MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2006-2010 Benoit Jacob <[email protected]> 00005 // Copyright (C) 2008-2009 Gael Guennebaud <[email protected]> 00006 // 00007 // This Source Code Form is subject to the terms of the Mozilla 00008 // Public License v. 2.0. If a copy of the MPL was not distributed 00009 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00010 00011 #ifndef EIGEN_MATRIX_H 00012 #define EIGEN_MATRIX_H 00013 00014 namespace Eigen { 00015 00016 namespace internal { 00017 template<typename _Scalar, int _Rows, int _Cols, int _Options, int _MaxRows, int _MaxCols> 00018 struct traits<Matrix<_Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols> > 00019 { 00020 private: 00021 enum { size = internal::size_at_compile_time<_Rows,_Cols>::ret }; 00022 typedef typename find_best_packet<_Scalar,size>::type PacketScalar; 00023 enum { 00024 row_major_bit = _Options&RowMajor ? RowMajorBit : 0, 00025 is_dynamic_size_storage = _MaxRows==Dynamic || _MaxCols==Dynamic, 00026 max_size = is_dynamic_size_storage ? Dynamic : _MaxRows*_MaxCols, 00027 default_alignment = compute_default_alignment<_Scalar,max_size>::value, 00028 actual_alignment = ((_Options&DontAlign)==0) ? default_alignment : 0, 00029 required_alignment = unpacket_traits<PacketScalar>::alignment, 00030 packet_access_bit = packet_traits<_Scalar>::Vectorizable && (actual_alignment>=required_alignment) ? PacketAccessBit : 0 00031 }; 00032 00033 public: 00034 typedef _Scalar Scalar; 00035 typedef Dense StorageKind; 00036 typedef Eigen::Index StorageIndex; 00037 typedef MatrixXpr XprKind; 00038 enum { 00039 RowsAtCompileTime = _Rows, 00040 ColsAtCompileTime = _Cols, 00041 MaxRowsAtCompileTime = _MaxRows, 00042 MaxColsAtCompileTime = _MaxCols, 00043 Flags = compute_matrix_flags<_Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols>::ret, 00044 Options = _Options, 00045 InnerStrideAtCompileTime = 1, 00046 OuterStrideAtCompileTime = (Options&RowMajor) ? ColsAtCompileTime : RowsAtCompileTime, 00047 00048 // FIXME, the following flag in only used to define NeedsToAlign in PlainObjectBase 00049 EvaluatorFlags = LinearAccessBit | DirectAccessBit | packet_access_bit | row_major_bit, 00050 Alignment = actual_alignment 00051 }; 00052 }; 00053 } 00054 00177 template<typename _Scalar, int _Rows, int _Cols, int _Options, int _MaxRows, int _MaxCols> 00178 class Matrix 00179 : public PlainObjectBase<Matrix<_Scalar, _Rows, _Cols, _Options, _MaxRows, _MaxCols> > 00180 { 00181 public: 00182 00186 typedef PlainObjectBase<Matrix> Base; 00187 00188 enum { Options = _Options }; 00189 00190 EIGEN_DENSE_PUBLIC_INTERFACE(Matrix) 00191 00192 typedef typename Base::PlainObject PlainObject; 00193 00194 using Base::base; 00195 using Base::coeffRef; 00196 00205 EIGEN_DEVICE_FUNC 00206 EIGEN_STRONG_INLINE Matrix& operator=(const Matrix& other) 00207 { 