATRICES,
YOU_PASSED_A_ROW_VECTOR_BUT_A_COLUMN_VECTOR_WAS_EXPECTED,
YOU_PASSED_A_COLUMN_VECTOR_BUT_A_ROW_VECTOR_WAS_EXPECTED,
THE_INDEX_TYPE_MUST_BE_A_SIGNED_TYPE,
THE_STORAGE_ORDER_OF_BOTH_SIDES_MUST_MATCH,
OBJECT_ALLOCATED_ON_STACK_IS_TOO_BIG,
IMPLICIT_CONVERSION_TO_SCALAR_IS_FOR_INNER_PRODUCT_ONLY,
STORAGE_LAYOUT_DOES_NOT_MATCH,
EIGEN_INTERNAL_ERROR_PLEASE_FILE_A_BUG_REPORT__INVALID_COST_VALUE,
THIS_COEFFICIENT_ACCESSOR_TAKING_ONE_ACCESS_IS_ONLY_FOR_EXPRESSIONS_ALLOWING_LINEAR_ACCESS,
MATRIX_FREE_CONJUGATE_GRADIENT_IS_COMPATIBLE_WITH_UPPER_UNION_LOWER_MODE_ONLY,
THIS_TYPE_IS_NOT_SUPPORTED
