CachedTargetCalculator Member List
This is the complete list of members for CachedTargetCalculator, including all inherited members.
aspect(const MsqMatrix< 3, 3 > &W)MBMesquite::TargetCalculator [static]
aspect(const MsqMatrix< 3, 2 > &W)MBMesquite::TargetCalculator [static]
aspect(const MsqMatrix< 2, 2 > &W)MBMesquite::TargetCalculator [static]
CachedTargetCalculator()CachedTargetCalculator [inline]
called_2dCachedTargetCalculator [private]
called_3dCachedTargetCalculator [private]
called_surfCachedTargetCalculator [private]
calls_2d() const CachedTargetCalculator [inline]
calls_3d() const CachedTargetCalculator [inline]
calls_surf() const CachedTargetCalculator [inline]
clear()CachedTargetCalculator [inline]
factor_2D(const MsqMatrix< 2, 2 > &W, double &Lambda, MsqMatrix< 2, 2 > &V, MsqMatrix< 2, 2 > &Q, MsqMatrix< 2, 2 > &Delta, MsqError &err)MBMesquite::TargetCalculator [static]
factor_3D(const MsqMatrix< 3, 3 > &W, double &Lambda, MsqMatrix< 3, 3 > &V, MsqMatrix< 3, 3 > &Q, MsqMatrix< 3, 3 > &Delta, MsqError &err)MBMesquite::TargetCalculator [static]
factor_surface(const MsqMatrix< 3, 2 > &W, double &Lambda, MsqMatrix< 3, 2 > &V, MsqMatrix< 2, 2 > &Q, MsqMatrix< 2, 2 > &Delta, MsqError &err)MBMesquite::TargetCalculator [static]
get_2D_target(PatchData &, size_t elem, Sample sample, MsqMatrix< 2, 2 > &result, MsqError &)CachedTargetCalculator [inline, virtual]
get_3D_target(PatchData &, size_t elem, Sample sample, MsqMatrix< 3, 3 > &result, MsqError &)CachedTargetCalculator [inline, virtual]
get_refmesh_Jacobian_2D(ReferenceMeshInterface *ref_mesh, PatchData &active_mesh, size_t element_no, Sample sample_no, MsqMatrix< 3, 2 > &W_out, MsqError &err)MBMesquite::TargetCalculator [static]
get_refmesh_Jacobian_3D(ReferenceMeshInterface *ref_mesh, PatchData &active_mesh, size_t element_no, Sample sample_no, MsqMatrix< 3, 3 > &W_out, MsqError &err)MBMesquite::TargetCalculator [static]
get_surface_target(PatchData &, size_t elem, Sample sample, MsqMatrix< 3, 2 > &result, MsqError &)CachedTargetCalculator [inline, virtual]
have_surface_orient() const CachedTargetCalculator [inline, virtual]
ideal_shape_2D(EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 2, 2 > &W, MsqError &err)MBMesquite::TargetCalculator [static]
ideal_shape_3D(EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 3, 3 > &W, MsqError &err)MBMesquite::TargetCalculator [static]
ideal_skew_2D(EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 2, 2 > &W, MsqError &err)MBMesquite::TargetCalculator [static]
ideal_skew_3D(EntityTopology element_type, Sample s, const PatchData &pd, MsqMatrix< 3, 3 > &W, MsqError &err)MBMesquite::TargetCalculator [static]
initialize_queue(MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err)MBMesquite::TargetCalculator [virtual]
jacobian_2D(PatchData &pd, EntityTopology element_type, int num_nodes, Sample location, const Vector3D *coords, MsqMatrix< 3, 2 > &W_out, MsqError &err)MBMesquite::TargetCalculator [static]
jacobian_3D(PatchData &pd, EntityTopology element_type, int num_nodes, Sample location, const Vector3D *coords, MsqMatrix< 3, 3 > &W_out, MsqError &err)MBMesquite::TargetCalculator [static]
make_2d(size_t elem, Sample sample)CachedTargetCalculator [static]
make_3d(size_t elem, Sample sample)CachedTargetCalculator [static]
make_surf(size_t elem, Sample sample)CachedTargetCalculator [static]
new_aspect_2D(const MsqVector< 2 > &r)MBMesquite::TargetCalculator [static]
new_aspect_2D(double rho)MBMesquite::TargetCalculator [static]
new_aspect_3D(const MsqVector< 3 > &r)MBMesquite::TargetCalculator [static]
new_orientation_2D(const MsqVector< 3 > &b1, const MsqVector< 3 > &b2)MBMesquite::TargetCalculator [static]
new_orientation_3D(const MsqVector< 3 > &b1, const MsqVector< 3 > &b2)MBMesquite::TargetCalculator [static]
shape(const MsqMatrix< 3, 3 > &W)MBMesquite::TargetCalculator [static]
shape(const MsqMatrix< 3, 2 > &W)MBMesquite::TargetCalculator [static]
shape(const MsqMatrix< 2, 2 > &W)MBMesquite::TargetCalculator [static]
size(const MsqMatrix< 3, 3 > &W)MBMesquite::TargetCalculator [static]
size(const MsqMatrix< 3, 2 > &W)MBMesquite::TargetCalculator [static]
size(const MsqMatrix< 2, 2 > &W)MBMesquite::TargetCalculator [static]
skew(const MsqMatrix< 3, 3 > &W)MBMesquite::TargetCalculator [static]
skew(const MsqMatrix< 3, 2 > &W)MBMesquite::TargetCalculator [static]
skew(const MsqMatrix< 2, 2 > &W)MBMesquite::TargetCalculator [static]
surf_orient(bool value)CachedTargetCalculator [inline]
surfOrientFlagCachedTargetCalculator [private]
~TargetCalculator()MBMesquite::TargetCalculator [virtual]
