MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2008-2015 Gael Guennebaud <[email protected]> 00005 // Copyright (C) 2007-2009 Benoit Jacob <[email protected]> 00006 // 00007 // This Source Code Form is subject to the terms of the Mozilla 00008 // Public License v. 2.0. If a copy of the MPL was not distributed 00009 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00010 00011 #ifndef EIGEN_CONSTANTS_H 00012 #define EIGEN_CONSTANTS_H 00013 00014 namespace Eigen { 00015 00021 const int Dynamic = -1; 00022 00026 const int DynamicIndex = 0xffffff; 00027 00031 const int Infinity = -1; 00032 00039 const int HugeCost = 10000; 00040 00061 const unsigned int RowMajorBit = 0x1; 00062 00065 const unsigned int EvalBeforeNestingBit = 0x2; 00066 00070 EIGEN_DEPRECATED 00071 const unsigned int EvalBeforeAssigningBit = 0x4; // FIXME deprecated 00072 00089 const unsigned int PacketAccessBit = 0x8; 00090 00091 #ifdef EIGEN_VECTORIZE 00092 00100 const unsigned int ActualPacketAccessBit = PacketAccessBit; 00101 #else 00102 const unsigned int ActualPacketAccessBit = 0x0; 00103 #endif 00104 00125 const unsigned int LinearAccessBit = 0x10; 00126 00139 const unsigned int LvalueBit = 0x20; 00140 00150 const unsigned int DirectAccessBit = 0x40; 00151 00162 EIGEN_DEPRECATED const unsigned int AlignedBit = 0x80; 00163 00164 const unsigned int NestByRefBit = 0x100; 00165 00173 const unsigned int NoPreferredStorageOrderBit = 0x200; 00174 00186 const unsigned int CompressedAccessBit = 0x400; 00187 00188 00189 // list of flags that are inherited by default 00190 const unsigned int HereditaryBits = RowMajorBit 00191 | EvalBeforeNestingBit; 00192 00202 enum { 00204 Lower=0x1, 00206 Upper=0x2, 00208 UnitDiag=0x4, 00210 ZeroDiag=0x8, 00212 UnitLower=UnitDiag|Lower, 00214 UnitUpper=UnitDiag|Upper, 00216 StrictlyLower=ZeroDiag|Lower, 00218 StrictlyUpper=ZeroDiag|Upper, 00220 SelfAdjoint=0x10, 00222 Symmetric=0x20 00223 }; 00224 00227 enum { 00228 Unaligned=0, 00229 Aligned8=8, 00230 Aligned16=16, 00231 Aligned32=32, 00232 Aligned64=64, 00233 Aligned128=128, 00234 AlignedMask=255, 00235 Aligned=16, 00236 #if EIGEN_MAX_ALIGN_BYTES==128 00237 AlignedMax = Aligned128 00238 #elif EIGEN_MAX_ALIGN_BYTES==64 00239 AlignedMax = Aligned64 00240 #elif EIGEN_MAX_ALIGN_BYTES==32 00241 AlignedMax = Aligned32 00242 #elif EIGEN_MAX_ALIGN_BYTES==16 00243 AlignedMax = Aligned16 00244 #elif EIGEN_MAX_ALIGN_BYTES==8 00245 AlignedMax = Aligned8 00246 #elif EIGEN_MAX_ALIGN_BYTES==0 00247 AlignedMax = Unaligned 00248 #else 00249 #error Invalid value for EIGEN_MAX_ALIGN_BYTES 00250 #endif 00251 }; 00252 00255 // FIXME after the corner() API change, this was not needed anymore, except by AlignedBox 00256 // TODO: find out what to do with that. Adapt the AlignedBox API ? 00257 enum CornerType { TopLeft, TopRight, BottomLeft, BottomRight }; 00258 00262 enum DirectionType { 00265 Vertical, 00268 Horizontal, 00271 BothDirections 00272 }; 00273 00276 enum { 00278 DefaultTraversal, 00280 LinearTraversal, 00283 InnerVectorizedTraversal, 00286 LinearVectorizedTraversal, 00289 SliceVectorizedTraversal, 00291 InvalidTraversal, 00293 AllAtOnceTraversal 00294 }; 00295 00298 enum { 00300 NoUnrolling, 00302 InnerUnrolling, 00305 CompleteUnrolling 00306 }; 00307 00310 enum { 00311 Specialized, 00312 BuiltIn 00313 }; 00314 00318 enum { 00320 ColMajor = 0, 00322 RowMajor = 0x1, // it is only a coincidence that this is equal to RowMajorBit -- don't rely on that 00324 AutoAlign = 0, // FIXME --- clarify the situation 00326 DontAlign = 0x2 00327 }; 00328 00331 enum { 00333 OnTheLeft = 1, 00335 OnTheRight = 2 00336 }; 00337 00338 /* the following used to be written as: 00339 * 00340 * struct NoChange_t {}; 00341 * namespace { 00342 * EIGEN_UNUSED NoChange_t NoChange; 00343 * } 00344 * 00345 * on the ground that it feels dangerous to disambiguate overloaded functions on enum/integer types. 