BOOL enum value | MBMesquite::Mesh | |
BYTE enum value | MBMesquite::Mesh | |
clear() | MBMesquite::MeshImpl | |
DOUBLE enum value | MBMesquite::Mesh | |
element_iterator(MsqError &err) | MBMesquite::MeshImpl | [virtual] |
ElementHandle typedef | MBMesquite::Mesh | |
elements_get_attached_vertices(const ElementHandle *elem_handles, size_t num_elems, std::vector< VertexHandle > &vert_handles, std::vector< size_t > &offsets, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
elements_get_topologies(const ElementHandle *element_handle_array, EntityTopology *element_topologies, size_t num_elements, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
EntityHandle typedef | MBMesquite::Mesh | |
get_all_elements(std::vector< ElementHandle > &handles, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
get_all_vertices(std::vector< VertexHandle > &vertices, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
get_geometric_dimension(MsqError &err) | MBMesquite::MeshImpl | [virtual] |
HANDLE enum value | MBMesquite::Mesh | |
INT enum value | MBMesquite::Mesh | |
mark_skin_fixed(MsqError &err, bool clear_existing=true) | MBMesquite::MeshImpl | |
MeshImpl() | MBMesquite::MeshImpl | |
MeshImpl(int num_vertex, int num_elem, EntityTopology entity_topology, const bool *fixed, const double *coords, const int *conn) | MBMesquite::MeshImpl | |
MeshImpl(int num_vertex, int num_elem, const EntityTopology *element_topologies, const bool *fixed, const double *coords, const int *conn) | MBMesquite::MeshImpl | |
myMesh | MBMesquite::MeshImpl | [protected] |
myTags | MBMesquite::MeshImpl | [protected] |
numCoords | MBMesquite::MeshImpl | [protected] |
read_exodus(const char *in_filename, MBMesquite::MsqError &err) | MBMesquite::MeshImpl | |
read_vtk(const char *in_filename, MBMesquite::MsqError &err) | MBMesquite::MeshImpl | |
release() | MBMesquite::MeshImpl | [virtual] |
release_entity_handles(const EntityHandle *handle_array, size_t num_handles, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
set_all_fixed_flags(bool value, MsqError &err) | MBMesquite::MeshImpl | |
set_all_slaved_flags(bool value, MsqError &err) | MBMesquite::MeshImpl | |
set_skin_flags(bool corner_fixed_flag, bool midnode_fixed_flag, bool midnode_slaved_flag, MsqError &err) | MBMesquite::MeshImpl | |
tag_create(const std::string &tag_name, TagType type, unsigned length, const void *default_value, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
tag_delete(TagHandle handle, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
tag_get(const std::string &name, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
tag_get_element_data(TagHandle handle, size_t num_elems, const ElementHandle *elem_array, void *tag_data, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
tag_get_vertex_data(TagHandle handle, size_t num_elems, const VertexHandle *node_array, void *tag_data, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
tag_properties(TagHandle handle, std::string &name_out, TagType &type_out, unsigned &length_out, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
tag_set_element_data(TagHandle handle, size_t num_elems, const ElementHandle *elem_array, const void *tag_data, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
tag_set_vertex_data(TagHandle handle, size_t num_elems, const VertexHandle *node_array, const void *tag_data, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
tag_to_bool(const char *tag_name, std::vector< bool > &vertex_vals, MsqError &err) | MBMesquite::MeshImpl | [private] |
TagType enum name | MBMesquite::Mesh | |
vertex_get_byte(const VertexHandle vertex, unsigned char *byte, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
vertex_iterator(MsqError &err) | MBMesquite::MeshImpl | [virtual] |
vertex_set_byte(VertexHandle vertex, unsigned char byte, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
vertex_set_coordinates(VertexHandle vertex, const Vector3D &coordinates, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
VertexHandle typedef | MBMesquite::Mesh | |
vertices_get_attached_elements(const VertexHandle *vertex_array, size_t num_vertex, std::vector< ElementHandle > &elements, std::vector< size_t > &offsets, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
vertices_get_byte(const VertexHandle *vertex, unsigned char *byte_array, size_t array_size, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
vertices_get_coordinates(const Mesh::VertexHandle vert_array[], MBMesquite::MsqVertex *coordinates, size_t num_vtx, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
vertices_get_fixed_flag(const VertexHandle vert_array[], std::vector< bool > &fixed_flag_array, size_t num_vtx, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
vertices_get_slaved_flag(const VertexHandle vert_array[], std::vector< bool > &slaved_flag_array, size_t num_vtx, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
vertices_set_byte(const VertexHandle *vert_array, const unsigned char *byte_array, size_t array_size, MsqError &err) | MBMesquite::MeshImpl | [virtual] |
vertices_set_fixed_flag(const VertexHandle vert_array[], const std::vector< bool > &fixed_flag_array, size_t num_vtx, MsqError &err) | MBMesquite::MeshImpl | |
vtk_create_structured_elems(const long *dims, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_attrib_data(FileTokenizer &file, long num_data_to_read, TagDescription &tag_out, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_cell_data(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_color_attrib(FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_dataset(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_field(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_field_data(FileTokenizer &file, size_t count, size_t field_count, const std::string &field_name, TagDescription &tag, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_point_data(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_polydata(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_polygons(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_rectilinear_grid(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_scalar_attrib(FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_structured_grid(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_structured_points(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_tensor_attrib(FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_texture_attrib(FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_typed_data(FileTokenizer &file, int type, size_t per_elem, size_t num_elem, TagDescription &tag_out, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_unstructured_grid(FileTokenizer &file, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_read_vector_attrib(FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err) | MBMesquite::MeshImpl | [private] |
vtk_store_cell_data(const void *data, TagDescription &desc, MsqError &) | MBMesquite::MeshImpl | [private] |
vtk_store_point_data(const void *data, TagDescription &desc, MsqError &) | MBMesquite::MeshImpl | [private] |
vtk_write_attrib_data(std::ostream &file, const TagDescription &desc, const void *data, size_t count, MsqError &err) const | MBMesquite::MeshImpl | [private] |
write_exodus(const char *out_filename, MBMesquite::MsqError &err) | MBMesquite::MeshImpl | |
write_vtk(const char *out_filename, MBMesquite::MsqError &err) | MBMesquite::MeshImpl | |
~Mesh() | MBMesquite::Mesh | [inline, virtual] |
~MeshImpl() | MBMesquite::MeshImpl | [virtual] |
