MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2009-2010 Gael Guennebaud <[email protected]> 00005 // Copyright (C) 2009-2010 Benoit Jacob <[email protected]> 00006 // 00007 // This Source Code Form is subject to the terms of the Mozilla 00008 // Public License v. 2.0. If a copy of the MPL was not distributed 00009 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00010 00011 #ifndef EIGEN_RETURNBYVALUE_H 00012 #define EIGEN_RETURNBYVALUE_H 00013 00014 namespace Eigen { 00015 00016 namespace internal { 00017 00018 template<typename Derived> 00019 struct traits<ReturnByValue<Derived> > 00020 : public traits<typename traits<Derived>::ReturnType> 00021 { 00022 enum { 00023 // We're disabling the DirectAccess because e.g. the constructor of 00024 // the Block-with-DirectAccess expression requires to have a coeffRef method. 00025 // Also, we don't want to have to implement the stride stuff. 00026 Flags = (traits<typename traits<Derived>::ReturnType>::Flags 00027 | EvalBeforeNestingBit) & ~DirectAccessBit 00028 }; 00029 }; 00030 00031 /* The ReturnByValue object doesn't even have a coeff() method. 00032 * So the only way that nesting it in an expression can work, is by evaluating it into a plain matrix. 00033 * So internal::nested always gives the plain return matrix type. 00034 * 00035 * FIXME: I don't understand why we need this specialization: isn't this taken care of by the EvalBeforeNestingBit ?? 00036 * Answer: EvalBeforeNestingBit should be deprecated since we have the evaluators 00037 */ 00038 template<typename Derived,int n,typename PlainObject> 00039 struct nested_eval<ReturnByValue<Derived>, n, PlainObject> 00040 { 00041 typedef typename traits<Derived>::ReturnType type; 00042 }; 00043 00044 } // end namespace internal 00045 00050 template<typename Derived> class ReturnByValue 00051 : public internal::dense_xpr_base< ReturnByValue<Derived> >::type, internal::no_assignment_operator 00052 { 00053 public: 00054 typedef typename internal::traits<Derived>::ReturnType ReturnType; 00055 00056 typedef typename internal::dense_xpr_base<ReturnByValue>::type Base; 00057 EIGEN_DENSE_PUBLIC_INTERFACE(ReturnByValue) 00058 00059 template<typename Dest> 00060 EIGEN_DEVICE_FUNC 00061 inline void evalTo(Dest& dst) const 00062 { static_cast<const Derived*>(this)->evalTo(dst); } 00063 EIGEN_DEVICE_FUNC inline Index rows() const { return static_cast<const Derived*>(this)->rows(); } 00064 EIGEN_DEVICE_FUNC inline Index cols() const { return static_cast<const Derived*>(this)->cols(); } 00065 00066 #ifndef EIGEN_PARSED_BY_DOXYGEN 00067 #define Unusable YOU_ARE_TRYING_TO_ACCESS_A_SINGLE_COEFFICIENT_IN_A_SPECIAL_EXPRESSION_WHERE_THAT_IS_NOT_ALLOWED_BECAUSE_THAT_WOULD_BE_INEFFICIENT 00068 class Unusable{ 00069 Unusable(const Unusable&) {} 00070 Unusable& operator=(const Unusable&) {return *this;} 00071 }; 00072 const Unusable& coeff(Index) const { return *reinterpret_cast<const Unusable*>(this); } 00073 const Unusable& coeff(Index,Index) const { return *reinterpret_cast<const Unusable*>(this); } 00074 Unusable& coeffRef(Index) { return *reinterpret_cast<Unusable*>(this); } 00075 Unusable& coeffRef(Index,Index) { return *reinterpret_cast<Unusable*>(this); } 00076 #undef Unusable 00077 #endif 00078 }; 00079 00080 template<typename Derived> 00081 template<typename OtherDerived> 00082 Derived& DenseBase<Derived>::operator=(const ReturnByValue<OtherDerived>& other) 00083 { 00084 other.evalTo(derived()); 00085 return derived(); 00086 } 00087 00088 namespace internal { 00089 00090 // Expression is evaluated in a temporary; default implementation of Assignment is bypassed so that 00091 // when a ReturnByValue expression is assigned, the evaluator is not constructed. 00092 // TODO: Finalize port to new regime; ReturnByValue should not exist in the expression world 00093 00094 template<typename Derived> 00095 struct evaluator<ReturnByValue<Derived> > 00096 : public evaluator<typename internal::traits<Derived>::ReturnType> 00097 { 00098 typedef ReturnByValue<Derived> XprType; 00099 typedef typename internal::traits<Derived>::ReturnType PlainObject; 00100 typedef evaluator<PlainObject> Base; 00101 00102 EIGEN_DEVICE_FUNC explicit evaluator(const XprType& xpr) 00103 : m_result(xpr.rows(), xpr.cols()) 00104 { 00105 ::new (static_cast<Base*>(this)) Base(m_result); 00106 xpr.evalTo(m_result); 00107 } 00108 00109 protected: 00110 PlainObject m_result; 00111 }; 00112 00113 } // end namespace internal 00114 00115 } // end namespace Eigen 00116 00117 #endif // EIGEN_RETURNBYVALUE_H
