MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef WRITE_VTK_HPP 00017 #define WRITE_VTK_HPP 00018 00019 #include <iosfwd> 00020 00021 #include "moab/Forward.hpp" 00022 #include "moab/WriterIface.hpp" 00023 00024 namespace moab 00025 { 00026 00027 class WriteUtilIface; 00028 00029 // class MB_DLL_EXPORT WriteVtk : public WriterIface 00030 class WriteVtk : public WriterIface 00031 { 00032 00033 public: 00034 //! Constructor 00035 WriteVtk( Interface* impl ); 00036 00037 //! Destructor 00038 virtual ~WriteVtk(); 00039 00040 static WriterIface* factory( Interface* ); 00041 00042 //! writes out a file 00043 ErrorCode write_file( const char* file_name, 00044 const bool overwrite, 00045 const FileOptions& opts, 00046 const EntityHandle* output_list, 00047 const int num_sets, 00048 const std::vector< std::string >& qa_list, 00049 const Tag* tag_list = NULL, 00050 int num_tags = 0, 00051 int export_dimension = 3 ); 00052 00053 private: 00054 //! Get entities to write, given set list passed to \ref write_file 00055 ErrorCode gather_mesh( const EntityHandle* set_list, int num_sets, Range& nodes, Range& elems ); 00056 00057 //! Write 4-line VTK file header 00058 ErrorCode write_header( std::ostream& stream ); 00059 00060 //! Write node coordinates 00061 ErrorCode write_nodes( std::ostream& stream, const Range& nodes ); 00062 00063 //! Write element connectivity 00064 ErrorCode write_elems( std::ostream& stream, const Range& nodes, const Range& elems ); 00065 00066 //! Write all tags on either the list of nodes or the list of elements 00067 ErrorCode write_tags( std::ostream& stream, bool nodes, const Range& entities, const Tag* tag_list, int num_tags ); 00068 00069 //! Write the tad description for the passed tag and call the template 00070 //! \ref write_tag function to write the tag data. 00071 ErrorCode write_tag( std::ostream& stream, Tag tag, const Range& entities, const Range& tagged_entities ); 00072 00073 //! Write tag data 00074 template < typename T > 00075 ErrorCode write_tag( std::ostream& stream, 00076 Tag tag, 00077 const Range& entities, 00078 const Range& tagged_entities, 00079 const int ); 00080 00081 ErrorCode write_bit_tag( std::ostream& stream, Tag tag, const Range& entities, const Range& tagged_entities ); 00082 //! Write a list of values 00083 template < typename T > 00084 void write_data( std::ostream& stream, const std::vector< T >& data, unsigned vals_per_tag ); 00085 00086 Interface* mbImpl; 00087 WriteUtilIface* writeTool; 00088 00089 bool mStrict; // If true, do not write data that cannot fit in strict VTK file format. 00090 int freeNodes; 00091 bool createOneNodeCells; 00092 }; 00093 00094 } // namespace moab 00095 00096 #endif
