MOAB: Mesh Oriented datABase
(version 5.2.1)
Public Member Functions | |
void | test_snap_to () |
void | test_arc_length () |
void | test_position_from_length () |
Private Member Functions | |
CPPUNIT_TEST_SUITE (LineDomainTest) | |
CPPUNIT_TEST (test_snap_to) | |
CPPUNIT_TEST (test_arc_length) | |
CPPUNIT_TEST (test_position_from_length) | |
CPPUNIT_TEST_SUITE_END () |
Definition at line 38 of file LineDomainTest.cpp.
MBMesquite::LineDomainTest::CPPUNIT_TEST | ( | test_snap_to | ) | [private] |
MBMesquite::LineDomainTest::CPPUNIT_TEST | ( | test_arc_length | ) | [private] |
MBMesquite::LineDomainTest::CPPUNIT_TEST_SUITE | ( | LineDomainTest | ) | [private] |
MBMesquite::LineDomainTest::CPPUNIT_TEST_SUITE_END | ( | ) | [private] |
Definition at line 75 of file LineDomainTest.cpp.
References MBMesquite::LineDomain::arc_length(), ASSERT_NO_ERROR, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::Vector3D::length(), and MBMesquite::Vector3D::to_array().
{ MsqPrintError err( std::cerr ); const Vector3D base1( 1, 1, 1 ); const Vector3D dir1( -1, -2, -3 ); LineDomain dom1( base1, dir1 ); double l1 = 1.0, l2 = M_PI; Vector3D p1 = base1 + l1 / dir1.length() * dir1; Vector3D p2 = base1 + l2 / dir1.length() * dir1; double len = dom1.arc_length( p1.to_array(), p2.to_array(), err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_DOUBLES_EQUAL( l2 - l1, len, 1e-6 ); len = dom1.arc_length( p2.to_array(), p1.to_array(), err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_DOUBLES_EQUAL( l1 - l2, len, 1e-6 ); }
Definition at line 94 of file LineDomainTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::Vector3D::length(), MBMesquite::LineDomain::position_from_length(), MBMesquite::Vector3D::to_array(), and moab::unit().
{ MsqPrintError err( std::cerr ); const Vector3D base1( 1, 1, 1 ); const Vector3D dir1( -1, -2, -3 ); LineDomain dom1( base1, dir1 ); const Vector3D unit = dir1 / dir1.length(); double l1 = 1.5; Vector3D result; dom1.position_from_length( base1.to_array(), l1, result.to_array(), err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_VECTORS_EQUAL( base1 + l1 * unit, result, 1e-6 ); double l2 = 3.333; Vector3D result2; dom1.position_from_length( result.to_array(), l2, result2.to_array(), err ); ASSERT_NO_ERROR( err ); CPPUNIT_ASSERT_VECTORS_EQUAL( result + l2 * unit, result2, 1e-6 ); }
Definition at line 55 of file LineDomainTest.cpp.
References CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::length(), and MBMesquite::LineDomain::snap_to().
{ const Vector3D base1( 1, 1, 1 ); const Vector3D dir1( -1, -2, -3 ); LineDomain dom1( base1, dir1 ); Vector3D point( 0, 0, 0 ), result( point ); dom1.snap_to( 0, result ); CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, ( ( result - base1 ) * dir1 ).length(), 1e-6 ); // on the line CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, ( ( point - result ) % dir1 ), 1e-6 ); // moved perp to line point = Vector3D( 10, 11, 12 ); result = point; dom1.snap_to( 0, result ); CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, ( ( result - base1 ) * dir1 ).length(), 1e-6 ); // on the line CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.0, ( ( point - result ) % dir1 ), 1e-6 ); // moved perp to line }
