MOAB
4.9.3pre
Main Page
Related Pages
Modules
Namespaces
Classes
Files
Examples
Class List
Class Index
Class Hierarchy
Class Members
Eigen::internal::static_assertion< true > Member List
This is the complete list of members for
, including all inherited members.
BOTH_MATRICES_MUST_HAVE_THE_SAME_STORAGE_ORDER
enum value
COEFFICIENT_WRITE_ACCESS_TO_SELFADJOINT_NOT_SUPPORTED
enum value
EIGEN_INTERNAL_COMPILATION_ERROR_OR_YOU_MADE_A_PROGRAMMING_MISTAKE
enum value
EIGEN_INTERNAL_ERROR_PLEASE_FILE_A_BUG_REPORT
enum value
EIGEN_INTERNAL_ERROR_PLEASE_FILE_A_BUG_REPORT__INVALID_COST_VALUE
enum value
FLOATING_POINT_ARGUMENT_PASSED__INTEGER_WAS_EXPECTED
enum value
IMPLICIT_CONVERSION_TO_SCALAR_IS_FOR_INNER_PRODUCT_ONLY
enum value
INVALID_MATRIX_PRODUCT
enum value
INVALID_MATRIX_PRODUCT__IF_YOU_WANTED_A_COEFF_WISE_PRODUCT_YOU_MUST_USE_THE_EXPLICIT_FUNCTION
enum value
INVALID_MATRIX_TEMPLATE_PARAMETERS
enum value
INVALID_MATRIXBASE_TEMPLATE_PARAMETERS
enum value
INVALID_STORAGE_ORDER_FOR_THIS_VECTOR_EXPRESSION
enum value
INVALID_VECTOR_VECTOR_PRODUCT__IF_YOU_WANTED_A_DOT_OR_COEFF_WISE_PRODUCT_YOU_MUST_USE_THE_EXPLICIT_FUNCTIONS
enum value
MATRIX_FREE_CONJUGATE_GRADIENT_IS_COMPATIBLE_WITH_UPPER_UNION_LOWER_MODE_ONLY
enum value
NUMERIC_TYPE_MUST_BE_REAL
enum value
OBJECT_ALLOCATED_ON_STACK_IS_TOO_BIG
enum value
OUT_OF_RANGE_ACCESS
enum value
PACKET_ACCESS_REQUIRES_TO_HAVE_INNER_STRIDE_FIXED_TO_1
enum value
STORAGE_LAYOUT_DOES_NOT_MATCH
enum value
THE_BRACKET_OPERATOR_IS_ONLY_FOR_VECTORS__USE_THE_PARENTHESIS_OPERATOR_INSTEAD
enum value
THE_INDEX_TYPE_MUST_BE_A_SIGNED_TYPE
enum value
THE_MATRIX_OR_EXPRESSION_THAT_YOU_PASSED_DOES_NOT_HAVE_THE_EXPECTED_TYPE
enum value
THE_STORAGE_ORDER_OF_BOTH_SIDES_MUST_MATCH
enum value
THIS_COEFFICIENT_ACCESSOR_TAKING_ONE_ACCESS_IS_ONLY_FOR_EXPRESSIONS_ALLOWING_LINEAR_ACCESS
enum value
THIS_EXPRESSION_IS_NOT_A_LVALUE__IT_IS_READ_ONLY
enum value
THIS_FUNCTION_IS_NOT_FOR_INTEGER_NUMERIC_TYPES
enum value
THIS_METHOD_IS_ONLY_FOR_1x1_EXPRESSIONS
enum value
THIS_METHOD_IS_ONLY_FOR_ARRAYS_NOT_MATRICES
enum value
THIS_METHOD_IS_ONLY_FOR_COLUMN_MAJOR_MATRICES
enum value
THIS_METHOD_IS_ONLY_FOR_DIAGONAL_MATRIX
enum value
THIS_METHOD_IS_ONLY_FOR_EXPRESSIONS_OF_BOOL
enum value
THIS_METHOD_IS_ONLY_FOR_EXPRESSIONS_WITH_DIRECT_MEMORY_ACCESS_SUCH_AS_MAP_OR_PLAIN_MATRICES
enum value
THIS_METHOD_IS_ONLY_FOR_FIXED_SIZE
enum value
THIS_METHOD_IS_ONLY_FOR_INNER_OR_LAZY_PRODUCTS
enum value
THIS_METHOD_IS_ONLY_FOR_MATRICES_OF_A_SPECIFIC_SIZE
enum value
THIS_METHOD_IS_ONLY_FOR_OBJECTS_OF_A_SPECIFIC_SIZE
enum value
THIS_METHOD_IS_ONLY_FOR_ROW_MAJOR_MATRICES
enum value
THIS_METHOD_IS_ONLY_FOR_SPECIFIC_TRANSFORMATIONS
enum value
THIS_METHOD_IS_ONLY_FOR_VECTORS_OF_A_SPECIFIC_SIZE
enum value
THIS_TYPE_IS_NOT_SUPPORTED
enum value
UNALIGNED_LOAD_AND_STORE_OPERATIONS_UNIMPLEMENTED_ON_ALTIVEC
enum value
WRITING_TO_TRIANGULAR_PART_WITH_UNIT_DIAGONAL_IS_NOT_SUPPORTED
enum value
YOU_ALREADY_SPECIFIED_THIS_STRIDE
enum value
YOU_ARE_TRYING_TO_USE_AN_INDEX_BASED_ACCESSOR_ON_AN_EXPRESSION_THAT_DOES_NOT_SUPPORT_THAT
enum value
YOU_CALLED_A_DYNAMIC_SIZE_METHOD_ON_A_FIXED_SIZE_MATRIX_OR_VECTOR
enum value
YOU_CALLED_A_FIXED_SIZE_METHOD_ON_A_DYNAMIC_SIZE_MATRIX_OR_VECTOR
enum value
YOU_CANNOT_MIX_ARRAYS_AND_MATRICES
enum value
enum value
YOU_MIXED_DIFFERENT_NUMERIC_TYPES__YOU_NEED_TO_USE_THE_CAST_METHOD_OF_MATRIXBASE_TO_CAST_NUMERIC_TYPES_EXPLICITLY
enum value
YOU_MIXED_MATRICES_OF_DIFFERENT_SIZES
enum value
YOU_MIXED_VECTORS_OF_DIFFERENT_SIZES
enum value
YOU_PASSED_A_COLUMN_VECTOR_BUT_A_ROW_VECTOR_WAS_EXPECTED
enum value
YOU_PASSED_A_ROW_VECTOR_BUT_A_COLUMN_VECTOR_WAS_EXPECTED
enum value
YOU_PERFORMED_AN_INVALID_TRANSFORMATION_CONVERSION
enum value
YOU_TRIED_CALLING_A_VECTOR_METHOD_ON_A_MATRIX
enum value
All
Classes
Namespaces
Files
Functions
Variables
Typedefs
Enumerations
Enumerator
Friends
Defines
Generated on Fri Apr 7 2017 01:08:33 for MOAB by
1.7.6.1
