MOAB  4.9.3pre
UnaryFunctors.h File Reference
Classes
struct  Eigen::internal::scalar_opposite_op< Scalar >
 Template functor to compute the opposite of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_opposite_op< Scalar > >
struct  Eigen::internal::scalar_abs_op< Scalar >
 Template functor to compute the absolute value of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_abs_op< Scalar > >
struct  Eigen::internal::scalar_score_coeff_op< Scalar >
 Template functor to compute the score of a scalar, to chose a pivot. More...
struct  Eigen::internal::functor_traits< scalar_score_coeff_op< Scalar > >
struct  Eigen::internal::abs_knowing_score< Scalar, typename >
struct  Eigen::internal::abs_knowing_score< Scalar, typename scalar_score_coeff_op< Scalar >::Score_is_abs >
struct  Eigen::internal::scalar_abs2_op< Scalar >
 Template functor to compute the squared absolute value of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_abs2_op< Scalar > >
struct  Eigen::internal::scalar_conjugate_op< Scalar >
 Template functor to compute the conjugate of a complex value. More...
struct  Eigen::internal::functor_traits< scalar_conjugate_op< Scalar > >
struct  Eigen::internal::scalar_arg_op< Scalar >
 Template functor to compute the phase angle of a complex. More...
struct  Eigen::internal::functor_traits< scalar_arg_op< Scalar > >
struct  Eigen::internal::scalar_cast_op< Scalar, NewType >
 Template functor to cast a scalar to another type. More...
struct  Eigen::internal::functor_traits< scalar_cast_op< Scalar, NewType > >
struct  Eigen::internal::scalar_real_op< Scalar >
 Template functor to extract the real part of a complex. More...
struct  Eigen::internal::functor_traits< scalar_real_op< Scalar > >
struct  Eigen::internal::scalar_imag_op< Scalar >
 Template functor to extract the imaginary part of a complex. More...
struct  Eigen::internal::functor_traits< scalar_imag_op< Scalar > >
struct  Eigen::internal::scalar_real_ref_op< Scalar >
 Template functor to extract the real part of a complex as a reference. More...
struct  Eigen::internal::functor_traits< scalar_real_ref_op< Scalar > >
struct  Eigen::internal::scalar_imag_ref_op< Scalar >
 Template functor to extract the imaginary part of a complex as a reference. More...
struct  Eigen::internal::functor_traits< scalar_imag_ref_op< Scalar > >
struct  Eigen::internal::scalar_exp_op< Scalar >
 Template functor to compute the exponential of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_exp_op< Scalar > >
struct  Eigen::internal::scalar_log_op< Scalar >
 Template functor to compute the logarithm of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_log_op< Scalar > >
struct  Eigen::internal::scalar_log10_op< Scalar >
 Template functor to compute the base-10 logarithm of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_log10_op< Scalar > >
struct  Eigen::internal::scalar_sqrt_op< Scalar >
 Template functor to compute the square root of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_sqrt_op< Scalar > >
struct  Eigen::internal::scalar_rsqrt_op< Scalar >
 Template functor to compute the reciprocal square root of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_rsqrt_op< Scalar > >
struct  Eigen::internal::scalar_cos_op< Scalar >
 Template functor to compute the cosine of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_cos_op< Scalar > >
struct  Eigen::internal::scalar_sin_op< Scalar >
 Template functor to compute the sine of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_sin_op< Scalar > >
struct  Eigen::internal::scalar_tan_op< Scalar >
 Template functor to compute the tan of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_tan_op< Scalar > >
struct  Eigen::internal::scalar_acos_op< Scalar >
 Template functor to compute the arc cosine of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_acos_op< Scalar > >
struct  Eigen::internal::scalar_asin_op< Scalar >
 Template functor to compute the arc sine of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_asin_op< Scalar > >
struct  Eigen::internal::scalar_lgamma_op< Scalar >
 Template functor to compute the natural log of the absolute value of Gamma of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_lgamma_op< Scalar > >
struct  Eigen::internal::scalar_digamma_op< Scalar >
 Template functor to compute psi, the derivative of lgamma of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_digamma_op< Scalar > >
struct  Eigen::internal::scalar_erf_op< Scalar >
 Template functor to compute the Gauss error function of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_erf_op< Scalar > >
struct  Eigen::internal::scalar_erfc_op< Scalar >
 Template functor to compute the Complementary Error Function of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_erfc_op< Scalar > >
struct  Eigen::internal::scalar_atan_op< Scalar >
 Template functor to compute the atan of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_atan_op< Scalar > >
struct  Eigen::internal::scalar_tanh_op< Scalar >
 Template functor to compute the tanh of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_tanh_op< Scalar > >
struct  Eigen::internal::scalar_sinh_op< Scalar >
 Template functor to compute the sinh of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_sinh_op< Scalar > >
struct  Eigen::internal::scalar_cosh_op< Scalar >
 Template functor to compute the cosh of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_cosh_op< Scalar > >
struct  Eigen::internal::scalar_inverse_op< Scalar >
 Template functor to compute the inverse of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_inverse_op< Scalar > >
struct  Eigen::internal::scalar_square_op< Scalar >
 Template functor to compute the square of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_square_op< Scalar > >
struct  Eigen::internal::scalar_cube_op< Scalar >
 Template functor to compute the cube of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_cube_op< Scalar > >
struct  Eigen::internal::scalar_round_op< Scalar >
 Template functor to compute the rounded value of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_round_op< Scalar > >
struct  Eigen::internal::scalar_floor_op< Scalar >
 Template functor to compute the floor of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_floor_op< Scalar > >
struct  Eigen::internal::scalar_ceil_op< Scalar >
 Template functor to compute the ceil of a scalar. More...
struct  Eigen::internal::functor_traits< scalar_ceil_op< Scalar > >
struct  Eigen::internal::scalar_isnan_op< Scalar >
 Template functor to compute whether a scalar is NaN. More...
struct  Eigen::internal::functor_traits< scalar_isnan_op< Scalar > >
struct  Eigen::internal::scalar_isinf_op< Scalar >
 Template functor to check whether a scalar is +/-inf. More...
struct  Eigen::internal::functor_traits< scalar_isinf_op< Scalar > >
struct  Eigen::internal::scalar_isfinite_op< Scalar >
 Template functor to check whether a scalar has a finite value. More...
struct  Eigen::internal::functor_traits< scalar_isfinite_op< Scalar > >
struct  Eigen::internal::scalar_boolean_not_op< Scalar >
 Template functor to compute the logical not of a boolean. More...
struct  Eigen::internal::functor_traits< scalar_boolean_not_op< Scalar > >
struct  Eigen::internal::scalar_sign_op< Scalar, false >
struct  Eigen::internal::scalar_sign_op< Scalar, true >
struct  Eigen::internal::functor_traits< scalar_sign_op< Scalar > >
Namespaces
namespace  Eigen
namespace  Eigen::internal
