MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retian certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file VertexConditionNumberTest.cpp 00028 * \brief unit tests for VertexConditionNumberQualityMetric 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "VertexConditionNumberQualityMetric.hpp" 00034 #include "cppunit/extensions/HelperMacros.h" 00035 #include "QualityMetricTester.hpp" 00036 00037 using namespace MBMesquite; 00038 00039 class VertexConditionNumberTest : public CppUnit::TestFixture 00040 { 00041 private: 00042 CPPUNIT_TEST_SUITE( VertexConditionNumberTest ); 00043 00044 CPPUNIT_TEST( test_supported_types ); 00045 CPPUNIT_TEST( test_ideal_element_eval ); 00046 CPPUNIT_TEST( test_ideal_element_grad ); 00047 CPPUNIT_TEST( test_measures_quality ); 00048 CPPUNIT_TEST( test_gradient_reflects_quality ); 00049 CPPUNIT_TEST( test_inverted_elements ); 00050 CPPUNIT_TEST( test_degenerate_elements ); 00051 CPPUNIT_TEST( test_get_evaluations ); 00052 CPPUNIT_TEST( test_get_element_indices ); 00053 CPPUNIT_TEST( test_get_fixed_indices ); 00054 CPPUNIT_TEST( test_eval_with_indices ); 00055 CPPUNIT_TEST( test_location_invariant ); 00056 CPPUNIT_TEST( test_orient_invariant ); 00057 00058 CPPUNIT_TEST_SUITE_END(); 00059 00060 VertexConditionNumberQualityMetric mMetric; 00061 QualityMetricTester tester; 00062 00063 public: 00064 VertexConditionNumberTest() : tester( QualityMetricTester::NON_MIXED_FE ) {} 00065 00066 void test_supported_types() 00067 { 00068 tester.test_supported_element_types( &mMetric ); 00069 } 00070 00071 void test_ideal_element_eval() 00072 { 00073 tester.test_evaluate_unit_tris_about_vertex( &mMetric, 1.0 ); 00074 tester.test_evaluate_unit_quads_about_vertex( &mMetric, 1.0 ); 00075 tester.test_evaluate_unit_hexes_about_vertex( &mMetric, 1.0 ); 00076 00077 tester.test_evaluate_unit_edge_element( &mMetric, TRIANGLE, 1.0 ); 00078 tester.test_evaluate_unit_edge_element( &mMetric, QUADRILATERAL, 1.0 ); 00079 tester.test_evaluate_unit_edge_element( &mMetric, TETRAHEDRON, 1.0 ); 00080 tester.test_evaluate_unit_edge_element( &mMetric, HEXAHEDRON, 1.0 ); 00081 } 00082 00083 void test_ideal_element_grad() 00084 { 00085 tester.test_ideal_element_zero_vertex_gradient( &mMetric, false ); 00086 } 00087 00088 void test_measures_quality() 00089 { 00090 tester.test_measures_vertex_quality( &mMetric ); 00091 } 00092 00093 void test_gradient_reflects_quality() 00094 { 00095 tester.test_vertex_gradient_reflects_quality( &mMetric ); 00096 } 00097 00098 void test_inverted_elements() 00099 { 00100 tester.test_evaluate_inverted_element( &mMetric, false ); 00101 } 00102 00103 void test_degenerate_elements() 00104 { 00105 tester.test_evaluate_degenerate_element( &mMetric, false ); 00106 } 00107 00108 void test_get_evaluations() 00109 { 00110 tester.test_get_vertex_evaluations( &mMetric ); 00111 } 00112 00113 void test_get_element_indices() 00114 { 00115 tester.test_get_vertex_indices( &mMetric ); 00116 } 00117 00118 void test_get_fixed_indices() 00119 { 00120 tester.test_get_indices_fixed( &mMetric ); 00121 } 00122 00123 void test_eval_with_indices() 00124 { 00125 tester.compare_eval_and_eval_with_indices( &mMetric ); 00126 } 00127 00128 void test_location_invariant() 00129 { 00130 tester.test_location_invariant( &mMetric ); 00131 tester.test_grad_location_invariant( &mMetric ); 00132 } 00133 00134 void test_orient_invariant() 00135 { 00136 tester.test_orient_invariant( &mMetric ); 00137 tester.test_grad_orient_invariant( &mMetric ); 00138 } 00139 }; 00140 00141 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( VertexConditionNumberTest, "VertexConditionNumberTest" ); 00142 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( VertexConditionNumberTest, "Unit" );
