MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2009 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2009) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file TShapeSize2DNB2.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "TShapeSize2DNB2.hpp" 00034 #include "MsqMatrix.hpp" 00035 #include "TMPDerivs.hpp" 00036 00037 namespace MBMesquite 00038 { 00039 00040 std::string TShapeSize2DNB2::get_name() const 00041 { 00042 return "TShapeSize2DNB2"; 00043 } 00044 00045 TShapeSize2DNB2::~TShapeSize2DNB2() {} 00046 00047 /** \f$ \mu(T) = \frac{|T|^2+2}{2\psi(T)} - 1 \f$ 00048 * \f$ \psi(T) = \sqrt{|T|^2 + 2 \tau}\f$ 00049 * \f$ \tau = det(T) \f$ 00050 */ 00051 bool TShapeSize2DNB2::evaluate( const MsqMatrix< 2, 2 >& T, double& result, MsqError& ) 00052 { 00053 double frob_sqr = sqr_Frobenius( T ); 00054 double psi = sqrt( frob_sqr + 2.0 * det( T ) ); 00055 00056 double a = 1e-12; 00057 while( !MBMesquite::divide( frob_sqr + 2, 2 * psi, result ) ) 00058 { 00059 MsqMatrix< 2, 2 > Tdelta( T ); 00060 Tdelta( 0, 0 ) += a; 00061 Tdelta( 1, 1 ) += a; 00062 a *= 2.0; 00063 frob_sqr = sqr_Frobenius( Tdelta ); 00064 psi = sqrt( frob_sqr + 2.0 * det( Tdelta ) ); 00065 if( psi > 1e-50 ) result = ( frob_sqr + 2 ) / 2 * psi; 00066 } 00067 00068 result -= 1.0; 00069 return true; 00070 } 00071 00072 bool TShapeSize2DNB2::evaluate_with_grad( const MsqMatrix< 2, 2 >& T, double& result, MsqMatrix< 2, 2 >& deriv_wrt_T, 00073 MsqError& /*err*/ ) 00074 { 00075 double frob_sqr = sqr_Frobenius( T ); 00076 double psi = sqrt( frob_sqr + 2.0 * det( T ) ); 00077 00078 double a = 1e-12; 00079 while( !MBMesquite::divide( frob_sqr + 2, 2 * psi, result ) ) 00080 { 00081 MsqMatrix< 2, 2 > Tdelta( T ); 00082 Tdelta( 0, 0 ) += a; 00083 Tdelta( 1, 1 ) += a; 00084 a *= 2.0; 00085 frob_sqr = sqr_Frobenius( Tdelta ); 00086 psi = sqrt( frob_sqr + 2.0 * det( Tdelta ) ); 00087 if( psi > 1e-50 ) result = ( frob_sqr + 2 ) / 2 * psi; 00088 } 00089 00090 // MsqMatrix<2,2> d_psi = 1.0/psi * (T + transpose_adj(T)); 00091 // deriv_wrt_T = (1.0/psi) * (T - result * d_psi); 00092 if( psi > 1e-50 ) 00093 { 00094 const double f = result / ( psi * psi ); 00095 deriv_wrt_T = transpose_adj( T ); 00096 deriv_wrt_T *= -f; 00097 deriv_wrt_T += ( 1.0 / psi - f ) * T; 00098 } 00099 00100 result -= 1.0; 00101 00102 return true; 00103 } 00104 00105 bool TShapeSize2DNB2::evaluate_with_hess( const MsqMatrix< 2, 2 >& T, double& result, MsqMatrix< 2, 2 >& deriv_wrt_T, 00106 MsqMatrix< 2, 2 > second[3], MsqError& /*err*/ ) 00107 { 00108 double frob_sqr = sqr_Frobenius( T ); 00109 double psi = sqrt( frob_sqr + 2.0 * det( T ) ); 00110 00111 double a = 1e-12; 00112 while( !MBMesquite::divide( frob_sqr + 2, 2 * psi, result ) ) 00113 { 00114 MsqMatrix< 2, 2 > Tdelta( T ); 00115 Tdelta( 0, 0 ) += a; 00116 Tdelta( 1, 1 ) += a; 00117 a *= 2.0; 00118 frob_sqr = sqr_Frobenius( Tdelta ); 00119 psi = sqrt( frob_sqr + 2.0 * det( Tdelta ) ); 00120 if( psi > 1e-50 ) result = ( frob_sqr + 2 ) / 2 * psi; 00121 } 00122 00123 const double inv_psi = 1.0 / psi; 00124 MsqMatrix< 2, 2 > d_psi = T + transpose_adj( T ); 00125 d_psi *= inv_psi; 00126 00127 deriv_wrt_T = d_psi; 00128 deriv_wrt_T *= -result; 00129 deriv_wrt_T += T; 00130 deriv_wrt_T *= inv_psi; 00131 00132 set_scaled_2nd_deriv_wrt_psi( second, -result * inv_psi, psi, T ); 00133 pluseq_scaled_outer_product( second, 2 * result * inv_psi * inv_psi, d_psi ); 00134 pluseq_scaled_sum_outer_product( second, -inv_psi * inv_psi, d_psi, T ); 00135 pluseq_scaled_I( second, inv_psi ); 00136 00137 result -= 1.0; 00138 00139 return true; 00140 } 00141 00142 } // namespace MBMesquite
