MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2009 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 jason@kraftcheck.com 00024 00025 ***************************************************************** */ 00026 /** \file TMPDerivsTest.cpp 00027 * \autor Jason Kraftcheck <jason@kraftcheck.com> 00028 */ 00029 00030 #include "TMPDerivs.hpp" 00031 #include "UnitUtil.hpp" 00032 00033 using namespace MBMesquite; 00034 00035 class TMPDerivsTest : public CppUnit::TestFixture 00036 { 00037 private: 00038 CPPUNIT_TEST_SUITE( TMPDerivsTest ); 00039 CPPUNIT_TEST( test_set_scaled_I ); 00040 CPPUNIT_TEST( test_pluseq_scaled_I ); 00041 CPPUNIT_TEST( test_pluseq_scaled_2nd_deriv_of_det ); 00042 CPPUNIT_TEST( test_set_scaled_2nd_deriv_of_det ); 00043 CPPUNIT_TEST( test_pluseq_scaled_outer_product ); 00044 CPPUNIT_TEST( test_set_scaled_outer_product ); 00045 CPPUNIT_TEST( test_set_scaled_sum_outer_product_2D ); 00046 CPPUNIT_TEST( test_set_scaled_sum_outer_product_3D ); 00047 CPPUNIT_TEST( test_pluseq_scaled_sum_outer_product_2D ); 00048 CPPUNIT_TEST( test_pluseq_scaled_sum_outer_product_3D ); 00049 CPPUNIT_TEST( test_pluseq_scaled_sum_outer_product_I_2D ); 00050 CPPUNIT_TEST( test_pluseq_scaled_sum_outer_product_I_3D ); 00051 CPPUNIT_TEST( test_pluseq_scaled_outer_product_I_I_2D ); 00052 CPPUNIT_TEST( test_pluseq_scaled_outer_product_I_I_3D ); 00053 CPPUNIT_TEST( test_set_scaled_2nd_deriv_norm_sqr_adj ); 00054 CPPUNIT_TEST_SUITE_END(); 00055 00056 public: 00057 void test_set_scaled_I(); 00058 void test_pluseq_scaled_I(); 00059 void test_pluseq_scaled_2nd_deriv_of_det(); 00060 void test_set_scaled_2nd_deriv_of_det(); 00061 void test_pluseq_scaled_outer_product(); 00062 void test_set_scaled_outer_product(); 00063 void test_set_scaled_sum_outer_product_2D(); 00064 void test_set_scaled_sum_outer_product_3D(); 00065 void test_pluseq_scaled_sum_outer_product_2D(); 00066 void test_pluseq_scaled_sum_outer_product_3D(); 00067 void test_pluseq_scaled_sum_outer_product_I_2D(); 00068 void test_pluseq_scaled_sum_outer_product_I_3D(); 00069 void test_pluseq_scaled_outer_product_I_I_2D(); 00070 void test_pluseq_scaled_outer_product_I_I_3D(); 00071 void test_set_scaled_2nd_deriv_norm_sqr_adj(); 00072 }; 00073 00074 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TMPDerivsTest, "TMPDerivsTest" ); 00075 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TMPDerivsTest, "Unit" ); 00076 00077 void TMPDerivsTest::test_set_scaled_I() 00078 { 00079 const double alpha = 3.14159, eps = 1e-12; 00080 MsqMatrix< 3, 3 > R[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }; 00081 set_scaled_I( R, alpha ); 00082 00083 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( alpha ) ), R[0], eps ); 00084 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( 0.0 ) ), R[1], eps ); 00085 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( 0.0 ) ), R[2], eps ); 00086 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( alpha ) ), R[3], eps ); 00087 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( 0.0 ) ), R[4], eps ); 00088 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( alpha ) ), R[5], eps ); 00089 } 00090 00091 void TMPDerivsTest::test_pluseq_scaled_I() 00092 { 00093 const double s = 3.14159, eps = 1e-12, alpha = 0.222; 00094 MsqMatrix< 3, 3 > R[6]; 00095 for( int i = 0; i < 6; ++i ) 00096 R[i] = MsqMatrix< 3, 3 >( s * i ); 00097 pluseq_scaled_I( R, alpha ); 00098 00099 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( 0 * s + alpha ) ), R[0], eps ); 00100 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( 1 * s ) ), R[1], eps ); 00101 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( 2 * s ) ), R[2], eps ); 00102 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( 3 * s + alpha ) ), R[3], eps ); 00103 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( 4 * s ) ), R[4], eps ); 00104 ASSERT_MATRICES_EQUAL( ( MsqMatrix< 3, 3 >( 5 * s + alpha ) ), R[5], eps ); 00105 } 00106 00107 