00346 * However, this leads to "variable declared but never referenced" warnings on Intel Composer XE, 00347 * and we do not know how to get rid of them (bug 450). 00348 */ 00349 00350 enum NoChange_t { NoChange }; 00351 enum Sequential_t { Sequential }; 00352 enum Default_t { Default }; 00353 00356 enum { 00357 IsDense = 0, 00358 IsSparse 00359 }; 00360 00364 enum AccessorLevels { 00366 ReadOnlyAccessors, 00368 WriteAccessors, 00370 DirectAccessors, 00372 DirectWriteAccessors 00373 }; 00374 00377 enum DecompositionOptions { 00379 Pivoting = 0x01, 00381 NoPivoting = 0x02, 00383 ComputeFullU = 0x04, 00385 ComputeThinU = 0x08, 00387 ComputeFullV = 0x10, 00389 ComputeThinV = 0x20, 00392 EigenvaluesOnly = 0x40, 00395 ComputeEigenvectors = 0x80, 00397 EigVecMask = EigenvaluesOnly | ComputeEigenvectors, 00400 Ax_lBx = 0x100, 00403 ABx_lx = 0x200, 00406 BAx_lx = 0x400, 00408 GenEigMask = Ax_lBx | ABx_lx | BAx_lx 00409 }; 00410 00413 enum QRPreconditioners { 00415 NoQRPreconditioner, 00417 HouseholderQRPreconditioner, 00419 ColPivHouseholderQRPreconditioner, 00421 FullPivHouseholderQRPreconditioner 00422 }; 00423 00424 #ifdef Success 00425 #error The preprocessor symbol 'Success' is defined, possibly by the X11 header file X.h 00426 #endif 00427 00430 enum ComputationInfo { 00432 Success = 0, 00434 NumericalIssue = 1, 00436 NoConvergence = 2, 00439 InvalidInput = 3 00440 }; 00441 00445 enum TransformTraits { 00447 Isometry = 0x1, 00450 Affine = 0x2, 00452 AffineCompact = 0x10 | Affine, 00454 Projective = 0x20 00455 }; 00456 00459 namespace Architecture 00460 { 00461 enum Type { 00462 Generic = 0x0, 00463 SSE = 0x1, 00464 AltiVec = 0x2, 00465 VSX = 0x3, 00466 NEON = 0x4, 00467 #if defined EIGEN_VECTORIZE_SSE 00468 Target = SSE 00469 #elif defined EIGEN_VECTORIZE_ALTIVEC 00470 Target = AltiVec 00471 #elif defined EIGEN_VECTORIZE_VSX 00472 Target = VSX 00473 #elif defined EIGEN_VECTORIZE_NEON 00474 Target = NEON 00475 #else 00476 Target = Generic 00477 #endif 00478 }; 00479 } 00480 00483 enum { DefaultProduct=0, LazyProduct, AliasFreeProduct, CoeffBasedProductMode, LazyCoeffBasedProductMode, OuterProduct, InnerProduct, GemvProduct, GemmProduct }; 00484 00487 enum Action {GetAction, SetAction}; 00488 00490 struct Dense {}; 00491 00493 struct Sparse {}; 00494 00496 struct SolverStorage {}; 00497 00499 struct PermutationStorage {}; 00500 00502 struct TranspositionsStorage {}; 00503 00505 struct MatrixXpr {}; 00506 00508 struct ArrayXpr {}; 00509 00510 // An evaluator must define its shape. By default, it can be one of the following: 00511 struct DenseShape { static std::string debugName() { return "DenseShape"; } }; 00512 struct SolverShape { static std::string debugName() { return "SolverShape"; } }; 00513 struct HomogeneousShape { static std::string debugName() { return "HomogeneousShape"; } }; 00514 struct DiagonalShape { static std::string debugName() { return "DiagonalShape"; } }; 00515 struct BandShape { static std::string debugName() { return "BandShape"; } }; 00516 struct TriangularShape { static std::string debugName() { return "TriangularShape"; } }; 00517 struct SelfAdjointShape { static std::string debugName() { return "SelfAdjointShape"; } }; 00518 struct PermutationShape { static std::string debugName() { return "PermutationShape"; } }; 00519 struct TranspositionsShape { static std::string debugName() { return "TranspositionsShape"; } }; 00520 struct SparseShape { static std::string debugName() { return "SparseShape"; } }; 00521 00522 namespace internal { 00523 00524 // random access iterators based on coeff*() accessors. 00525 struct IndexBased {}; 00526 00527 // evaluator based on iterators to access coefficients. 00528 struct IteratorBased {}; 00529 00533 enum ComparisonName { 00534 cmp_EQ = 0, 00535 cmp_LT = 1, 00536 cmp_LE = 2, 00537 cmp_UNORD = 3, 00538 cmp_NEQ = 4, 00539 cmp_GT = 5, 00540 cmp_GE = 6 00541 }; 00542 } // end namespace internal 00543 00544 } // end namespace Eigen 00545 00546 #endif // EIGEN_CONSTANTS_H
