MOAB
4.9.3pre
Variables | |
| const unsigned int | Eigen::RowMajorBit = 0x1 |
| const unsigned int | Eigen::EvalBeforeNestingBit = 0x2 |
| EIGEN_DEPRECATED const unsigned int | Eigen::EvalBeforeAssigningBit = 0x4 |
| const unsigned int | Eigen::PacketAccessBit = 0x8 |
| const unsigned int | Eigen::LinearAccessBit = 0x10 |
| const unsigned int | Eigen::LvalueBit = 0x20 |
| const unsigned int | Eigen::DirectAccessBit = 0x40 |
| EIGEN_DEPRECATED const unsigned int | Eigen::AlignedBit = 0x80 |
| const unsigned int | Eigen::NoPreferredStorageOrderBit = 0x200 |
| const unsigned int | Eigen::CompressedAccessBit = 0x400 |
These are the possible bits which can be OR'ed to constitute the flags of a matrix or expression.
It is important to note that these flags are a purely compile-time notion. They are a compile-time property of an expression type, implemented as enum's. They are not stored in memory at runtime, and they do not incur any runtime overhead.
| EIGEN_DEPRECATED const unsigned int Eigen::AlignedBit = 0x80 |
expression.packet<Aligned>(0);
Definition at line 162 of file Constants.h.
| const unsigned int Eigen::CompressedAccessBit = 0x400 |
Means that the underlying coefficients can be accessed through pointers to the sparse (un)compressed storage format, that is, the expression provides:
inline const Scalar* valuePtr() const; inline const Index* innerIndexPtr() const; inline const Index* outerIndexPtr() const; inline const Index* innerNonZeroPtr() const;
Definition at line 186 of file Constants.h.
| const unsigned int Eigen::DirectAccessBit = 0x40 |
Means that the underlying array of coefficients can be directly accessed as a plain strided array. The memory layout of the array of coefficients must be exactly the natural one suggested by rows(), cols(), outerStride(), innerStride(), and the RowMajorBit. This rules out expressions such as Diagonal, whose coefficients, though referencable, do not have such a regular memory layout.
See the comment on LvalueBit for an explanation of how LvalueBit and DirectAccessBit are mutually orthogonal.
Definition at line 150 of file Constants.h.
| EIGEN_DEPRECATED const unsigned int Eigen::EvalBeforeAssigningBit = 0x4 |
Definition at line 71 of file Constants.h.
| const unsigned int Eigen::EvalBeforeNestingBit = 0x2 |
means the expression should be evaluated by the calling expression
Definition at line 65 of file Constants.h.
| const unsigned int Eigen::LinearAccessBit = 0x10 |
Short version: means the expression can be seen as 1D vector.
Long version: means that one can access the coefficients of this expression by coeff(int), and coeffRef(int) in the case of a lvalue expression. These index-based access methods are guaranteed to not have to do any runtime computation of a (row, col)-pair from the index, so that it is guaranteed that whenever it is available, index-based access is at least as fast as (row,col)-based access. Expressions for which that isn't possible don't have the LinearAccessBit.
If both PacketAccessBit and LinearAccessBit are set, then the packets of this expression can be accessed by packet(int), and writePacket(int) in the case of a lvalue expression.
Typically, all vector expressions have the LinearAccessBit, but there is one exception: Product expressions don't have it, because it would be troublesome for vectorization, even when the Product is a vector expression. Thus, vector Product expressions allow index-based coefficient access but not index-based packet access, so they don't have the LinearAccessBit.
Definition at line 125 of file Constants.h.
| const unsigned int Eigen::LvalueBit = 0x20 |
Means the expression has a coeffRef() method, i.e. is writable as its individual coefficients are directly addressable. This rules out read-only expressions.
Note that DirectAccessBit and LvalueBit are mutually orthogonal, as there are examples of expression having one but note the other:
Expressions having LvalueBit also have their coeff() method returning a const reference instead of returning a new value.
Definition at line 139 of file Constants.h.
| const unsigned int Eigen::NoPreferredStorageOrderBit = 0x200 |
for an expression, this means that the storage order can be either row-major or column-major. The precise choice will be decided at evaluation time or when combined with other expressions.
Definition at line 173 of file Constants.h.
| const unsigned int Eigen::PacketAccessBit = 0x8 |
Short version: means the expression might be vectorized
Long version: means that the coefficients can be handled by packets and start at a memory location whose alignment meets the requirements of the present CPU architecture for optimized packet access. In the fixed-size case, there is the additional condition that it be possible to access all the coefficients by packets (this implies the requirement that the size be a multiple of 16 bytes, and that any nontrivial strides don't break the alignment). In the dynamic-size case, there is no such condition on the total size and strides, so it might not be possible to access all coeffs by packets.
Definition at line 89 of file Constants.h.
| const unsigned int Eigen::RowMajorBit = 0x1 |
for a matrix, this means that the storage order is row-major. If this bit is not set, the storage order is column-major. For an expression, this determines the storage order of the matrix created by evaluation of that expression.
Definition at line 61 of file Constants.h.