void TMPDerivsTest::test_pluseq_scaled_2nd_deriv_of_det() 00108 { 00109 const double a = 1.33; 00110 const double e = 1e-12; 00111 MsqMatrix< 3, 3 > T; 00112 T( 0, 0 ) = 11; 00113 T( 0, 1 ) = 12; 00114 T( 0, 2 ) = 13; 00115 T( 1, 0 ) = 21; 00116 T( 1, 1 ) = 22; 00117 T( 1, 2 ) = 23; 00118 T( 2, 0 ) = 31; 00119 T( 2, 1 ) = 32; 00120 T( 2, 2 ) = 33; 00121 MsqMatrix< 3, 3 > R[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }; 00122 pluseq_scaled_2nd_deriv_of_det( R, a, T ); 00123 00124 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 0, 0 ), e ); 00125 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 0, 1 ), e ); 00126 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 0, 2 ), e ); 00127 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 1, 0 ), e ); 00128 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 1, 1 ), e ); 00129 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 1, 2 ), e ); 00130 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 2, 0 ), e ); 00131 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 2, 1 ), e ); 00132 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 2, 2 ), e ); 00133 00134 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[1]( 0, 0 ), e ); 00135 CPPUNIT_ASSERT_DOUBLES_EQUAL( 33 * a, R[1]( 0, 1 ), e ); 00136 CPPUNIT_ASSERT_DOUBLES_EQUAL( -32 * a, R[1]( 0, 2 ), e ); 00137 CPPUNIT_ASSERT_DOUBLES_EQUAL( -33 * a, R[1]( 1, 0 ), e ); 00138 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[1]( 1, 1 ), e ); 00139 CPPUNIT_ASSERT_DOUBLES_EQUAL( 31 * a, R[1]( 1, 2 ), e ); 00140 CPPUNIT_ASSERT_DOUBLES_EQUAL( 32 * a, R[1]( 2, 0 ), e ); 00141 CPPUNIT_ASSERT_DOUBLES_EQUAL( -31 * a, R[1]( 2, 1 ), e ); 00142 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[1]( 2, 2 ), e ); 00143 00144 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[2]( 0, 0 ), e ); 00145 CPPUNIT_ASSERT_DOUBLES_EQUAL( -23 * a, R[2]( 0, 1 ), e ); 00146 CPPUNIT_ASSERT_DOUBLES_EQUAL( 22 * a, R[2]( 0, 2 ), e ); 00147 CPPUNIT_ASSERT_DOUBLES_EQUAL( 23 * a, R[2]( 1, 0 ), e ); 00148 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[2]( 1, 1 ), e ); 00149 CPPUNIT_ASSERT_DOUBLES_EQUAL( -21 * a, R[2]( 1, 2 ), e ); 00150 CPPUNIT_ASSERT_DOUBLES_EQUAL( -22 * a, R[2]( 2, 0 ), e ); 00151 CPPUNIT_ASSERT_DOUBLES_EQUAL( 21 * a, R[2]( 2, 1 ), e ); 00152 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[2]( 2, 2 ), e ); 00153 00154 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 0, 0 ), e ); 00155 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 0, 1 ), e ); 00156 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 0, 2 ), e ); 00157 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 1, 0 ), e ); 00158 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 1, 1 ), e ); 00159 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 1, 2 ), e ); 00160 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 2, 0 ), e ); 00161 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 2, 1 ), e ); 00162 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 2, 2 ), e ); 00163 00164 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[4]( 0, 0 ), e ); 00165 CPPUNIT_ASSERT_DOUBLES_EQUAL( 13 * a, R[4]( 0, 1 ), e ); 00166 CPPUNIT_ASSERT_DOUBLES_EQUAL( -12 * a, R[4]( 0, 2 ), e ); 00167 CPPUNIT_ASSERT_DOUBLES_EQUAL( -13 * a, R[4]( 1, 0 ), e ); 00168 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[4]( 1, 1 ), e ); 00169 CPPUNIT_ASSERT_DOUBLES_EQUAL( 11 * a, R[4]( 1, 2 ), e ); 00170 CPPUNIT_ASSERT_DOUBLES_EQUAL( 12 * a, R[4]( 2, 0 ), e ); 00171 CPPUNIT_ASSERT_DOUBLES_EQUAL( -11 * a, R[4]( 2, 1 ), e ); 00172 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[4]( 2, 2 ), e ); 00173 00174 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 0, 0 ), e ); 00175 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 0, 1 ), e ); 00176 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 0, 2 ), e ); 00177 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 1, 0 ), e ); 00178 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 1, 1 ), e ); 00179 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 1, 2 ), e ); 00180 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 2, 0 ), e ); 00181 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 2, 1 ), e ); 00182 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 2, 2 ), e ); 00183 } 00184 00185 void TMPDerivsTest::test_set_scaled_2nd_deriv_of_det() 00186 { 00187 const double a = 0.7; 00188 const double e = 1e-12; 00189 MsqMatrix< 3, 3 > T; 00190 T( 0, 0 ) = 11; 00191 T( 0, 1 ) = 12; 00192 T( 0, 2 ) = 13; 00193 T( 1, 0 ) = 21; 00194 T( 1, 1 ) = 22; 00195 T( 1, 2 ) = 23; 00196 T( 2, 0 ) = 31; 00197 T( 2, 1 ) = 32; 00198 T( 2, 2 ) = 33; 00199 MsqMatrix< 3, 3 > R[6]; 00200 for( int i = 0; i < 6; ++i ) 00201 for( int r = 0; r < 3; ++r ) 00202 for( int c = 0; c < 3; ++c ) 00203 R[i]( r, c ) = 9 * i + 3 * r + c; 00204 00205 set_scaled_2nd_deriv_of_det( R, a, T ); 00206 00207 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 0, 0 ), e ); 00208 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 0, 1 ), e ); 00209 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 0, 2 ), e ); 00210 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 1, 0 ), e ); 00211 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 1, 1 ), e ); 00212 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 1, 2 ), e ); 00213 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 2, 0 ), e ); 00214 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 2, 1 ), e ); 00215 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[0]( 2, 2 ), e ); 00216 00217 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[1]( 0, 0 ), e ); 00218 CPPUNIT_ASSERT_DOUBLES_EQUAL( 33 * a, R[1]( 0, 1 ), e ); 00219 CPPUNIT_ASSERT_DOUBLES_EQUAL( -32 * a, R[1]( 0, 2 ), e ); 00220 CPPUNIT_ASSERT_DOUBLES_EQUAL( -33 * a, R[1]( 1, 0 ), e ); 00221 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[1]( 1, 1 ), e ); 00222 CPPUNIT_ASSERT_DOUBLES_EQUAL( 31 * a, R[1]( 1, 2 ), e ); 00223 CPPUNIT_ASSERT_DOUBLES_EQUAL( 32 * a, R[1]( 2, 0 ), e ); 00224 CPPUNIT_ASSERT_DOUBLES_EQUAL( -31 * a, R[1]( 2, 1 ), e ); 00225 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[1]( 2, 2 ), e ); 00226 00227 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[2]( 0, 0 ), e ); 00228 CPPUNIT_ASSERT_DOUBLES_EQUAL( -23 * a, R[2]( 0, 1 ), e ); 00229 CPPUNIT_ASSERT_DOUBLES_EQUAL( 22 * a, R[2]( 0, 2 ), e ); 00230 CPPUNIT_ASSERT_DOUBLES_EQUAL( 23 * a, R[2]( 1, 0 ), e ); 00231 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[2]( 1, 1 ), e ); 00232 CPPUNIT_ASSERT_DOUBLES_EQUAL( -21 * a, R[2]( 1, 2 ), e ); 00233 CPPUNIT_ASSERT_DOUBLES_EQUAL( -22 * a, R[2]( 2, 0 ), e ); 00234 CPPUNIT_ASSERT_DOUBLES_EQUAL( 21 * a, R[2]( 2, 1 ), e ); 00235 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[2]( 2, 2 ), e ); 00236 00237 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 0, 0 ), e ); 00238 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 0, 1 ), e ); 00239 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 0, 2 ), e ); 00240 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 1, 0 ), e ); 00241 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 1, 1 ), e ); 00242 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 1, 2 ), e ); 00243 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 2, 0 ), e ); 00244 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 2, 1 ), e ); 00245 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[3]( 2, 2 ), e ); 00246 00247 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[4]( 0, 0 ), e ); 00248 CPPUNIT_ASSERT_DOUBLES_EQUAL( 13 * a, R[4]( 0, 1 ), e ); 00249 CPPUNIT_ASSERT_DOUBLES_EQUAL( -12 * a, R[4]( 0, 2 ), e ); 00250 CPPUNIT_ASSERT_DOUBLES_EQUAL( -13 * a, R[4]( 1, 0 ), e ); 00251 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[4]( 1, 1 ), e ); 00252 CPPUNIT_ASSERT_DOUBLES_EQUAL( 11 * a, R[4]( 1, 2 ), e ); 00253 