MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 diachin2@llnl.gov, djmelan@sandia.gov, mbrewer@sandia.gov, 00024 pknupp@sandia.gov, tleurent@mcs.anl.gov, tmunson@mcs.anl.gov, 00025 kraftche@cae.wisc.edu 00026 00027 ***************************************************************** */ 00028 /*! 00029 \file ParallelMeshInterface.hpp 00030 \brief This file contains the parallel Mesquite mesh interface. 00031 Many users will want to implement a concrete class derived from 00032 the ParallelMeshInterface class to access their mesh. 00033 00034 */ 00035 #ifndef MESQUITE_PARALLEL_MESH_INTERFACE_HPP 00036 #define MESQUITE_PARALLEL_MESH_INTERFACE_HPP 00037 00038 #include "MeshInterface.hpp" 00039 00040 namespace MBMesquite 00041 { 00042 class ParallelHelper; 00043 00044 /*! \class ParallelMesh \brief MBMesquite::ParallelMesh is an abstract class 00045 * which defines required methods required for using Mesquite in parallel. 00046 * It derives from the MBMesquite::Mesh interface so the user must provide 00047 * implementations of the pure virtual methods in both MBMesquite::Mesh as 00048 * well as those defined here. 00049 */ 00050 class MESQUITE_EXPORT ParallelMesh : virtual public Mesh 00051 { 00052 public: 00053 /*! Get global ids for given vertices. 00054 */ 00055 virtual void vertices_get_global_id( const VertexHandle vert_array[], 00056 size_t global_id[], 00057 size_t num_vtx, 00058 MsqError& err ) = 0; 00059 00060 /*! Get processor ids for given vertices. 00061 */ 00062 virtual void vertices_get_processor_id( const VertexHandle vert_array[], 00063 int proc_id[], 00064 size_t num_vtx, 00065 MsqError& err ) = 0; 00066 00067 /*! Set parallel helper 00068 */ 00069 virtual void set_parallel_helper( ParallelHelper* p_helper ) 00070 { 00071 this->helper = p_helper; 00072 } 00073 00074 /*! Get parallel helper 00075 */ 00076 virtual ParallelHelper* get_parallel_helper() 00077 { 00078 return helper; 00079 } 00080 00081 protected: 00082 ParallelHelper* helper; 00083 //! Don't allow a ParallelMesh to be deleted directly. 00084 virtual ~ParallelMesh() {} 00085 }; 00086 } // namespace MBMesquite 00087 00088 #endif
