Classes |
| struct | Eigen::internal::true_type |
| struct | Eigen::internal::false_type |
| struct | Eigen::internal::conditional< Condition, Then, Else > |
| struct | Eigen::internal::conditional< false, Then, Else > |
| struct | Eigen::internal::is_same< T, U > |
| struct | Eigen::internal::is_same< T, T > |
| struct | Eigen::internal::remove_reference< T > |
| struct | Eigen::internal::remove_reference< T & > |
| struct | Eigen::internal::remove_pointer< T > |
| struct | Eigen::internal::remove_pointer< T * > |
| struct | Eigen::internal::remove_pointer< T *const > |
| struct | Eigen::internal::remove_const< T > |
| struct | Eigen::internal::remove_const< const T > |
| struct | Eigen::internal::remove_const< const T[]> |
| struct | Eigen::internal::remove_const< const T[Size]> |
| struct | Eigen::internal::remove_all< T > |
| struct | Eigen::internal::remove_all< const T > |
| struct | Eigen::internal::remove_all< T const & > |
| struct | Eigen::internal::remove_all< T & > |
| struct | Eigen::internal::remove_all< T const * > |
| struct | Eigen::internal::remove_all< T * > |
| struct | Eigen::internal::is_arithmetic< T > |
| struct | Eigen::internal::is_arithmetic< float > |
| struct | Eigen::internal::is_arithmetic< double > |
| struct | Eigen::internal::is_arithmetic< long double > |
| struct | Eigen::internal::is_arithmetic< bool > |
| struct | Eigen::internal::is_arithmetic< char > |
| struct | Eigen::internal::is_arithmetic< signed char > |
| struct | Eigen::internal::is_arithmetic< unsigned char > |
| struct | Eigen::internal::is_arithmetic< signed short > |
| struct | Eigen::internal::is_arithmetic< unsigned short > |
| struct | Eigen::internal::is_arithmetic< signed int > |
| struct | Eigen::internal::is_arithmetic< unsigned int > |
| struct | Eigen::internal::is_arithmetic< signed long > |
| struct | Eigen::internal::is_arithmetic< unsigned long > |
| struct | Eigen::internal::is_integral< T > |
| struct | Eigen::internal::is_integral< bool > |
| struct | Eigen::internal::is_integral< char > |
| struct | Eigen::internal::is_integral< signed char > |
| struct | Eigen::internal::is_integral< unsigned char > |
| struct | Eigen::internal::is_integral< signed short > |
| struct | Eigen::internal::is_integral< unsigned short > |
| struct | Eigen::internal::is_integral< signed int > |
| struct | Eigen::internal::is_integral< unsigned int > |
| struct | Eigen::internal::is_integral< signed long > |
| struct | Eigen::internal::is_integral< unsigned long > |
| struct | Eigen::internal::add_const< T > |
| struct | Eigen::internal::add_const< T & > |
| struct | Eigen::internal::is_const< T > |
| struct | Eigen::internal::is_const< T const > |
| struct | Eigen::internal::add_const_on_value_type< T > |
| struct | Eigen::internal::add_const_on_value_type< T & > |
| struct | Eigen::internal::add_const_on_value_type< T * > |
| struct | Eigen::internal::add_const_on_value_type< T *const > |
| struct | Eigen::internal::add_const_on_value_type< T const *const > |
| struct | Eigen::internal::is_convertible_impl< From, To > |
| struct | Eigen::internal::is_convertible_impl< From, To >::any_conversion |
| struct | Eigen::internal::is_convertible_impl< From, To >::yes |
| struct | Eigen::internal::is_convertible_impl< From, To >::no |
| struct | Eigen::internal::is_convertible< From, To > |
| struct | Eigen::internal::enable_if< true, T > |
| class | Eigen::internal::noncopyable |
| struct | Eigen::internal::result_of< T > |
| struct | Eigen::internal::has_none |
| struct | Eigen::internal::has_std_result_type |
| struct | Eigen::internal::has_tr1_result |
| struct | Eigen::internal::unary_result_of_select< Func, ArgType, SizeOf > |
| struct | Eigen::internal::unary_result_of_select< Func, ArgType, sizeof(has_std_result_type)> |
| struct | Eigen::internal::unary_result_of_select< Func, ArgType, sizeof(has_tr1_result)> |
| struct | Eigen::internal::result_of< Func(ArgType)> |
| struct | Eigen::internal::binary_result_of_select< Func, ArgType0, ArgType1, SizeOf > |
| struct | Eigen::internal::binary_result_of_select< Func, ArgType0, ArgType1, sizeof(has_std_result_type)> |
| struct | Eigen::internal::binary_result_of_select< Func, ArgType0, ArgType1, sizeof(has_tr1_result)> |
| struct | Eigen::internal::result_of< Func(ArgType0, ArgType1)> |
| class | Eigen::internal::meta_sqrt< Y, InfX, SupX, Done > |
| class | Eigen::internal::meta_sqrt< Y, InfX, SupX, true > |
| struct | Eigen::internal::meta_least_common_multiple< A, B, K, Done > |
| struct | Eigen::internal::meta_least_common_multiple< A, B, K, true > |
| struct | Eigen::internal::scalar_product_traits< T, U > |
| struct | Eigen::internal::scalar_product_traits< T, T > |
| struct | Eigen::internal::scalar_product_traits< T, std::complex< T > > |
| struct | Eigen::internal::scalar_product_traits< std::complex< T >, T > |
Namespaces |
| namespace | Eigen |
| namespace | Eigen::internal |
| namespace | Eigen::numext |
Functions |
| template<typename T > |
| EIGEN_STRONG_INLINE void | Eigen::numext::swap (T &a, T &b) |
| T | Eigen::numext::div_ceil (const T &a, const T &b) |
This file contains generic metaprogramming classes which are not specifically related to Eigen.
- Note:
- In case you wonder, yes we're aware that Boost already provides all these features, we however don't want to add a dependency to Boost.
Definition in file Meta.h.