00208 return Base::_set(other); 00209 } 00210 00221 template<typename OtherDerived> 00222 EIGEN_DEVICE_FUNC 00223 EIGEN_STRONG_INLINE Matrix& operator=(const DenseBase<OtherDerived>& other) 00224 { 00225 return Base::_set(other); 00226 } 00227 00228 /* Here, doxygen failed to copy the brief information when using \copydoc */ 00229 00234 template<typename OtherDerived> 00235 EIGEN_DEVICE_FUNC 00236 EIGEN_STRONG_INLINE Matrix& operator=(const EigenBase<OtherDerived> &other) 00237 { 00238 return Base::operator=(other); 00239 } 00240 00241 template<typename OtherDerived> 00242 EIGEN_DEVICE_FUNC 00243 EIGEN_STRONG_INLINE Matrix& operator=(const ReturnByValue<OtherDerived>& func) 00244 { 00245 return Base::operator=(func); 00246 } 00247 00258 EIGEN_DEVICE_FUNC 00259 EIGEN_STRONG_INLINE Matrix() : Base() 00260 { 00261 Base::_check_template_params(); 00262 EIGEN_INITIALIZE_COEFFS_IF_THAT_OPTION_IS_ENABLED 00263 } 00264 00265 // FIXME is it still needed 00266 EIGEN_DEVICE_FUNC 00267 explicit Matrix(internal::constructor_without_unaligned_array_assert) 00268 : Base(internal::constructor_without_unaligned_array_assert()) 00269 { Base::_check_template_params(); EIGEN_INITIALIZE_COEFFS_IF_THAT_OPTION_IS_ENABLED } 00270 00271 #ifdef EIGEN_HAVE_RVALUE_REFERENCES 00272 EIGEN_DEVICE_FUNC 00273 Matrix(Matrix&& other) 00274 : Base(std::move(other)) 00275 { 00276 Base::_check_template_params(); 00277 if (RowsAtCompileTime!=Dynamic && ColsAtCompileTime!=Dynamic) 00278 Base::_set_noalias(other); 00279 } 00280 EIGEN_DEVICE_FUNC 00281 Matrix& operator=(Matrix&& other) 00282 { 00283 other.swap(*this); 00284 return *this; 00285 } 00286 #endif 00287 00288 #ifndef EIGEN_PARSED_BY_DOXYGEN 00289 00290 // This constructor is for both 1x1 matrices and dynamic vectors 00291 template<typename T> 00292 EIGEN_DEVICE_FUNC 00293 EIGEN_STRONG_INLINE explicit Matrix(const T& x) 00294 { 00295 Base::_check_template_params(); 00296 Base::template _init1<T>(x); 00297 } 00298 00299 template<typename T0, typename T1> 00300 EIGEN_DEVICE_FUNC 00301 EIGEN_STRONG_INLINE Matrix(const T0& x, const T1& y) 00302 { 00303 Base::_check_template_params(); 00304 Base::template _init2<T0,T1>(x, y); 00305 } 00306 #else 00307 00308 EIGEN_DEVICE_FUNC 00309 explicit Matrix(const Scalar *data); 00310 00323 EIGEN_STRONG_INLINE explicit Matrix(Index dim); 00325 Matrix(const Scalar& x); 00338 EIGEN_DEVICE_FUNC 00339 Matrix(Index rows, Index cols); 00340 00342 Matrix(const Scalar& x, const Scalar& y); 00343 #endif 00344 00346 EIGEN_DEVICE_FUNC 00347 EIGEN_STRONG_INLINE Matrix(const Scalar& x, const Scalar& y, const Scalar& z) 00348 { 00349 Base::_check_template_params(); 00350 EIGEN_STATIC_ASSERT_VECTOR_SPECIFIC_SIZE(Matrix, 3) 00351 m_storage.data()[0] = x; 00352 m_storage.data()[1] = y; 00353 m_storage.data()[2] = z; 00354 } 00356 EIGEN_DEVICE_FUNC 00357 EIGEN_STRONG_INLINE