MOAB
4.9.3pre
Defines | |
| #define | EIGEN_UNROLLING_LIMIT 100 |
| #define | EIGEN_CACHEFRIENDLY_PRODUCT_THRESHOLD 8 |
| #define | EIGEN_TUNE_TRIANGULAR_PANEL_WIDTH 8 |
| #define | EIGEN_ARCH_DEFAULT_NUMBER_OF_REGISTERS 8 |
| #define EIGEN_ARCH_DEFAULT_NUMBER_OF_REGISTERS 8 |
Defines the default number of registers available for that architecture. Currently it must be 8 or 16. Other values will fail.
Definition at line 46 of file Settings.h.
| #define EIGEN_CACHEFRIENDLY_PRODUCT_THRESHOLD 8 |
Defines the threshold between a "small" and a "large" matrix. This threshold is mainly used to select the proper product implementation.
Definition at line 31 of file Settings.h.
| #define EIGEN_TUNE_TRIANGULAR_PANEL_WIDTH 8 |
Defines the maximal width of the blocks used in the triangular product and solver for vectors (level 2 blas xTRMV and xTRSV). The default is 8.
Definition at line 38 of file Settings.h.
| #define EIGEN_UNROLLING_LIMIT 100 |
Defines the maximal loop size to enable meta unrolling of loops. Note that the value here is expressed in Eigen's own notion of "number of FLOPS", it does not correspond to the number of iterations or the number of instructions
Definition at line 24 of file Settings.h.
