MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2009 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2009) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file ViscousCFDTetShapeWrapper.hpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #ifndef MSQ_VISCOUS_CFD_TET_SHAPE_WRAPPER_HPP 00033 #define MSQ_VISCOUS_CFD_TET_SHAPE_WRAPPER_HPP 00034 00035 #include "Mesquite.hpp" 00036 #include "Wrapper.hpp" 00037 00038 namespace MBMesquite 00039 { 00040 00041 class MeshDomainAssoc; 00042 00043 class MESQUITE_EXPORT ViscousCFDTetShapeWrapper : public Wrapper 00044 { 00045 private: 00046 double dCutoff, aVal; 00047 int iterationLimit; 00048 int parallelIterations; 00049 double maxVtxMovement; 00050 00051 void run_wrapper( MeshDomainAssoc* mesh_and_domain, 00052 ParallelMesh* pmesh, 00053 Settings* settings, 00054 QualityAssessor* qa, 00055 MsqError& err ); 00056 00057 public: 00058 /** 00059 *\param max_vertex_movement Termination optimization if no vertex is moved 00060 * by more than this distance in the previous solver 00061 * step. 00062 *\param a Coefficient for target metric weight 00063 *\param d_prime Dihedral handle cut-off for target metric weight 00064 *\param max_iterations Termination optimizaiton after this many solver 00065 * steps. 00066 */ 00067 ViscousCFDTetShapeWrapper( double max_vertex_movement, 00068 double a = 0.4395, 00069 double d_prime = 135, 00070 int max_iterations = 50, 00071 int parallel_iterations = 10 ) 00072 : dCutoff( d_prime ), aVal( a ), iterationLimit( max_iterations ), parallelIterations( parallel_iterations ), 00073 maxVtxMovement( max_vertex_movement ) 00074 { 00075 } 00076 }; 00077 00078 } // namespace MBMesquite 00079 00080 #endif
