MOAB
4.9.3pre
Expression of a diagonal/subdiagonal/superdiagonal in a matrix. More...
#include <Diagonal.h>
Public Types | |
| enum | { DiagIndex = _DiagIndex } |
| typedef internal::dense_xpr_base < Diagonal >::type | Base |
| typedef internal::conditional < internal::is_lvalue < MatrixType >::value, Scalar, const Scalar >::type | ScalarWithConstIfNotLvalue |
Public Member Functions | |
| EIGEN_DEVICE_FUNC | Diagonal (MatrixType &matrix, Index a_index=DiagIndex) |
| EIGEN_DEVICE_FUNC Index | rows () const |
| EIGEN_DEVICE_FUNC Index | cols () const |
| EIGEN_DEVICE_FUNC Index | innerStride () const |
| EIGEN_DEVICE_FUNC Index | outerStride () const |
| EIGEN_DEVICE_FUNC ScalarWithConstIfNotLvalue * | data () |
| EIGEN_DEVICE_FUNC const Scalar * | data () const |
| EIGEN_DEVICE_FUNC Scalar & | coeffRef (Index row, Index) |
| EIGEN_DEVICE_FUNC const Scalar & | coeffRef (Index row, Index) const |
| EIGEN_DEVICE_FUNC CoeffReturnType | coeff (Index row, Index) const |
| EIGEN_DEVICE_FUNC Scalar & | coeffRef (Index idx) |
| EIGEN_DEVICE_FUNC const Scalar & | coeffRef (Index idx) const |
| EIGEN_DEVICE_FUNC CoeffReturnType | coeff (Index idx) const |
| EIGEN_DEVICE_FUNC const internal::remove_all< typename MatrixType::Nested >::type & | nestedExpression () const |
| EIGEN_DEVICE_FUNC Index | index () const |
Protected Attributes | |
| internal::ref_selector < MatrixType >::non_const_type | m_matrix |
| const internal::variable_if_dynamicindex < Index, DiagIndex > | m_index |
Private Member Functions | |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Index | absDiagIndex () const |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Index | rowOffset () const |
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Index | colOffset () const |
| template<int LoadMode> | |
| MatrixType::PacketReturnType | packet (Index) const |
| MatrixType::PacketReturnType | packet (Index, Index) const |
| MatrixType | the type of the object in which we are taking a sub/main/super diagonal |
| DiagIndex | the index of the sub/super diagonal. The default is 0 and it means the main diagonal. A positive value means a superdiagonal, a negative value means a subdiagonal. You can also use Dynamic so the index can be set at runtime. |
The matrix is not required to be square.
This class represents an expression of the main diagonal, or any sub/super diagonal of a square matrix. It is the return type of MatrixBase::diagonal() and MatrixBase::diagonal(Index) and most of the time this is the only way it is used.
Definition at line 63 of file Diagonal.h.
| typedef internal::dense_xpr_base<Diagonal>::type Eigen::Diagonal< MatrixType, _DiagIndex >::Base |
Definition at line 69 of file Diagonal.h.
| typedef internal::conditional< internal::is_lvalue<MatrixType>::value, Scalar, const Scalar >::type Eigen::Diagonal< MatrixType, _DiagIndex >::ScalarWithConstIfNotLvalue |
Definition at line 103 of file Diagonal.h.
| anonymous enum |
| EIGEN_DEVICE_FUNC Eigen::Diagonal< MatrixType, _DiagIndex >::Diagonal | ( | MatrixType & | matrix, |
| Index | a_index = DiagIndex |
| ) | [inline, explicit] |
Definition at line 73 of file Diagonal.h.