CPPUNIT_ASSERT_DOUBLES_EQUAL( 12 * a, R[4]( 2, 0 ), e ); 00254 CPPUNIT_ASSERT_DOUBLES_EQUAL( -11 * a, R[4]( 2, 1 ), e ); 00255 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[4]( 2, 2 ), e ); 00256 00257 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 0, 0 ), e ); 00258 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 0, 1 ), e ); 00259 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 0, 2 ), e ); 00260 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 1, 0 ), e ); 00261 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 1, 1 ), e ); 00262 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 1, 2 ), e ); 00263 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 2, 0 ), e ); 00264 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 2, 1 ), e ); 00265 CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, R[5]( 2, 2 ), e ); 00266 } 00267 00268 void TMPDerivsTest::test_pluseq_scaled_outer_product() 00269 { 00270 const double vals[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9 }; 00271 const MsqMatrix< 3, 3 > M( vals ); 00272 const double a = 0.1212; 00273 const double e = 1e-12; 00274 00275 MsqMatrix< 3, 3 > R[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }; 00276 pluseq_scaled_outer_product( R, a, M ); 00277 00278 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00279 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 0 ) ) * M.row( 0 ), R[0], e ); 00280 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 0 ) ) * M.row( 1 ), R[1], e ); 00281 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 0 ) ) * M.row( 2 ), R[2], e ); 00282 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 1 ) ) * M.row( 1 ), R[3], e ); 00283 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 1 ) ) * M.row( 2 ), R[4], e ); 00284 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 2 ) ) * M.row( 2 ), R[5], e ); 00285 #else 00286 ASSERT_MATRICES_EQUAL( a * M.column( 0 ) * transpose( M.column( 0 ) ), R[0], e ); 00287 ASSERT_MATRICES_EQUAL( a * M.column( 0 ) * transpose( M.column( 1 ) ), R[1], e ); 00288 ASSERT_MATRICES_EQUAL( a * M.column( 0 ) * transpose( M.column( 2 ) ), R[2], e ); 00289 ASSERT_MATRICES_EQUAL( a * M.column( 1 ) * transpose( M.column( 1 ) ), R[3], e ); 00290 ASSERT_MATRICES_EQUAL( a * M.column( 1 ) * transpose( M.column( 2 ) ), R[4], e ); 00291 ASSERT_MATRICES_EQUAL( a * M.column( 2 ) * transpose( M.column( 2 ) ), R[5], e ); 00292 #endif 00293 } 00294 00295 void TMPDerivsTest::test_set_scaled_outer_product() 00296 { 00297 const double vals[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9 }; 00298 const MsqMatrix< 3, 3 > M( vals ); 00299 const double a = 0.1212; 00300 const double e = 1e-12; 00301 00302 MsqMatrix< 3, 3 > R[6]; 00303 for( int i = 0; i < 6; ++i ) 00304 for( int r = 0; r < 3; ++r ) 00305 for( int c = 0; c < 3; ++c ) 00306 R[i]( r, c ) = 9 * i + 3 * r + c; 00307 set_scaled_outer_product( R, a, M ); 00308 00309 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00310 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 0 ) ) * M.row( 0 ), R[0], e ); 00311 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 0 ) ) * M.row( 1 ), R[1], e ); 00312 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 0 ) ) * M.row( 2 ), R[2], e ); 00313 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 1 ) ) * M.row( 1 ), R[3], e ); 00314 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 1 ) ) * M.row( 2 ), R[4], e ); 00315 ASSERT_MATRICES_EQUAL( a * transpose( M.row( 2 ) ) * M.row( 2 ), R[5], e ); 00316 #else 00317 ASSERT_MATRICES_EQUAL( a * M.column( 0 ) * transpose( M.column( 0 ) ), R[0], e ); 00318 ASSERT_MATRICES_EQUAL( a * M.column( 0 ) * transpose( M.column( 1 ) ), R[1], e ); 00319 ASSERT_MATRICES_EQUAL( a * M.column( 0 ) * transpose( M.column( 2 ) ), R[2], e ); 00320 ASSERT_MATRICES_EQUAL( a * M.column( 1 ) * transpose( M.column( 1 ) ), R[3], e ); 00321 ASSERT_MATRICES_EQUAL( a * M.column( 1 ) * transpose( M.column( 