MOAB
4.9.3pre
Rotation given by a cosine-sine pair. More...
#include <Jacobi.h>
Public Types | |
| typedef NumTraits< Scalar >::Real | RealScalar |
Public Member Functions | |
| JacobiRotation () | |
| JacobiRotation (const Scalar &c, const Scalar &s) | |
| Scalar & | c () |
| Scalar | c () const |
| Scalar & | s () |
| Scalar | s () const |
| JacobiRotation | operator* (const JacobiRotation &other) |
| JacobiRotation | transpose () const |
| JacobiRotation | adjoint () const |
| template<typename Derived > | |
| bool | makeJacobi (const MatrixBase< Derived > &, Index p, Index q) |
| bool | makeJacobi (const RealScalar &x, const Scalar &y, const RealScalar &z) |
| void | makeGivens (const Scalar &p, const Scalar &q, Scalar *z=0) |
Protected Member Functions | |
| void | makeGivens (const Scalar &p, const Scalar &q, Scalar *z, internal::true_type) |
| void | makeGivens (const Scalar &p, const Scalar &q, Scalar *z, internal::false_type) |
Protected Attributes | |
| Scalar | m_c |
| Scalar | m_s |
This class represents a Jacobi or Givens rotation. This is a 2D rotation in the plane J of angle
defined by its cosine c and sine s as follow:
You can apply the respective counter-clockwise rotation to a column vector v by applying its adjoint on the left:
that translates to the following Eigen code:
v.applyOnTheLeft(J.adjoint());
| typedef NumTraits<Scalar>::Real Eigen::JacobiRotation< Scalar >::RealScalar |
| Eigen::JacobiRotation< Scalar >::JacobiRotation | ( | ) | [inline] |
| Eigen::JacobiRotation< Scalar >::JacobiRotation | ( | const Scalar & | c, |
| const Scalar & | s | ||
| ) | [inline] |
| JacobiRotation Eigen::JacobiRotation< Scalar >::adjoint | ( | ) | const [inline] |
Returns the adjoint transformation
Definition at line 62 of file Jacobi.h.
{ using numext::conj; return JacobiRotation(conj(m_c), -m_s); }
| Scalar& Eigen::JacobiRotation< Scalar >::c | ( | ) | [inline] |
| Scalar Eigen::JacobiRotation< Scalar >::c | ( | ) | const [inline] |
| void Eigen::JacobiRotation< Scalar >::makeGivens | ( | const Scalar & | p, |
| const Scalar & | q, | ||
| Scalar * | z = 0 |
Makes *this as a Givens rotation G such that applying
to the left of the vector
yields:
The value of z is returned if z is not null (the default is null). Also note that G is built such that the cosine is always real.
Example:
Output:
This function implements the continuous Givens rotation generation algorithm found in Anderson (2000), Discontinuous Plane Rotations and the Symmetric Eigenvalue Problem. LAPACK Working Note 150, University of Tennessee, UT-CS-00-454, December 4, 2000.
Definition at line 148 of file Jacobi.h.
makeGivens(p, q, z, typename internal::conditional<NumTraits<Scalar>::IsComplex, internal::true_type, internal::false_type>::type());
| Scalar * | z, | ||
| internal::true_type | |||
| ) | [protected] |
Definition at line 156 of file Jacobi.h.
using std::sqrt;
using std::abs;
using numext::conj;
if(q==Scalar(0))
m_c = numext::real(p)<0 ? Scalar(-1) : Scalar(1);
m_s = 0;
if(r) *r = m_c * p;
else if(p==Scalar(0))
m_c = 0;
m_s = -q/abs(q);
if(r) *r = abs(q);
else
RealScalar p1 = numext::norm1(p);
RealScalar q1 = numext::norm1(q);
if(p1>=q1)
Scalar ps = p / p1;
RealScalar p2 = numext::abs2(ps);
Scalar qs = q / p1;
RealScalar q2 = numext::abs2(qs);
RealScalar u = sqrt(RealScalar(1) + q2/p2);
if(numext::real(p)<RealScalar(0))
u = -u;
m_c = Scalar(1)/u;
m_s = -qs*conj(ps)*(m_c/p2);
if(r) *r = p * u;
else
Scalar ps = p / q1;
Scalar qs = q / q1;
RealScalar u = q1 * sqrt(p2 + q2);
u = -u;
p1 = abs(p);
ps = p/p1;
m_c = p1/u;
m_s = -conj(ps) * (q/u);
if(r) *r = ps * u;
| Scalar * | z, | ||
| internal::false_type | |||
| ) | [protected] |
Definition at line 215 of file Jacobi.h.