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Index Eigen::Diagonal< MatrixType, _DiagIndex >::absDiagIndex | ( | ) | const [inline, private] |
| EIGEN_DEVICE_FUNC CoeffReturnType Eigen::Diagonal< MatrixType, _DiagIndex >::coeff | ( | Index | row, |
| Index | |||
| ) | const [inline] |
| EIGEN_DEVICE_FUNC CoeffReturnType Eigen::Diagonal< MatrixType, _DiagIndex >::coeff | ( | Index | idx | ) | const [inline] |
Definition at line 143 of file Diagonal.h.
| EIGEN_DEVICE_FUNC Scalar& Eigen::Diagonal< MatrixType, _DiagIndex >::coeffRef | ( | Index | row, |
| Index | |||
| ) | [inline] |
Definition at line 111 of file Diagonal.h.
| EIGEN_DEVICE_FUNC const Scalar& Eigen::Diagonal< MatrixType, _DiagIndex >::coeffRef | ( | Index | row, |
| Index | |||
| EIGEN_DEVICE_FUNC Scalar& Eigen::Diagonal< MatrixType, _DiagIndex >::coeffRef | ( | Index | idx | ) | [inline] |
Definition at line 130 of file Diagonal.h.
EIGEN_STATIC_ASSERT_LVALUE(MatrixType)
return m_matrix.coeffRef(idx+rowOffset(), idx+colOffset());
| EIGEN_DEVICE_FUNC const Scalar& Eigen::Diagonal< MatrixType, _DiagIndex >::coeffRef | ( | Index | idx | ) | const [inline] |
Definition at line 137 of file Diagonal.h.
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Index Eigen::Diagonal< MatrixType, _DiagIndex >::colOffset | ( | ) | const [inline, private] |
| EIGEN_DEVICE_FUNC Index Eigen::Diagonal< MatrixType, _DiagIndex >::cols | ( | void | ) | const [inline] |
Definition at line 85 of file Diagonal.h.
{ return 1; }
| EIGEN_DEVICE_FUNC ScalarWithConstIfNotLvalue* Eigen::Diagonal< MatrixType, _DiagIndex >::data | ( | ) | [inline] |
Definition at line 106 of file Diagonal.h.
| EIGEN_DEVICE_FUNC const Scalar* Eigen::Diagonal< MatrixType, _DiagIndex >::data | ( | ) | const [inline] |
Definition at line 108 of file Diagonal.h.
| EIGEN_DEVICE_FUNC Index Eigen::Diagonal< MatrixType, _DiagIndex >::index | ( | ) | const [inline] |
Definition at line 156 of file Diagonal.h.
| EIGEN_DEVICE_FUNC Index Eigen::Diagonal< MatrixType, _DiagIndex >::innerStride | ( | ) | const [inline] |
Definition at line 88 of file Diagonal.h.
return m_matrix.outerStride() + 1;
| EIGEN_DEVICE_FUNC const internal::remove_all<typename MatrixType::Nested>::type& Eigen::Diagonal< MatrixType, _DiagIndex >::nestedExpression | ( | ) | const [inline] |
Definition at line 150 of file Diagonal.h.
return m_matrix;
| EIGEN_DEVICE_FUNC Index Eigen::Diagonal< MatrixType, _DiagIndex >::outerStride | ( | ) | const [inline] |
Definition at line 94 of file Diagonal.h.
return 0;
| MatrixType::PacketReturnType Eigen::Diagonal< MatrixType, _DiagIndex >::packet | ( | Index | ) | const [private] |
| MatrixType::PacketReturnType Eigen::Diagonal< MatrixType, _DiagIndex >::packet | ( | Index | , |
| Index | |||
| EIGEN_DEVICE_FUNC EIGEN_STRONG_INLINE Index Eigen::Diagonal< MatrixType, _DiagIndex >::rowOffset | ( | ) | const [inline, private] |
| EIGEN_DEVICE_FUNC Index Eigen::Diagonal< MatrixType, _DiagIndex >::rows | ( | void | ) | const [inline] |
const internal::variable_if_dynamicindex<Index, DiagIndex> Eigen::Diagonal< MatrixType, _DiagIndex >::m_index [protected] |
Definition at line 163 of file Diagonal.h.
internal::ref_selector<MatrixType>::non_const_type Eigen::Diagonal< MatrixType, _DiagIndex >::m_matrix [protected] |
Definition at line 162 of file Diagonal.h.