2 ) ), R[4], e ); 00322 ASSERT_MATRICES_EQUAL( a * M.column( 2 ) * transpose( M.column( 2 ) ), R[5], e ); 00323 #endif 00324 } 00325 00326 void TMPDerivsTest::test_set_scaled_sum_outer_product_3D() 00327 { 00328 const double vals1[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9 }; 00329 const double vals2[] = { -1, -2, -3, -4, -5, -6, -7, -8, -9 }; 00330 const MsqMatrix< 3, 3 > A( vals1 ), B( vals2 ); 00331 const double a = 2.3; 00332 const double e = 1e-12; 00333 00334 MsqMatrix< 3, 3 > R[6] = { 0.5, 0.5, 0.5, 0.5, 0.5, 0.5 }; 00335 set_scaled_sum_outer_product( R, a, A, B ); 00336 00337 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00338 const MsqMatrix< 3, 3 > E[6] = { transpose( A.row( 0 ) ) * B.row( 0 ) + transpose( B.row( 0 ) ) * A.row( 0 ), 00339 transpose( A.row( 0 ) ) * B.row( 1 ) + transpose( B.row( 0 ) ) * A.row( 1 ), 00340 transpose( A.row( 0 ) ) * B.row( 2 ) + transpose( B.row( 0 ) ) * A.row( 2 ), 00341 transpose( A.row( 1 ) ) * B.row( 1 ) + transpose( B.row( 1 ) ) * A.row( 1 ), 00342 transpose( A.row( 1 ) ) * B.row( 2 ) + transpose( B.row( 1 ) ) * A.row( 2 ), 00343 transpose( A.row( 2 ) ) * B.row( 2 ) + transpose( B.row( 2 ) ) * A.row( 2 ) }; 00344 #else 00345 const MsqMatrix< 3, 3 > E[6] = { 00346 A.column( 0 ) * transpose( B.column( 0 ) ) + B.column( 0 ) * transpose( A.column( 0 ) ), 00347 A.column( 0 ) * transpose( B.column( 1 ) ) + B.column( 0 ) * transpose( A.column( 1 ) ), 00348 A.column( 0 ) * transpose( B.column( 2 ) ) + B.column( 0 ) * transpose( A.column( 2 ) ), 00349 A.column( 1 ) * transpose( B.column( 1 ) ) + B.column( 1 ) * transpose( A.column( 1 ) ), 00350 A.column( 1 ) * transpose( B.column( 2 ) ) + B.column( 1 ) * transpose( A.column( 2 ) ), 00351 A.column( 2 ) * transpose( B.column( 2 ) ) + B.column( 2 ) * transpose( A.column( 2 ) ) }; 00352 #endif 00353 00354 ASSERT_MATRICES_EQUAL( a * E[0], R[0], e ); 00355 ASSERT_MATRICES_EQUAL( a * E[1], R[1], e ); 00356 ASSERT_MATRICES_EQUAL( a * E[2], R[2], e ); 00357 ASSERT_MATRICES_EQUAL( a * E[3], R[3], e ); 00358 ASSERT_MATRICES_EQUAL( a * E[4], R[4], e ); 00359 ASSERT_MATRICES_EQUAL( a * E[5], R[5], e ); 00360 } 00361 void TMPDerivsTest::test_set_scaled_sum_outer_product_2D() 00362 { 00363 const double vals1[] = { 1, 2, 3, 4 }; 00364 const double vals2[] = { -1, -2, -3, -4 }; 00365 const MsqMatrix< 2, 2 > A( vals1 ), B( vals2 ); 00366 const double a = 2.3; 00367 const double e = 1e-12; 00368 00369 MsqMatrix< 2, 2 > R[3] = { 0.0, 0.0, 0.0 }; 00370 pluseq_scaled_sum_outer_product( R, a, A, B ); 00371 00372 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00373 const MsqMatrix< 2, 2 > E[3] = { 00374 transpose( A.row( 0 ) ) * B.row( 0 ) + transpose( B.row( 0 ) ) * A.row( 0 ), 00375 transpose( A.row( 0 ) ) * B.row( 1 ) + transpose( B.row( 0 ) ) * A.row( 1 ), 00376 transpose( A.row( 1 ) ) * B.row( 1 ) + transpose( B.row( 1 ) ) * A.row( 1 ), 00377 }; 00378 #else 00379 const MsqMatrix< 2, 2 > E[3] = { 00380 A.column( 0 ) * transpose( B.column( 0 ) ) + B.column( 0 ) * transpose( A.column( 0 ) ), 00381 A.column( 0 ) * transpose( B.column( 1 ) ) + B.column( 0 ) * transpose( A.column( 1 ) ), 00382 A.column( 1 ) * transpose( B.column( 1 ) ) + B.column( 1 ) * transpose( A.column( 1 ) ), 00383 }; 00384 #endif 00385 00386 ASSERT_MATRICES_EQUAL( a * E[0], R[0], e ); 00387 ASSERT_MATRICES_EQUAL( a * E[1], R[1], e ); 00388 ASSERT_MATRICES_EQUAL( a * E[2], R[2], e ); 00389 } 00390 00391 void TMPDerivsTest::test_pluseq_scaled_sum_outer_product_3D() 00392 { 00393 const double vals1[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9 }; 00394 const double vals2[] = { -1, -2, -3, -4, -5, -6, -7, -8, -9 }; 00395 const MsqMatrix< 3, 3 > A( vals1 ), B( vals2 ); 00396 const double a = 2.3; 00397 const double e = 1e-12; 00398 00399 double off = 0.5; 00400 MsqMatrix< 3, 3 > R[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }; 00401 MsqMatrix< 3, 3 > S[6] = { off, off, off, off, off, off }; 00402 MsqMatrix< 