Classes |
| struct | Eigen::internal::smart_copy_helper< T, true > |
| struct | Eigen::internal::smart_copy_helper< T, false > |
| struct | Eigen::internal::smart_memmove_helper< T, true > |
| struct | Eigen::internal::smart_memmove_helper< T, false > |
| class | Eigen::internal::aligned_stack_memory_handler< T > |
| class | Eigen::internal::scoped_array< T > |
| class | Eigen::aligned_allocator< T > |
| | STL compatible allocator to use with with 16 byte aligned types. More...
| struct | Eigen::aligned_allocator< T >::rebind< U > |
Namespaces |
| namespace | Eigen |
| namespace | Eigen::internal |
Defines |
| #define | EIGEN_GLIBC_MALLOC_ALREADY_ALIGNED 0 |
| #define | EIGEN_FREEBSD_MALLOC_ALREADY_ALIGNED 0 |
| #define | EIGEN_MALLOC_ALREADY_ALIGNED 0 |
| #define | ei_declare_aligned_stack_constructed_variable(TYPE, NAME, SIZE, BUFFER) |
| #define | EIGEN_MAKE_ALIGNED_OPERATOR_NEW_IF(NeedsToAlign) |
| #define | EIGEN_MAKE_ALIGNED_OPERATOR_NEW EIGEN_MAKE_ALIGNED_OPERATOR_NEW_IF(true) |
| #define | EIGEN_MAKE_ALIGNED_OPERATOR_NEW_IF_VECTORIZABLE_FIXED_SIZE(Scalar, Size) EIGEN_MAKE_ALIGNED_OPERATOR_NEW_IF(bool(((Size)!=Eigen::Dynamic) && ((sizeof(Scalar)*(Size))%EIGEN_MAX_ALIGN_BYTES==0))) |
Functions |
| EIGEN_DEVICE_FUNC void | Eigen::internal::throw_std_bad_alloc () |
| void * | Eigen::internal::handmade_aligned_malloc (std::size_t size) |
| void | Eigen::internal::handmade_aligned_free (void *ptr) |
| void * | Eigen::internal::handmade_aligned_realloc (void *ptr, std::size_t size, std::size_t=0) |
| | Reallocates aligned memory. Since we know that our handmade version is based on std::malloc we can use std::realloc to implement efficient reallocation.
| EIGEN_DEVICE_FUNC void | Eigen::internal::check_that_malloc_is_allowed () |
| EIGEN_DEVICE_FUNC void * | Eigen::internal::aligned_malloc (size_t size) |
| EIGEN_DEVICE_FUNC void | Eigen::internal::aligned_free (void *ptr) |
| void * | Eigen::internal::aligned_realloc (void *ptr, size_t new_size, size_t old_size) |
| | Reallocates an aligned block of memory.
| template<bool Align> |
| EIGEN_DEVICE_FUNC void * | Eigen::internal::conditional_aligned_malloc (size_t size) |
| template<> |
| EIGEN_DEVICE_FUNC void * | Eigen::internal::conditional_aligned_malloc< false > (size_t size) |
| EIGEN_DEVICE_FUNC void | Eigen::internal::conditional_aligned_free (void *ptr) |
| template<> |
| EIGEN_DEVICE_FUNC void | Eigen::internal::conditional_aligned_free< false > (void *ptr) |
| void * | Eigen::internal::conditional_aligned_realloc (void *ptr, size_t new_size, size_t old_size) |
| template<> |
| void * | Eigen::internal::conditional_aligned_realloc< false > (void *ptr, size_t new_size, size_t) |
| template<typename T > |
| EIGEN_DEVICE_FUNC void | Eigen::internal::destruct_elements_of_array (T *ptr, size_t size) |
| EIGEN_DEVICE_FUNC T * | Eigen::internal::construct_elements_of_array (T *ptr, size_t size) |
EIGEN_DEVICE_FUNC
EIGEN_ALWAYS_INLINE void | Eigen::internal::check_size_for_overflow (size_t size) |
| EIGEN_DEVICE_FUNC T * | Eigen::internal::aligned_new (size_t size) |
| template<typename T , bool Align> |
| EIGEN_DEVICE_FUNC T * | Eigen::internal::conditional_aligned_new (size_t size) |
| EIGEN_DEVICE_FUNC void | Eigen::internal::aligned_delete (T *ptr, size_t size) |
| EIGEN_DEVICE_FUNC void | Eigen::internal::conditional_aligned_delete (T *ptr, size_t size) |
| EIGEN_DEVICE_FUNC T * | Eigen::internal::conditional_aligned_realloc_new (T *pts, size_t new_size, size_t old_size) |
| EIGEN_DEVICE_FUNC T * | Eigen::internal::conditional_aligned_new_auto (size_t size) |
| T * | Eigen::internal::conditional_aligned_realloc_new_auto (T *pts, size_t new_size, size_t old_size) |
| EIGEN_DEVICE_FUNC void | Eigen::internal::conditional_aligned_delete_auto (T *ptr, size_t size) |
| template<int Alignment, typename Scalar , typename Index > |
| EIGEN_DEVICE_FUNC Index | Eigen::internal::first_aligned (const Scalar *array, Index size) |
| template<typename Scalar , typename Index > |
| EIGEN_DEVICE_FUNC Index | Eigen::internal::first_default_aligned (const Scalar *array, Index size) |
| template<typename Index > |
| Index | Eigen::internal::first_multiple (Index size, Index base) |
| EIGEN_DEVICE_FUNC void | Eigen::internal::smart_copy (const T *start, const T *end, T *target) |
| void | Eigen::internal::smart_memmove (const T *start, const T *end, T *target) |
| void | Eigen::internal::swap (scoped_array< T > &a, scoped_array< T > &b) |
| void | Eigen::internal::queryCacheSizes (int &l1, int &l2, int &l3) |
| int | Eigen::internal::queryL1CacheSize () |
| int | Eigen::internal::queryTopLevelCacheSize () |
Value:Eigen::internal::check_size_for_overflow<TYPE>(SIZE); \
TYPE* NAME = (BUFFER)!=0 ? BUFFER : reinterpret_cast<TYPE*>(Eigen::internal::aligned_malloc(sizeof(TYPE)*SIZE)); \
Eigen::internal::aligned_stack_memory_handler<TYPE> EIGEN_CAT(NAME,_stack_memory_destructor)((BUFFER)==0 ? NAME : 0,SIZE,true)
Declares, allocates and construct an aligned buffer named NAME of SIZE elements of type TYPE on the stack if SIZE is smaller than EIGEN_STACK_ALLOCATION_LIMIT, and if stack allocation is supported by the platform (currently, this is Linux and Visual Studio only). Otherwise the memory is allocated on the heap. The allocated buffer is automatically deleted when exiting the scope of this declaration. If BUFFER is non null, then the declared variable is simply an alias for BUFFER, and no allocation/deletion occurs. Here is an example:
The underlying stack allocation function can controlled with the EIGEN_ALLOCA preprocessor token.
Definition at line 641 of file Memory.h.
