, including all inherited members.
BOOL enum value | MBMesquite::Mesh | |
BYTE enum value | MBMesquite::Mesh | |
doError | FakeMesh | [private] |
DOUBLE enum value | MBMesquite::Mesh | |
element_iterator(MsqError &err) | FakeMesh | [inline] |
ElementHandle typedef | MBMesquite::Mesh | |
elements_get_attached_vertices(const ElementHandle *, size_t, vector< VertexHandle > &, vector< size_t > &, MsqError &err) | FakeMesh | [inline] |
MBMesquite::Mesh::elements_get_attached_vertices(const ElementHandle *elem_handles, size_t num_elems, std::vector< VertexHandle > &vert_handles, std::vector< size_t > &offsets, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
elements_get_topologies(const ElementHandle *, EntityTopology *, size_t, MsqError &err) | FakeMesh | [inline, virtual] |
elemHandles | FakeMesh | [private] |
EntityHandle typedef | MBMesquite::Mesh | |
FakeMesh(size_t num_verts) | FakeMesh | |
fixedFlags | FakeMesh | [private] |
get_all_elements(vector< ElementHandle > &elems, MsqError &err) | FakeMesh | |
MBMesquite::Mesh::get_all_elements(std::vector< ElementHandle > &elements, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
get_all_vertices(vector< VertexHandle > &verts, MsqError &err) | FakeMesh | |
MBMesquite::Mesh::get_all_vertices(std::vector< VertexHandle > &vertices, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
get_geometric_dimension(MsqError &err) | FakeMesh | [inline, virtual] |
HANDLE enum value | MBMesquite::Mesh | |
INT enum value | MBMesquite::Mesh | |
release() | FakeMesh | [inline, virtual] |
release_entity_handles(const EntityHandle *, size_t, MsqError &err) | FakeMesh | [inline, virtual] |
should_fail(bool yesno) | FakeMesh | [inline] |
tag_create(const string &, TagType, unsigned, const void *, MsqError &err) | FakeMesh | [inline] |
MBMesquite::Mesh::tag_create(const std::string &tag_name, TagType type, unsigned length, const void *default_value, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
tag_delete(TagHandle, MsqError &err) | FakeMesh | [inline, virtual] |
tag_get(const string &, MsqError &err) | FakeMesh | [inline] |
MBMesquite::Mesh::tag_get(const std::string &name, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
tag_get_element_data(TagHandle, size_t, const ElementHandle *, void *, MsqError &err) | FakeMesh | [inline, virtual] |
tag_get_vertex_data(TagHandle, size_t, const VertexHandle *, void *, MsqError &err) | FakeMesh | [inline, virtual] |
tag_properties(TagHandle, string &, TagType &, unsigned &, MsqError &err) | FakeMesh | [inline] |
MBMesquite::Mesh::tag_properties(TagHandle handle, std::string &name_out, TagType &type_out, unsigned &length_out, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
tag_set_element_data(TagHandle, size_t, const ElementHandle *, const void *, MsqError &err) | FakeMesh | [inline, virtual] |
tag_set_vertex_data(TagHandle, size_t, const VertexHandle *, const void *, MsqError &err) | FakeMesh | [inline, virtual] |
TagType enum name | MBMesquite::Mesh | |
vertex_get_byte(const VertexHandle h, unsigned char *b, MsqError &err) | FakeMesh | [inline, virtual] |
vertex_iterator(MsqError &err) | FakeMesh | [inline] |
vertex_set_byte(VertexHandle h, unsigned char b, MsqError &err) | FakeMesh | [inline, virtual] |
vertex_set_coordinates(VertexHandle, const Vector3D &, MsqError &err) | FakeMesh | [inline, virtual] |
vertexBytes | FakeMesh | [private] |
VertexHandle typedef | MBMesquite::Mesh | |
vertHandles | FakeMesh | [private] |
vertices_get_attached_elements(const VertexHandle *array, size_t len, vector< ElementHandle > &elems, vector< size_t > &offsets, MsqError &err) | FakeMesh | |
MBMesquite::Mesh::vertices_get_attached_elements(const VertexHandle *vertex_array, size_t num_vertex, std::vector< ElementHandle > &elements, std::vector< size_t > &offsets, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
vertices_get_byte(const VertexHandle *, unsigned char *, size_t, MsqError &err) | FakeMesh | [virtual] |
vertices_get_coordinates(const VertexHandle *, MsqVertex *, size_t, MsqError &err) | FakeMesh | [inline] |
MBMesquite::Mesh::vertices_get_coordinates(const VertexHandle vert_array[], MsqVertex *coordinates, size_t num_vtx, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
vertices_get_fixed_flag(const VertexHandle *verts, std::vector< bool > &fixed, size_t n, MsqError &err) | FakeMesh | |
MBMesquite::Mesh::vertices_get_fixed_flag(const VertexHandle vert_array[], std::vector< bool > &fixed_flag_array, size_t num_vtx, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
vertices_get_slaved_flag(const VertexHandle *verts, std::vector< bool > &fixed, size_t n, MsqError &err) | FakeMesh | |
MBMesquite::Mesh::vertices_get_slaved_flag(const VertexHandle vert_array[], std::vector< bool > &slaved_flag_array, size_t num_vtx, MsqError &err)=0 | MBMesquite::Mesh | [pure virtual] |
vertices_set_byte(const VertexHandle *, const unsigned char *, size_t, MsqError &err) | FakeMesh | [virtual] |
vertOffsets | FakeMesh | [private] |
~FakeMesh() | FakeMesh | |
~Mesh() | MBMesquite::Mesh | [inline, virtual] |