3, 3 > E[6]; 00403 00404 pluseq_scaled_sum_outer_product( R, a, A, B ); 00405 pluseq_scaled_sum_outer_product( S, a, A, B ); 00406 set_scaled_sum_outer_product( E, a, A, B ); 00407 00408 ASSERT_MATRICES_EQUAL( E[0], R[0], e ); 00409 ASSERT_MATRICES_EQUAL( E[1], R[1], e ); 00410 ASSERT_MATRICES_EQUAL( E[2], R[2], e ); 00411 ASSERT_MATRICES_EQUAL( E[3], R[3], e ); 00412 ASSERT_MATRICES_EQUAL( E[4], R[4], e ); 00413 ASSERT_MATRICES_EQUAL( E[5], R[5], e ); 00414 00415 MsqMatrix< 3, 3 > P( off ); 00416 ASSERT_MATRICES_EQUAL( E[0] + P, S[0], e ); 00417 ASSERT_MATRICES_EQUAL( E[1] + P, S[1], e ); 00418 ASSERT_MATRICES_EQUAL( E[2] + P, S[2], e ); 00419 ASSERT_MATRICES_EQUAL( E[3] + P, S[3], e ); 00420 ASSERT_MATRICES_EQUAL( E[4] + P, S[4], e ); 00421 ASSERT_MATRICES_EQUAL( E[5] + P, S[5], e ); 00422 } 00423 00424 void TMPDerivsTest::test_pluseq_scaled_sum_outer_product_2D() 00425 { 00426 const double vals1[] = { 1, 2, 3, 4 }; 00427 const double vals2[] = { -1, -2, -3, -4 }; 00428 const MsqMatrix< 2, 2 > A( vals1 ), B( vals2 ); 00429 const double a = 2.3; 00430 const double e = 1e-12; 00431 00432 double off = 0.5; 00433 MsqMatrix< 2, 2 > R[3] = { 0.0, 0.0, 0.0 }; 00434 MsqMatrix< 2, 2 > S[3] = { off, off, off }; 00435 MsqMatrix< 2, 2 > E[3]; 00436 00437 pluseq_scaled_sum_outer_product( R, a, A, B ); 00438 pluseq_scaled_sum_outer_product( S, a, A, B ); 00439 set_scaled_sum_outer_product( E, a, A, B ); 00440 00441 ASSERT_MATRICES_EQUAL( E[0], R[0], e ); 00442 ASSERT_MATRICES_EQUAL( E[1], R[1], e ); 00443 ASSERT_MATRICES_EQUAL( E[2], R[2], e ); 00444 00445 MsqMatrix< 2, 2 > P( off ); 00446 ASSERT_MATRICES_EQUAL( E[0] + P, S[0], e ); 00447 ASSERT_MATRICES_EQUAL( E[1] + P, S[1], e ); 00448 ASSERT_MATRICES_EQUAL( E[2] + P, S[2], e ); 00449 } 00450 00451 void TMPDerivsTest::test_pluseq_scaled_sum_outer_product_I_3D() 00452 { 00453 const double e = 1e-12; 00454 const double vals[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9 }; 00455 const MsqMatrix< 3, 3 > A( vals ), I( 1.0 ); 00456 00457 MsqMatrix< 3, 3 > R[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }; 00458 MsqMatrix< 3, 3 > S[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }; 00459 pluseq_scaled_sum_outer_product( R, 1.0, I, A ); 00460 pluseq_scaled_sum_outer_product_I( S, 1.0, A ); 00461 ASSERT_MATRICES_EQUAL( R[0], S[0], e ); 00462 ASSERT_MATRICES_EQUAL( R[1], S[1], e ); 00463 ASSERT_MATRICES_EQUAL( R[2], S[2], e ); 00464 ASSERT_MATRICES_EQUAL( R[3], S[3], e ); 00465 ASSERT_MATRICES_EQUAL( R[4], S[4], e ); 00466 ASSERT_MATRICES_EQUAL( R[5], S[5], e ); 00467 00468 MsqMatrix< 3, 3 > T[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }; 00469 MsqMatrix< 3, 3 > U[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }; 00470 pluseq_scaled_sum_outer_product( R, -0.333, I, A ); 00471 pluseq_scaled_sum_outer_product_I( S, -0.333, A ); 00472 ASSERT_MATRICES_EQUAL( T[0], U[0], e ); 00473 ASSERT_MATRICES_EQUAL( T[1], U[1], e ); 00474 ASSERT_MATRICES_EQUAL( T[2], U[2], e ); 00475 ASSERT_MATRICES_EQUAL( T[3], U[3], e ); 00476 ASSERT_MATRICES_EQUAL( T[4], U[4], e ); 00477 ASSERT_MATRICES_EQUAL( T[5], U[5], e ); 00478 } 00479 00480 void TMPDerivsTest::test_pluseq_scaled_sum_outer_product_I_2D() 00481 { 00482 const double e = 1e-12; 00483 const double vals[] = { 1, 2, 3, 4 }; 00484 const MsqMatrix< 2, 2 > A( vals ), I( 1.0 ); 00485 00486 MsqMatrix< 2, 2 > R[3] = { 0.0, 0.0, 0.0 }; 00487 MsqMatrix< 2, 2 > S[3] = { 0.0, 0.0, 0.0 }; 00488 pluseq_scaled_sum_outer_product( R, 1.0, I, A ); 00489 pluseq_scaled_sum_outer_product_I( S, 1.0, A ); 00490 ASSERT_MATRICES_EQUAL( R[0], S[0], e ); 00491 ASSERT_MATRICES_EQUAL( R[1], S[1], e ); 00492 ASSERT_MATRICES_EQUAL( R[2], S[2], e ); 00493 00494 MsqMatrix< 2, 2 > T[3] = { 0.0, 0.0, 0.0 }; 00495 MsqMatrix< 2, 2 > U[3] = { 0.0, 0.0, 0.0 }; 00496 pluseq_scaled_sum_outer_product( R, -0.333, I, A ); 00497 pluseq_scaled_sum_outer_product_I( S, -0.333, A ); 00498 ASSERT_MATRICES_EQUAL( T[0], U[0], e ); 00499 ASSERT_MATRICES_EQUAL( T[1], U[1], e ); 00500 ASSERT_MATRICES_EQUAL( T[2], U[2], e ); 00501 } 00502 00503 void TMPDerivsTest::test_pluseq_scaled_outer_product_I_I_2D() 00504 { 00505 const double e = 1e-12; 00506 MsqMatrix< 2, 2 > R[3] = { 0.0, 0.0, 0.0 }, S[3] = { 0.0, 0.0, 0.0 }; 00507 const double alpha = 3.14; 00508 pluseq_scaled_outer_product( R, alpha, MsqMatrix< 2, 2 >( 1.0 ) ); 00509 pluseq_scaled_outer_product_I_I( S, alpha ); 00510 ASSERT_MATRICES_EQUAL( R[0], S[0], e ); 00511 ASSERT_MATRICES_EQUAL( R[1], S[1], e ); 00512 ASSERT_MATRICES_EQUAL( R[2], S[2], e ); 00513 } 00514 00515 void TMPDerivsTest::test_pluseq_scaled_outer_product_I_I_3D() 00516 { 00517 const double e = 1e-12; 00518 MsqMatrix< 3, 3 > R[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }, S[6] = { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }; 00519 const double alpha = 3.14; 00520 pluseq_scaled_outer_product( R, alpha, MsqMatrix< 3, 3 >( 1.0 ) ); 00521 pluseq_scaled_outer_product_I_I( S, alpha ); 00522 ASSERT_MATRICES_EQUAL( R[0], S[0], e ); 00523 ASSERT_MATRICES_EQUAL( R[1], S[1], e ); 00524 ASSERT_MATRICES_EQUAL( R[2], S[2], e ); 00525 ASSERT_MATRICES_EQUAL( R[3], S[3], e ); 00526 ASSERT_MATRICES_EQUAL( R[4], S[4], e ); 00527 ASSERT_MATRICES_EQUAL( R[5], S[5], e ); 00528 } 00529 00530 static inline MsqMatrix< 3, 3 > first_deriv_norm_sqr_adj( const MsqMatrix< 3, 3 >& T ) 00531 { 00532 return 2 * ( ( sqr_Frobenius( T ) * T ) - ( T * transpose( T ) * T ) ); 00533 } 00534 00535 void TMPDerivsTest::test_set_scaled_2nd_deriv_norm_sqr_adj() 00536 { 00537 const double e = 5e-2; 00538 const double delta = 1e-3; 00539 const double vals[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9 }; 00540 const MsqMatrix< 3, 3 > A( vals ); 00541 const MsqMatrix< 3, 3 > dA = first_deriv_norm_sqr_adj( A ); 00542 00543 MsqMatrix< 3, 3 > actual[6] = { -1, -1, -1, -1, -1, -1 }; 00544 set_scaled_2nd_deriv_norm_sqr_adj( actual, 1.0, A ); 00545 00546 MsqMatrix< 3, 3 > B( A ); 00547 B( 0, 0 ) += delta; 00548 MsqMatrix< 3, 3 > dB = first_deriv_norm_sqr_adj( B ); 00549 dB -= dA; 00550 dB /= delta; 00551 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 0, 0 ), actual[0]( 0, 0 ), e ); 00552 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 0, 1 ), actual[0]( 0, 1 ), e ); 00553 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 0, 2 ), actual[0]( 0, 2 ), e ); 00554 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 0 ), actual[1]( 0, 0 ), e ); 00555 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 1 ), actual[1]( 0, 1 ), e ); 00556 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 2 ), actual[1]( 0, 2 ), e ); 00557 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 0 ), actual[2]( 0, 0 ), e ); 00558 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 1 ), actual[2]( 0, 1 ), e ); 00559 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 2 ), actual[2]( 0, 2 ), e ); 00560 00561 B = A; 00562 B( 0, 1 ) += delta; 00563 dB = first_deriv_norm_sqr_adj( B ); 00564 dB -= dA; 00565 dB /= delta; 00566 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 0, 0 ), actual[0]( 1, 0 ), e ); 00567 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 0, 1 ), actual[0]( 1, 1 ), e ); 00568 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 0, 2 ), actual[0]( 1, 2 ), e ); 00569 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 0 ), actual[1]( 1, 0 ), e ); 00570 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 1 ), actual[1]( 1, 1 ), e ); 00571 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 2 ), actual[1]( 1, 2 ), e ); 00572 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 0 ), actual[2]( 1, 0 ), e ); 00573 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 1 ), actual[2]( 1, 1 ), e ); 00574 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 2 ), actual[2]( 1, 2 ), e ); 00575 00576 B = A; 00577 B( 0, 2 ) += delta; 00578 dB = first_deriv_norm_sqr_adj( B ); 00579 dB -= dA; 00580 