Matrix(const Scalar& x, const Scalar& y, const Scalar& z, const Scalar& w) 00358 { 00359 Base::_check_template_params(); 00360 EIGEN_STATIC_ASSERT_VECTOR_SPECIFIC_SIZE(Matrix, 4) 00361 m_storage.data()[0] = x; 00362 m_storage.data()[1] = y; 00363 m_storage.data()[2] = z; 00364 m_storage.data()[3] = w; 00365 } 00366 00367 00369 EIGEN_DEVICE_FUNC 00370 EIGEN_STRONG_INLINE Matrix(const Matrix& other) : Base(other) 00371 { } 00372 00376 template<typename OtherDerived> 00377 EIGEN_DEVICE_FUNC 00378 EIGEN_STRONG_INLINE Matrix(const EigenBase<OtherDerived> &other) 00379 : Base(other.derived()) 00380 { } 00381 00382 EIGEN_DEVICE_FUNC inline Index innerStride() const { return 1; } 00383 EIGEN_DEVICE_FUNC inline Index outerStride() const { return this->innerSize(); } 00384 00386 00387 template<typename OtherDerived> 00388 EIGEN_DEVICE_FUNC 00389 explicit Matrix(const RotationBase<OtherDerived,ColsAtCompileTime>& r); 00390 template<typename OtherDerived> 00391 EIGEN_DEVICE_FUNC 00392 Matrix& operator=(const RotationBase<OtherDerived,ColsAtCompileTime>& r); 00393 00394 // allow to extend Matrix outside Eigen 00395 #ifdef EIGEN_MATRIX_PLUGIN 00396 #include EIGEN_MATRIX_PLUGIN 00397 #endif 00398 00399 protected: 00400 template <typename Derived, typename OtherDerived, bool IsVector> 00401 friend struct internal::conservative_resize_like_impl; 00402 00403 using Base::m_storage; 00404 }; 00405 00426 #define EIGEN_MAKE_TYPEDEFS(Type, TypeSuffix, Size, SizeSuffix) \ 00427 \ 00428 typedef Matrix<Type, Size, Size> Matrix##SizeSuffix##TypeSuffix; \ 00429 \ 00430 typedef Matrix<Type, Size, 1> Vector##SizeSuffix##TypeSuffix; \ 00431 \ 00432 typedef Matrix<Type, 1, Size> RowVector##SizeSuffix##TypeSuffix; 00433 00434 #define EIGEN_MAKE_FIXED_TYPEDEFS(Type, TypeSuffix, Size) \ 00435 \ 00436 typedef Matrix<Type, Size, Dynamic> Matrix##Size##X##TypeSuffix; \ 00437 \ 00438 typedef Matrix<Type, Dynamic, Size> Matrix##X##Size##TypeSuffix; 00439 00440 #define EIGEN_MAKE_TYPEDEFS_ALL_SIZES(Type, TypeSuffix) \ 00441 EIGEN_MAKE_TYPEDEFS(Type, TypeSuffix, 2, 2) \ 00442 EIGEN_MAKE_TYPEDEFS(Type, TypeSuffix, 3, 3) \ 00443 EIGEN_MAKE_TYPEDEFS(Type, TypeSuffix, 4, 4) \ 00444 EIGEN_MAKE_TYPEDEFS(Type, TypeSuffix, Dynamic, X) \ 00445 EIGEN_MAKE_FIXED_TYPEDEFS(Type, TypeSuffix, 2) \ 00446 EIGEN_MAKE_FIXED_TYPEDEFS(Type, TypeSuffix, 3) \ 00447 EIGEN_MAKE_FIXED_TYPEDEFS(Type, TypeSuffix, 4) 00448 00449 EIGEN_MAKE_TYPEDEFS_ALL_SIZES(int, i) 00450 EIGEN_MAKE_TYPEDEFS_ALL_SIZES(float, f) 00451 EIGEN_MAKE_TYPEDEFS_ALL_SIZES(double, d) 00452 EIGEN_MAKE_TYPEDEFS_ALL_SIZES(std::complex<float>, cf) 00453 EIGEN_MAKE_TYPEDEFS_ALL_SIZES(std::complex<double>, cd) 00454 00455 #undef EIGEN_MAKE_TYPEDEFS_ALL_SIZES 00456 #undef EIGEN_MAKE_TYPEDEFS 00457 #undef EIGEN_MAKE_FIXED_TYPEDEFS 00458 00459 } // end namespace Eigen 00460 00461 #endif // EIGEN_MATRIX_H
