MBMesquite::CornerHessDiagIterator Class Reference
Iterate over only diagonal blocks of element corner Hessian data. More...
+ Collaboration diagram for MBMesquite::CornerHessDiagIterator:
Public Member Functions
 CornerHessDiagIterator (const Matrix3D *corner_hessians, EntityTopology elem_type)
SymMatrix3D operator* () const
CornerHessDiagIteratoroperator++ ()
CornerHessDiagIterator operator++ (int)
Private Attributes
const Matrix3DcornerHess
 Current location in concatenated Hessian data.
const EntityTopology elemType
 Element topology for Hessian data.
unsigned mCorner
unsigned mStep
 Amount to step to reach next diagonal block.
Detailed Description
Given concatenation of corner Hessian data for an element, iterate over only the diagonal terms for each corner. This class allows common code to be used to generate Hessian diagonal blocks from either the diagonal blocks for each corner or the full Hessian data for each corner, where this class is used for the latter.
Definition at line 100 of file AveragingQM.cpp.
MBMesquite::CornerHessDiagIterator::CornerHessDiagIterator ( const Matrix3D corner_hessians,
) [inline]
Definition at line 109 of file AveragingQM.cpp.
References elemType, mCorner, and mStep.
        : cornerHess( corner_hessians ), elemType( elem_type ), mCorner( 0 )
        TopologyInfo::adjacent_vertices( elemType, mCorner, mStep );
        ++mStep;
Member Function Documentation
SymMatrix3D MBMesquite::CornerHessDiagIterator::operator* ( ) const [inline]
Definition at line 116 of file AveragingQM.cpp.
References cornerHess, and MBMesquite::Matrix3D::upper().
        return cornerHess->upper();
CornerHessDiagIterator& MBMesquite::CornerHessDiagIterator::operator++ ( ) [inline]
Definition at line 121 of file AveragingQM.cpp.
References cornerHess, elemType, mCorner, and mStep.
Referenced by operator++().
        cornerHess += mStep;
        if( !--mStep )
            TopologyInfo::adjacent_vertices( elemType, ++mCorner, mStep );
            ++mStep;
        return *this;
CornerHessDiagIterator MBMesquite::CornerHessDiagIterator::operator++ ( int  ) [inline]
Definition at line 132 of file AveragingQM.cpp.
References operator++().
        CornerHessDiagIterator copy( *this );
        operator++();
        return copy;
Member Data Documentation
Definition at line 103 of file AveragingQM.cpp.
Referenced by operator*(), and operator++().
Definition at line 104 of file AveragingQM.cpp.
Referenced by CornerHessDiagIterator(), and operator++().
The element corner for which cornerHess is pointing into the corresponding Hessian data.
Definition at line 105 of file AveragingQM.cpp.
Definition at line 107 of file AveragingQM.cpp.
List of all members.
