MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 This example takes a .cub mesh file as input and prints out the total area of 00003 meshes in each surface of the model. It works for tri and quad elements. 00004 It makes use of CUBIT's reserved tag - GEOM_DIMENSION and GLOBAL_ID tag. 00005 Both GLOBAL_ID & GEOM_DIMENSION tag are associated with all the geometric 00006 entities in a .cub file. Note: The program would give incorrect result for a 00007 non-convex element, since it breaks polygons into triangles for computing the area 00008 */ 00009 00010 #include "moab/Core.hpp" 00011 #include "moab/Range.hpp" 00012 #include "moab/CartVect.hpp" 00013 #include <iostream> 00014 00015 using namespace moab; 00016 00017 double compute_area( std::vector< EntityHandle >& ); 00018 00019 // instantiate 00020 Interface* mb; 00021 00022 int main( int argc, char** argv ) 00023 { 00024 if( 1 == argc ) 00025 { 00026 std::cout << "Usage: " << argv[0] << " <filename>" << std::endl; 00027 return 0; 00028 } 00029 00030 // declare variables 00031 Tag gtag, idtag; 00032 ErrorCode rval; 00033 const char* tag_geom = "GEOM_DIMENSION"; 00034 const char* tag_gid = "GLOBAL_ID"; 00035 Range sets; 00036 std::vector< EntityHandle > ents; 00037 00038 // load a file 00039 mb = new Core(); 00040 rval = mb->load_file( argv[1] ); 00041 if( MB_SUCCESS != rval ) return 1; 00042 00043 // get the tag handle for the tags 00044 rval = mb->tag_get_handle( tag_geom, 1, MB_TYPE_INTEGER, gtag ); 00045 if( MB_SUCCESS != rval ) return 1; 00046 rval = mb->tag_get_handle( tag_gid, 1, MB_TYPE_INTEGER, idtag ); 00047 if( MB_SUCCESS != rval ) return 1; 00048 00049 // get all the sets with GEOM_DIMESION tag 00050 rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, >ag, NULL, 1, sets ); 00051 if( MB_SUCCESS != rval ) return 1; 00052 00053 // iterate over each set, getting entities 00054 Range::iterator set_it; 00055 00056 // loop thru all the geometric entity sets 00057 for( set_it = sets.begin(); set_it != sets.end(); ++set_it ) 00058 { 00059 00060 EntityHandle this_set = *set_it; 00061 00062 // get the id for this set 00063 int set_id; 00064 rval = mb->tag_get_data( gtag, &this_set, 1, &set_id ); 00065 if( MB_SUCCESS != rval ) return 1; 00066 00067 // check if it is a surface entities (GEOM_DIMENSION 2) then compute area 00068 if( set_id == 2 ) 00069 { 00070 00071 // area of a surface 00072 double total_area = 0.0; 00073 00074 // get the global id of this surface 00075 int gid = 0; 00076 rval = mb->tag_get_data( idtag, &this_set, 1, &gid ); 00077 if( MB_SUCCESS != rval ) return 1; 00078 00079 // get all entities with dimension 2 in ents 00080 rval = mb->get_entities_by_dimension( this_set, 2, ents ); 00081 if( MB_SUCCESS != rval ) return 1; 00082 00083 // compute the area 00084 total_area = compute_area( ents ); 00085 00086 ents.clear(); 00087 00088 std::cout << "Total area of meshes in surface " << gid << " = " << total_area << std::endl; 00089 } 00090 } 00091 } 00092 00093 // This routine takes all the element entities in a face as input and computes the surface area 00094 // iterating over each element 00095 double compute_area( std::vector< EntityHandle >& entities ) 00096 { 00097 00098 ErrorCode rval = MB_SUCCESS; 00099 double area = 0.0; 00100 00101 // loop thro' all the elements 00102 for( int i = 0; i < int( entities.size() ); i++ ) 00103 { 00104 std::vector< EntityHandle > conn; 00105 EntityHandle handle = entities[i]; 00106 00107 // get the connectivity of this element 00108 rval = mb->get_connectivity( &handle, 1, conn ); 00109 if( MB_SUCCESS != rval ) return -1.0; 00110 00111 // break polygon into triangles and sum the area - Limitation: Convex polygon 00112 for( int j = 2; j <= int( conn.size() ); ++j ) 00113 { 00114 00115 EntityHandle vertices[3] = { conn[0], conn[j - 1], conn[j - 2] }; 00116 CartVect coords[3]; 00117 00118 // get 3 coordinates forming the triangle 00119 rval = mb->get_coords( vertices, 3, coords[0].array() ); 00120 if( MB_SUCCESS != rval ) return -1.0; 00121 00122 CartVect edge0 = coords[1] - coords[0]; 00123 CartVect edge1 = coords[2] - coords[0]; 00124 00125 // using MBCarVect overloaded operators and computing triangle area 00126 area += ( edge0 * edge1 ).length() / 2.0; 00127 } 00128 } 00129 // clear the entities, else old entities remain 00130 entities.clear(); 00131 return area; 00132 }
