MOAB: Mesh Oriented datABase
(version 5.3.1)
Computes the condition numbers of the corner's of elements connected to the given vertex and then averages those values. More...
#include <VertexConditionNumberQualityMetric.hpp>
Public Member Functions | |
VertexConditionNumberQualityMetric () | |
virtual | ~VertexConditionNumberQualityMetric () |
virtual destructor ensures use of polymorphism during destruction | |
virtual std::string | get_name () const |
virtual int | get_negate_flag () const |
1 if metric should be minimized, -1 if metric should be maximized. | |
virtual bool | evaluate (PatchData &pd, size_t handle, double &value, MsqError &err) |
Get metric value at a logical location in the patch. | |
virtual bool | evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err) |
The metric does not use the sample point functionality or the compute_weighted_jacobian. It uses the isotropic ideal element. This metric does require a feasible region, and the metric needs to be minimized.
Definition at line 53 of file VertexConditionNumberQualityMetric.hpp.
Definition at line 44 of file VertexConditionNumberQualityMetric.cpp.
: AveragingQM( QualityMetric::LINEAR ) {}
virtual MBMesquite::VertexConditionNumberQualityMetric::~VertexConditionNumberQualityMetric | ( | ) | [inline, virtual] |
Definition at line 59 of file VertexConditionNumberQualityMetric.hpp.
bool VertexConditionNumberQualityMetric::evaluate | ( | PatchData & | pd, |
size_t | handle, | ||
double & | value, | ||
MsqError & | err | ||
) | [virtual] |
Evaluate the metric at one location in the PatchData.
pd | The patch. |
handle | The location in the patch (as passed back from get_evaluations). |
value | The output metric value. |
Implements MBMesquite::QualityMetric.
Definition at line 56 of file VertexConditionNumberQualityMetric.cpp.
References MBMesquite::arrptr(), MBMesquite::AveragingQM::average_metrics(), MBMesquite::condition_number_2d(), MBMesquite::condition_number_3d(), MBMesquite::MsqMeshEntity::get_connected_vertices(), MBMesquite::PatchData::get_element_array(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::PatchData::get_vertex_element_adjacencies(), MBMesquite::HEXAHEDRON, MSQ_ERRZERO, MBMesquite::MSQ_MAX_CAP, MSQ_SETERR, MBMesquite::MSQ_SQRT_THREE, MBMesquite::MSQ_SQRT_THREE_INV, MBMesquite::MSQ_SQRT_TWO, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by evaluate_with_indices().
{ // pd.generate_vertex_to_element_data(); bool return_flag; fval = MSQ_MAX_CAP; // get the element array MsqMeshEntity* elems = pd.get_element_array( err ); // get the vertex to element array and the offset array // const size_t* elem_offset = pd.get_vertex_to_elem_offset(err); MSQ_ERRZERO(err); // const size_t* v_to_e_array = pd.get_vertex_to_elem_array(err); MSQ_ERRZERO(err); // find the offset for this vertex // size_t this_offset = elem_offset[this_vert]; // get the number of elements attached to this vertex (given by the // first entry in the vertex to element array) // size_t num_elems = v_to_e_array[this_offset]; // PRINT_INFO("\nIN LOCAL SIZE CPP, num_elements = %i",num_elems); // if no elements, then return true size_t num_elems; const size_t* v_to_e_array = pd.get_vertex_element_adjacencies( this_vert, num_elems, err ); MSQ_ERRZERO( err ); if( num_elems <= 0 ) { return true; } // create an array to store the local metric values before averaging // Can we remove this dynamic allocatio? std::vector< double > met_vals( num_elems ); // vector to hold the other verts which form a corner. vector< size_t > other_vertices; other_vertices.reserve( 4 ); size_t i = 0; // only 3 temp_vec will be sent to cond-num calculator, but the // additional vector3Ds may be needed during the calculations size_t elem_index; Vector3D temp_vec[6]; const MsqVertex* vertices = pd.get_vertex_array( err ); // loop over the elements attached to this vertex for( i = 0; i < num_elems; ++i ) { // get the vertices connected to this vertex for this element elem_index = v_to_e_array[i]; elems[elem_index].get_connected_vertices( this_vert, other_vertices, err ); MSQ_ERRZERO( err ); // switch over the element type of this element switch( elems[v_to_e_array[i]].get_element_type() ) { case TRIANGLE: temp_vec[0] = vertices[other_vertices[0]] - vertices[this_vert]; temp_vec[2] = vertices[other_vertices[1]] - vertices[this_vert]; // make relative to equilateral temp_vec[1] = ( ( 2 * temp_vec[2] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV; return_flag = condition_number_2d( temp_vec, elem_index, pd, met_vals[i], err ); MSQ_ERRZERO( err ); if( !return_flag ) return return_flag; break; case QUADRILATERAL: temp_vec[0] = vertices[other_vertices[0]] - vertices[this_vert]; temp_vec[1] = vertices[other_vertices[1]] - vertices[this_vert]; return_flag = condition_number_2d( temp_vec, elem_index, pd, met_vals[i], err ); MSQ_ERRZERO( err ); if( !return_flag ) return return_flag; break; case TETRAHEDRON: temp_vec[0] = vertices[other_vertices[0]] - vertices[this_vert]; temp_vec[3] = vertices[other_vertices[1]] - vertices[this_vert]; temp_vec[4] = vertices[other_vertices[2]] - vertices[this_vert]; // transform to equilateral tet temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) / MSQ_SQRT_THREE; temp_vec[2] = ( ( 3 * temp_vec[4] ) - temp_vec[0] - temp_vec[3] ) / ( MSQ_SQRT_THREE * MSQ_SQRT_TWO ); return_flag = condition_number_3d( temp_vec, pd, met_vals[i], err ); MSQ_ERRZERO( err ); if( !return_flag ) return return_flag; break; case HEXAHEDRON: temp_vec[0] = vertices[other_vertices[0]] - vertices[this_vert]; temp_vec[1] = vertices[other_vertices[1]] - vertices[this_vert]; temp_vec[2] = vertices[other_vertices[2]] - vertices[this_vert]; return_flag = condition_number_3d( temp_vec, pd, met_vals[i], err ); MSQ_ERRZERO( err ); if( !return_flag ) return return_flag; break; default: MSQ_SETERR( err ) ( MsqError::UNSUPPORTED_ELEMENT, "Element type (%d) not uspported in VertexConditionNumberQM.\n", (int)( elems[v_to_e_array[i]].get_element_type() ) ); fval = MSQ_MAX_CAP; return false; } // end switch over element type other_vertices.clear(); } // end loop over elements fval = average_metrics( arrptr( met_vals ), num_elems, err ); MSQ_ERRZERO( err ); return true; }
bool VertexConditionNumberQualityMetric::evaluate_with_indices | ( | PatchData & | pd, |
std::vector< size_t > & | indices, | ||
) | [virtual] |
pd | The patch. |
indices | The free vertices that the evaluation is a function of, specified as vertex indices in the PatchData. |
Definition at line 152 of file VertexConditionNumberQualityMetric.cpp.
References evaluate(), MBMesquite::MsqMeshEntity::get_connected_vertices(), MBMesquite::PatchData::get_element_array(), MBMesquite::PatchData::get_vertex_element_adjacencies(), MSQ_ERRFALSE, MSQ_ERRZERO, and MBMesquite::PatchData::num_free_vertices().
{ bool rval = evaluate( pd, this_vert, value, err ); MSQ_ERRFALSE( err ); indices.clear(); MsqMeshEntity* elems = pd.get_element_array( err ); size_t num_elems; const size_t* v_to_e_array = pd.get_vertex_element_adjacencies( this_vert, num_elems, err ); MSQ_ERRZERO( err ); // vector to hold the other verts which form a corner. vector< size_t > other_vertices; other_vertices.reserve( 4 ); size_t i = 0; // loop over the elements attached to this vertex for( i = 0; i < num_elems; ++i ) { // get the vertices connected to this vertex for this element elems[v_to_e_array[i]].get_connected_vertices( this_vert, other_vertices, err ); MSQ_ERRZERO( err ); for( unsigned j = 0; j < other_vertices.size(); ++j ) { if( other_vertices[j] < pd.num_free_vertices() ) indices.push_back( other_vertices[j] ); } } std::sort( indices.begin(), indices.end() ); indices.erase( std::unique( indices.begin(), indices.end() ), indices.end() ); if( this_vert < pd.num_free_vertices() ) indices.push_back( this_vert ); return rval; }
std::string VertexConditionNumberQualityMetric::get_name | ( | ) | const [virtual] |
Definition at line 46 of file VertexConditionNumberQualityMetric.cpp.
{ return "Vertex Condition Number"; }
int VertexConditionNumberQualityMetric::get_negate_flag | ( | ) | const [virtual] |
Definition at line 51 of file VertexConditionNumberQualityMetric.cpp.
return 1;