dB /= delta; 00581 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 0, 0 ), actual[0]( 2, 0 ), e ); 00582 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 0, 1 ), actual[0]( 2, 1 ), e ); 00583 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 0, 2 ), actual[0]( 2, 2 ), e ); 00584 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 0 ), actual[1]( 2, 0 ), e ); 00585 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 1 ), actual[1]( 2, 1 ), e ); 00586 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 2 ), actual[1]( 2, 2 ), e ); 00587 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 0 ), actual[2]( 2, 0 ), e ); 00588 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 1 ), actual[2]( 2, 1 ), e ); 00589 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 2 ), actual[2]( 2, 2 ), e ); 00590 00591 B = A; 00592 B( 1, 0 ) += delta; 00593 dB = first_deriv_norm_sqr_adj( B ); 00594 dB -= dA; 00595 dB /= delta; 00596 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 0 ), actual[3]( 0, 0 ), e ); 00597 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 1 ), actual[3]( 0, 1 ), e ); 00598 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 2 ), actual[3]( 0, 2 ), e ); 00599 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 0 ), actual[4]( 0, 0 ), e ); 00600 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 1 ), actual[4]( 0, 1 ), e ); 00601 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 2 ), actual[4]( 0, 2 ), e ); 00602 00603 B = A; 00604 B( 1, 1 ) += delta; 00605 dB = first_deriv_norm_sqr_adj( B ); 00606 dB -= dA; 00607 dB /= delta; 00608 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 0 ), actual[3]( 1, 0 ), e ); 00609 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 1 ), actual[3]( 1, 1 ), e ); 00610 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 2 ), actual[3]( 1, 2 ), e ); 00611 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 0 ), actual[4]( 1, 0 ), e ); 00612 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 1 ), actual[4]( 1, 1 ), e ); 00613 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 2 ), actual[4]( 1, 2 ), e ); 00614 00615 B = A; 00616 B( 1, 2 ) += delta; 00617 dB = first_deriv_norm_sqr_adj( B ); 00618 dB -= dA; 00619 dB /= delta; 00620 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 0 ), actual[3]( 2, 0 ), e ); 00621 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 1 ), actual[3]( 2, 1 ), e ); 00622 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 1, 2 ), actual[3]( 2, 2 ), e ); 00623 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 0 ), actual[4]( 2, 0 ), e ); 00624 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 1 ), actual[4]( 2, 1 ), e ); 00625 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 2 ), actual[4]( 2, 2 ), e ); 00626 00627 B = A; 00628 B( 2, 0 ) += delta; 00629 dB = first_deriv_norm_sqr_adj( B ); 00630 dB -= dA; 00631 dB /= delta; 00632 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 0 ), actual[5]( 0, 0 ), e ); 00633 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 1 ), actual[5]( 0, 1 ), e ); 00634 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 2 ), actual[5]( 0, 2 ), e ); 00635 00636 B = A; 00637 B( 2, 1 ) += delta; 00638 dB = first_deriv_norm_sqr_adj( B ); 00639 dB -= dA; 00640 dB /= delta; 00641 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 0 ), actual[5]( 1, 0 ), e ); 00642 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 1 ), actual[5]( 1, 1 ), e ); 00643 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 2 ), actual[5]( 1, 2 ), e ); 00644 00645 B = A; 00646 B( 2, 2 ) += delta; 00647 dB = first_deriv_norm_sqr_adj( B ); 00648 dB -= dA; 00649 dB /= delta; 00650 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 0 ), actual[5]( 2, 0 ), e ); 00651 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 1 ), actual[5]( 2, 1 ), e ); 00652 CPPUNIT_ASSERT_DOUBLES_EQUAL( dB( 2, 2 ), actual[5]( 2, 2 ), e ); 00653 }
