MOAB: Mesh Oriented datABase
(version 5.3.1)
#include <ViscousCFDTetShapeWrapper.hpp>
Public Member Functions | |
ViscousCFDTetShapeWrapper (double max_vertex_movement, double a=0.4395, double d_prime=135, int max_iterations=50, int parallel_iterations=10) | |
Private Member Functions | |
void | run_wrapper (MeshDomainAssoc *mesh_and_domain, ParallelMesh *pmesh, Settings *settings, QualityAssessor *qa, MsqError &err) |
Private Attributes | |
double | dCutoff |
double | aVal |
int | iterationLimit |
int | parallelIterations |
double | maxVtxMovement |
Definition at line 43 of file ViscousCFDTetShapeWrapper.hpp.
MBMesquite::ViscousCFDTetShapeWrapper::ViscousCFDTetShapeWrapper | ( | double | max_vertex_movement, |
double | a = 0.4395 , |
double | d_prime = 135 , |
int | max_iterations = 50 , |
int | parallel_iterations = 10 |
) | [inline] |
max_vertex_movement | Termination optimization if no vertex is moved by more than this distance in the previous solver step. |
a | Coefficient for target metric weight |
d_prime | Dihedral handle cut-off for target metric weight |
max_iterations | Termination optimizaiton after this many solver steps. |
Definition at line 64 of file ViscousCFDTetShapeWrapper.hpp.
: dCutoff( d_prime ), aVal( a ), iterationLimit( max_iterations ), parallelIterations( parallel_iterations ), maxVtxMovement( max_vertex_movement ) { }
void MBMesquite::ViscousCFDTetShapeWrapper::run_wrapper | ( | MeshDomainAssoc * | mesh_and_domain, |
ParallelMesh * | pmesh, | ||
Settings * | settings, | ||
QualityAssessor * | quality_assessor, | ||
MsqError & | err | ||
) | [private, virtual] |
Function that each wrapper must implement
Implements MBMesquite::Wrapper.
Definition at line 59 of file ViscousCFDTetShapeWrapper.cpp.
References MBMesquite::TerminationCriterion::add_absolute_vertex_movement(), MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::QualityAssessor::add_quality_assessment(), MBMesquite::InstructionQueue::add_quality_assessor(), aVal, dCutoff, MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::Assessor::get_invalid_element_count(), MBMesquite::MeshDomainAssoc::get_mesh(), MBMesquite::QualityAssessor::get_results(), iterationLimit, maxVtxMovement, mesh, MSQ_CHKERR, MSQ_ERRRTN, parallelIterations, MBMesquite::InstructionQueue::remove_quality_assessor(), MBMesquite::InstructionQueue::run_common(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), and MBMesquite::QualityImprover::set_outer_termination_criterion().
{ InstructionQueue q; // Set up barrier metric to see if mesh contains inverted elements TShapeB1 mu_b; IdealShapeTarget w_ideal; TQualityMetric barrier( &w_ideal, &mu_b ); // Check for inverted elements in the mesh QualityAssessor inv_check( &barrier ); inv_check.disable_printing_results(); q.add_quality_assessor( &inv_check, err );MSQ_ERRRTN( err ); q.run_common( mesh_and_domain, pmesh, settings, err );MSQ_ERRRTN( err ); q.remove_quality_assessor( 0, err );MSQ_ERRRTN( err ); const QualityAssessor::Assessor* inv_b = inv_check.get_results( &barrier ); const bool use_barrier = ( 0 == inv_b->get_invalid_element_count() ); // Create remaining metric instances TShapeNB1 mu; TShapeSizeOrientNB1 mu_o; TShapeSizeOrientB1 mu_ob; // Select which target metrics to use TMetric *mu_p, *mu_op; if( use_barrier ) { mu_p = &mu_b; mu_op = &mu_ob; } else { mu_p = μ mu_op = &mu_o; } // Set up target and weight calculators Mesh* mesh = mesh_and_domain->get_mesh(); TagVertexMesh init_mesh( err, pmesh ? (Mesh*)pmesh : mesh );MSQ_ERRRTN( err ); ReferenceMesh ref_mesh( &init_mesh ); RefMeshTargetCalculator w_init( &ref_mesh ); TetDihedralWeight c_dihedral( &ref_mesh, dCutoff, aVal ); RemainingWeight c_remaining( &c_dihedral ); // Create objective function TQualityMetric metric1( &w_ideal, &c_dihedral, mu_p ); TQualityMetric metric2( &w_init, &c_remaining, mu_op ); AddQualityMetric of_metric( &metric1, &metric2, err );MSQ_ERRRTN( err ); PMeanPTemplate obj_func( 1.0, &of_metric ); // Create optimizer TrustRegion solver( &obj_func ); TerminationCriterion term, ptc; term.add_iteration_limit( iterationLimit ); term.add_absolute_vertex_movement( maxVtxMovement ); ptc.add_iteration_limit( pmesh ? parallelIterations : 1 ); solver.set_inner_termination_criterion( &term ); solver.set_outer_termination_criterion( &ptc ); // Create instruction queue qa->add_quality_assessment( &metric1 ); qa->add_quality_assessment( &metric2 ); qa->add_quality_assessment( &of_metric ); q.add_quality_assessor( qa, err );MSQ_ERRRTN( err ); q.set_master_quality_improver( &solver, err );MSQ_ERRRTN( err ); q.add_quality_assessor( qa, err );MSQ_ERRRTN( err ); // Optimize mesh q.run_common( mesh_and_domain, pmesh, settings, err );MSQ_CHKERR( err ); }
double MBMesquite::ViscousCFDTetShapeWrapper::aVal [private] |
Definition at line 46 of file ViscousCFDTetShapeWrapper.hpp.
Referenced by run_wrapper().
double MBMesquite::ViscousCFDTetShapeWrapper::dCutoff [private] |
int MBMesquite::ViscousCFDTetShapeWrapper::iterationLimit [private] |
Definition at line 47 of file ViscousCFDTetShapeWrapper.hpp.
double MBMesquite::ViscousCFDTetShapeWrapper::maxVtxMovement [private] |
Definition at line 49 of file ViscousCFDTetShapeWrapper.hpp.
Definition at line 48 of file ViscousCFDTetShapeWrapper.hpp.