using std::sqrt;
using std::abs;
if(q==Scalar(0))
m_c = p<Scalar(0) ? Scalar(-1) : Scalar(1);
m_s = Scalar(0);
if(r) *r = abs(p);
m_c = Scalar(0);
m_s = q<Scalar(0) ? Scalar(1) : Scalar(-1);
if(r) *r = abs(q);
else if(abs(p) > abs(q))
Scalar t = q/p;
Scalar u = sqrt(Scalar(1) + numext::abs2(t));
if(p<Scalar(0))
u = -u;
m_c = Scalar(1)/u;
m_s = -t * m_c;
if(r) *r = p * u;
else
Scalar t = p/q;
if(q<Scalar(0))
u = -u;
m_s = -Scalar(1)/u;
m_c = -t * m_s;
if(r) *r = q * u;
| bool Eigen::JacobiRotation< Scalar >::makeJacobi | ( | const MatrixBase< Derived > & | m, |
| Index | p, | ||
| Index | q | ||
| ) | [inline] |
Makes *this as a Jacobi rotation J such that applying J on both the right and left sides of the 2x2 selfadjoint matrix
yields a diagonal matrix
Example:
Output:
Definition at line 126 of file Jacobi.h.
return makeJacobi(numext::real(m.coeff(p,p)), m.coeff(p,q), numext::real(m.coeff(q,q)));
| bool Eigen::JacobiRotation< Scalar >::makeJacobi | ( | const RealScalar & | x, |
| const Scalar & | y, | ||
| const RealScalar & | z | ||
Makes *this as a Jacobi rotation J such that applying J on both the right and left sides of the selfadjoint 2x2 matrix
Definition at line 83 of file Jacobi.h.
using std::sqrt;
using std::abs;
typedef typename NumTraits<Scalar>::Real RealScalar;
if(y == Scalar(0))
m_c = Scalar(1);
m_s = Scalar(0);
return false;
else
RealScalar tau = (x-z)/(RealScalar(2)*abs(y));
RealScalar w = sqrt(numext::abs2(tau) + RealScalar(1));
RealScalar t;
if(tau>RealScalar(0))
t = RealScalar(1) / (tau + w);
else
t = RealScalar(1) / (tau - w);
RealScalar sign_t = t > RealScalar(0) ? RealScalar(1) : RealScalar(-1);
RealScalar n = RealScalar(1) / sqrt(numext::abs2(t)+RealScalar(1));
m_s = - sign_t * (numext::conj(y) / abs(y)) * abs(t) * n;
m_c = n;
return true;
| JacobiRotation Eigen::JacobiRotation< Scalar >::operator* | ( | const JacobiRotation< Scalar > & | other | ) | [inline] |
| Scalar& Eigen::JacobiRotation< Scalar >::s | ( | ) | [inline] |
| Scalar Eigen::JacobiRotation< Scalar >::s | ( | ) | const [inline] |
| JacobiRotation Eigen::JacobiRotation< Scalar >::transpose | ( | ) | const [inline] |
Returns the transposed transformation
Definition at line 59 of file Jacobi.h.
{ using numext::conj; return JacobiRotation(m_c, -conj(m_s)); }
Scalar Eigen::JacobiRotation< Scalar >::m_c [protected] |
Scalar Eigen::JacobiRotation< Scalar >::m_s [protected] |
