MOAB
4.9.3pre
#include "Eigen_Colamd.h"
Classes | |
| struct | Eigen::internal::colamd_col< IndexType > |
| struct | Eigen::internal::Colamd_Row< IndexType > |
| class | Eigen::AMDOrdering< StorageIndex > |
| class | Eigen::NaturalOrdering< StorageIndex > |
| class | Eigen::COLAMDOrdering< StorageIndex > |
Namespaces | |
| namespace | Eigen |
| namespace | Eigen::internal |
Functions | |
| template<typename IndexType > | |
| IndexType | Eigen::internal::colamd_c (IndexType n_col) |
| IndexType | Eigen::internal::colamd_r (IndexType n_row) |
| static IndexType | Eigen::internal::init_rows_cols (IndexType n_row, IndexType n_col, Colamd_Row< IndexType > Row[], colamd_col< IndexType > col[], IndexType A[], IndexType p[], IndexType stats[COLAMD_STATS]) |
| static void | Eigen::internal::init_scoring (IndexType n_row, IndexType n_col, Colamd_Row< IndexType > Row[], colamd_col< IndexType > Col[], IndexType A[], IndexType head[], double knobs[COLAMD_KNOBS], IndexType *p_n_row2, IndexType *p_n_col2, IndexType *p_max_deg) |
| static IndexType | Eigen::internal::find_ordering (IndexType n_row, IndexType n_col, IndexType Alen, Colamd_Row< IndexType > Row[], colamd_col< IndexType > Col[], IndexType A[], IndexType head[], IndexType n_col2, IndexType max_deg, IndexType pfree) |
| static void | Eigen::internal::order_children (IndexType n_col, colamd_col< IndexType > Col[], IndexType p[]) |
| static void | Eigen::internal::detect_super_cols (colamd_col< IndexType > Col[], IndexType A[], IndexType head[], IndexType row_start, IndexType row_length) |
| static IndexType | Eigen::internal::garbage_collection (IndexType n_row, IndexType n_col, Colamd_Row< IndexType > Row[], colamd_col< IndexType > Col[], IndexType A[], IndexType *pfree) |
| static IndexType | Eigen::internal::clear_mark (IndexType n_row, Colamd_Row< IndexType > Row[]) |
| IndexType | Eigen::internal::colamd_recommended (IndexType nnz, IndexType n_row, IndexType n_col) |
| Returns the recommended value of Alen. | |
| static void | Eigen::internal::colamd_set_defaults (double knobs[COLAMD_KNOBS]) |
| set default parameters The use of this routine is optional. | |
| static bool | Eigen::internal::colamd (IndexType n_row, IndexType n_col, IndexType Alen, IndexType *A, IndexType *p, double knobs[COLAMD_KNOBS], IndexType stats[COLAMD_STATS]) |
| Computes a column ordering using the column approximate minimum degree ordering. | |
| template<typename MatrixType > | |
| void | Eigen::internal::ordering_helper_at_plus_a (const MatrixType &A, MatrixType &symmat) |
