MOAB: Mesh Oriented datABase
(version 5.3.1)
String arugment that is limited to a list of acceptable keywords. More...
#include <CLArgs.hpp>
Public Member Functions | |
KeyWordArg (const char *keyword_list[], int list_length) | |
KeyWordArg (const char *default_val, const char *keyword_list[], int list_length) | |
virtual bool | value (const std::string &val) |
virtual std::string | brief () const |
Get short description string for usage output or empty string for default. | |
virtual std::string | manstr () const |
Get short description string for UNIX man page output or empty string for default. | |
Static Public Member Functions | |
static bool | compare_no_case (const char *s1, const char *s2) |
Private Member Functions | |
void | initialize (const char *keyword_list[], int list_length) |
Private Attributes | |
std::vector< std::string > | mKeyWords |
A specialized string arugment implementation that limits the acceptable string argument to one of a list of keywords. A case-insensitive comparison is done with the allowed keywords. The "value" has the case of the keyword rather than the case used in the literal value specified in the command line argument.
Definition at line 218 of file CLArgs.hpp.
CLArgs::KeyWordArg::KeyWordArg | ( | const char * | keyword_list[], |
int | list_length | ||
) | [inline] |
Definition at line 225 of file CLArgs.hpp.
References initialize().
{ initialize( keyword_list, list_length ); }
CLArgs::KeyWordArg::KeyWordArg | ( | const char * | default_val, |
const char * | keyword_list[], | ||
) | [inline] |
Definition at line 229 of file CLArgs.hpp.
: StringArg( default_val ) { initialize( keyword_list, list_length ); }
std::string CLArgs::KeyWordArg::brief | ( | ) | const [virtual] |
Reimplemented from CLArgs::ArgIBase.
Definition at line 429 of file CLArgs.cpp.
bool CLArgs::KeyWordArg::compare_no_case | ( | const char * | s1, |
const char * | s2 | ||
) | [static] |
Definition at line 456 of file CLArgs.cpp.
{ for( ; *s1; ++s1, ++s2 ) if( toupper( *s1 ) != toupper( *s2 ) ) return false; return !*s2; }
void CLArgs::KeyWordArg::initialize | ( | const char * | keyword_list[], |
) | [private] |
std::string CLArgs::KeyWordArg::manstr | ( | ) | const [virtual] |
Definition at line 442 of file CLArgs.cpp.
References ManPage::bold().
{ if( mKeyWords.empty() ) return std::string(); std::ostringstream ss; ManPage::bold( ss, mKeyWords[0].c_str() ); for( unsigned i = 1; i < mKeyWords.size(); ++i ) { ss << "|"; ManPage::bold( ss, mKeyWords[i].c_str() ); } return ss.str(); }
bool CLArgs::KeyWordArg::value | ( | const std::string & | val | ) | [virtual] |
Definition at line 420 of file CLArgs.cpp.
References compare_no_case(), and value().
{ std::vector< std::string >::const_iterator i; for( i = mKeyWords.begin(); i != mKeyWords.end(); ++i ) if( compare_no_case( i->c_str(), val.c_str() ) ) { return value( *i ); } return false; }
std::vector< std::string > CLArgs::KeyWordArg::mKeyWords [private] |
Definition at line 221 of file CLArgs.hpp.
Referenced by initialize().
