MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef READCCMIO_HPP 00002 #define READCCMIO_HPP 00003 00004 #ifndef IS_BUILDING_MB 00005 #error "ReadCCMIO.hpp isn't supposed to be included into an application" 00006 #endif 00007 00008 #include <vector> 00009 #include <set> 00010 #include <map> 00011 #include <string> 00012 00013 #include "moab/Forward.hpp" 00014 #include "moab/Range.hpp" 00015 #include "moab/ExoIIInterface.hpp" 00016 #include "moab/ReaderIface.hpp" 00017 //#include "moab/TupleList.hpp" 00018 #include "ccmio.h" 00019 00020 namespace moab 00021 { 00022 00023 #undef READCCMIO_USE_TUPLE_LIST 00024 00025 class ReadUtilIface; 00026 00027 class ReadCCMIO : public ReaderIface 00028 { 00029 00030 public: 00031 typedef std::map< int, std::vector< EntityHandle > > TupleList; 00032 typedef std::map< int, std::vector< int > > SenseList; 00033 00034 //! Constructor 00035 ReadCCMIO( Interface* impl ); 00036 00037 //! Destructor 00038 virtual ~ReadCCMIO(); 00039 00040 static ReaderIface* factory( Interface* ); 00041 00042 ErrorCode load_file( const char* file_name, 00043 const EntityHandle* file_set, 00044 const FileOptions& opts, 00045 const SubsetList* subset_list = 0, 00046 const Tag* file_id_tag = 0 ); 00047 00048 private: 00049 ErrorCode read_processor( CCMIOID rootID, 00050 CCMIOID problemID, 00051 CCMIOID processorID, 00052 CCMIOID verticesID, 00053 CCMIOID topologyID, 00054 CCMIOSize_t proc, 00055 Range* new_ents ); 00056 00057 ErrorCode read_cells( CCMIOSize_t proc, 00058 CCMIOID processorID, 00059 CCMIOID verticesID, 00060 CCMIOID topologyID, 00061 TupleList& vert_map, 00062 Range* new_cells ); 00063 00064 ErrorCode construct_cells( TupleList& face_map, 00065 #ifndef READCCMIO_USE_TUPLE_LIST 00066 SenseList& sense_map, 00067 #endif 00068 TupleList& vert_map, 00069 std::map< int, int >& cell_topo_types, 00070 std::vector< EntityHandle >& new_cells ); 00071 00072 ErrorCode ccmio_to_moab_type( int ccm_type, EntityType& moab_type, bool& has_mid_nodes ); 00073 00074 ErrorCode create_cell_from_faces( std::vector< EntityHandle >& facehs, 00075 std::vector< int >& senses, 00076 EntityType this_type, 00077 bool has_mid_nodes, 00078 EntityHandle& cell ); 00079 00080 ErrorCode read_gids_and_types( CCMIOID problemID, CCMIOID topologyID, std::vector< EntityHandle >& cells ); 00081 00082 ErrorCode read_all_faces( CCMIOID topologyID, 00083 TupleList& vert_map, 00084 TupleList& face_map 00085 #ifndef READCCMIO_USE_TUPLE_LIST 00086 , 00087 SenseList& sense_map 00088 #endif 00089 , 00090 Range* new_faces ); 00091 00092 ErrorCode read_faces( CCMIOID faceID, 00093 CCMIOEntity bdy_or_int, 00094 TupleList& vert_map, 00095 TupleList& face_map 00096 #ifndef READCCMIO_USE_TUPLE_LIST 00097 , 00098 SenseList& sense_map 00099 #endif 00100 , 00101 Range* new_faces ); 00102 00103 ErrorCode make_faces( int* farray, TupleList& vert_map, std::vector< EntityHandle >& new_faces, int num_faces ); 00104 00105 ErrorCode read_vertices( CCMIOSize_t proc, 00106 CCMIOID processorID, 00107 CCMIOID verticesID, 00108 CCMIOID topologyID, 00109 Range* verts, 00110 TupleList& vert_map ); 00111 00112 ErrorCode get_processors( CCMIOID stateID, 00113 CCMIOID& processorID, 00114 CCMIOID& verticesID, 00115 CCMIOID& topologyID, 00116 CCMIOID& solutionID, 00117 std::vector< CCMIOSize_t >& procs, 00118 bool& has_solution ); 00119 00120 ErrorCode get_state( CCMIOID rootID, CCMIOID& problemID, CCMIOID& stateID ); 00121 00122 ErrorCode read_tag_values( const char* file_name, 00123 const char* tag_name, 00124 const FileOptions& opts, 00125 std::vector< int >& tag_values_out, 00126 const SubsetList* subset_list = 0 ); 00127 00128 ErrorCode load_matset_data( CCMIOID problemID ); 00129 00130 ErrorCode load_neuset_data( CCMIOID problemID ); 00131 00132 ErrorCode load_metadata( CCMIOID rootID, 00133 CCMIOID problemID, 00134 CCMIOID stateID, 00135 CCMIOID processorID, 00136 const EntityHandle* file_set ); 00137 00138 ErrorCode read_topology_types( CCMIOID& topologyID, std::map< int, int >& cell_topo_types ); 00139 00140 ErrorCode get_int_option( const char* opt_str, EntityHandle seth, Tag& tag, CCMIOID node ); 00141 00142 ErrorCode get_dbl_option( const char* opt_str, EntityHandle seth, Tag& tag, CCMIOID node ); 00143 00144 ErrorCode get_str_option( const char* opt_str, 00145 EntityHandle seth, 00146 Tag& tag, 00147 CCMIOID node, 00148 const char* tag_name = NULL ); 00149 00150 //! Cached tags for reading. Note that all these tags are defined when the 00151 //! core is initialized. 00152 Tag mMaterialSetTag; 00153 Tag mDirichletSetTag; 00154 Tag mNeumannSetTag; 00155 Tag mHasMidNodesTag; 00156 Tag mGlobalIdTag; 00157 Tag mNameTag; 00158 Tag mMaterialIdTag, mMaterialTypeTag; 00159 Tag mRadiationTag, mPorosityIdTag, mSpinIdTag, mGroupIdTag, mColorIdxTag, mProcessorIdTag, mLightMaterialTag, 00160 mFreeSurfaceMaterialTag; 00161 Tag mThicknessTag, mProstarRegionNumberTag, mBoundaryTypeTag, mCreatingProgramTag; 00162 00163 Interface* mbImpl; 00164 00165 ReadUtilIface* readMeshIface; 00166 00167 std::map< int, EntityHandle > newMatsets, newNeusets; 00168 00169 bool hasSolution; 00170 }; 00171 00172 } // namespace moab 00173 00174 #endif
